Wiping data completely
  • severach
    • Aug 2007
    • 1055
    Re: Wiping data completely
    I prefer to zero drives from within a running Windows. I have one running all the time so why not use it. Plug in, zero, eject. USB or SATA, I can zero whatever you like (you like)!
    I like Western Digital Data Lifeguard Diagnostic for Windows. Easy, fast, and reliable. It doesn't work right with RAID drives present so I use GDISK32.
    Just 1 pass of zeros. It's sufficient for all but high security government data, and no, your tax returns aren't. No one will pay a plugged nickle for those!
    sig files are for morons
    • c_hegge
      • Sep 2009
      • 5219
      WD lifeguard only works with WD Drives IIRC. I usually use Seatools for Diagnostics. It will test anything
      • Agent24
        I see dead caps
        • Oct 2007
        • 5086
        • New Zealand
        I use HDAT2.
        -David VanHorn
        • ddscentral
          • Mar 2008
          • 151
          • Lithuania, EU
          I mostly use Linux DD command to erase disks (and shred for secure erase).
          • falcontech
            Denon Mc6000 channel 1 completely non-functional
            by falcontech
            Hello
            I need your help with a non-functioning channel on this Denon controller. I noticed the problem because, with the mixing software, the channel appears completely off and none of its controls work. At the top of the channel, like the others, there's a selector switch that moves between MIDI and external audio inputs. I also tried connecting an audio source (since it's also a standalone mixer) and I got no input. The flat cable connecting this panel to the sound card is fine. I'm attaching a photo and the service manual. I hope someone can help me resolve the issue. Thanks....
            09-04-2025, 09:03 AM
          • max-power
            Dell E6540 laptop completely dead after dssasembly
            by max-power
            Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
            that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
            After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
            03-24-2025, 08:49 AM
          • fiveseventy
            RX570 dies completely, then recovers.
            by fiveseventy
            Hello all,
            I have a Sapphire Radeon RX 570 Pulse ITX 4GB (single fan) which has started misbehaving recently.
            The card was bought used maybe 5 years ago and has worked without issue until recently.
            I have no reason to believe it has been worked on or physically damaged.
            For periods of time it will be 100% perfect.
            Perfect temperatures, no glitches or artefacts, solid FPS.
            I can game, run benchmarks, do whatever without any problem.
            I can reboot the machine as many times as I like and nothing changes
            however, most times...
            06-22-2024, 05:29 AM
          • pavski
            Completely dead MSI z490 tomahawk
            by pavski
            Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
            I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
            t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
            Can you please let me know if this is indeed incorrect and what else should I look at next?
            Thanks!
            06-02-2024, 02:42 PM
          • Andreasbest
            Lenovo Thinkpad T14s completely dead.
            by Andreasbest
            Hello.
            I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
            I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
            Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
            Thank you in advance!
            Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
            03-19-2024, 03:18 AM
