Completely dead MSI z490 tomahawk
  • pavski
    • May 2021
    • 5
    Trying to troubleshoot MSI z490 tomahawk board and would appreciate your help. The board is completely dead and shows no activity when the power button is pressed.
    I have tried to look at the Superio, the PSIN signal seems to be correct (goes from 3.3V to 0 on button press) but the voltage on PSOUT pin is quite low. I
    t is only 0.8V which seems to be incorrect but goes to 0 when the button is pressed.
    Can you please let me know if this is indeed incorrect and what else should I look at next?
    Thanks!
  • DynaxSC
    • Apr 2021
    • 458
    • Poland
    PSOUT seems to be strange value, normally should be 0 or around 3.3V.
    But before analyzing the signals on the board, first you should rule out the BIOS image, if it's not demaged. Read out and backup the image with a hw programmer, and read it with eg. UEFITool, to see if the contents make any sense. You can compare it with a stock image.Then for test you can write a stock image to the BIOS SPI chip, and see if the board will start or not, this will give you final prove. Don't throw away the original image, as it contains speciific data for the board, eg. MAC LAN Address, UUID, S/N.
    If BIOS is ok, then go to checking the PCH supply voltages (1.05V, 1.8V and 3.3V). They should be present in stand-by mode. If any isn't present, this means 99% the chipset is dead (shorted power supply line). Most easiest place to check this is on the inner pads of the caps which are soldered on the PCH around the silicon die.
    If they are all present, next is to check whether the chipset asserts the SLP_S3# signal (can be found on pin 64 of SIO) after SuperIO asserted PWRBTN out (pin 60 or 61 of SIO, don't remember exactly). This signal from PCH usually starts the pre boot power sequence.
    If SLP_S3# is not asserted, then it might mean that PCH is somehow demaged, despite the supply voltages are not shorted, or PCH get some wrong signals not allowing to assert SLP_S3, eg. some shorted signal on the board.
    I could write and write more things to do, but just read many other posts on the forum, there is already a lot of similar cases, where you can get much more hints. Take the time for it, as it is not possible to write a full instruction how to diagnose a board, as there can be thousands of reasons why a board is not working.
    • max-power
      Dell E6540 laptop completely dead after dssasembly
      by max-power
      Hi, I disassemble my laptop to replace the speakers, to access them, you have to remove everything including the heat sink and fan, unscrew the motherboard, lift it up a bit to access the speaker wire.
      that was not the first time I dissasemble it, i did replace the same speaker a few year ago and I repaste it last year, so I had nothing to worry about. but when I put everything back together, its completely dead.
      After a bit of investigating, i found one pin of the status led ribbon cable that was unglued from the cable and bend touching another pin, I bend it back at his place...
      03-24-2025, 08:49 AM
    • wangbreeze
      T480s random shutoff and then completely dead
      by wangbreeze
      Hello Gurus,
      I got a ThinkPad T480s. It was running fine but suddenly started random shut down. When it turned off, I had to push the reset pin to bring it back to life. But it got aggressively worse and became completely dead. No charging light, no life.
      I did some initial diagnostics with just the board (no battery, nothing attached, and no CMOS battery as well)
      Initial testing of the coil resistance seems to indicate no dead short. The only low resistance I measured was at PL701. It reads 38 ohms.
      charger gave - 20V - ok
      U101B
      02-03-2024, 04:57 PM
    • pavski
      Board view and schematics for MSI Mag z490 tomahawk board
      by pavski
      The MSI Mag z490 tomahawk board is not responding to pressing the switch button. There is voltage supplied to BIOS and superio but I would like to trace it. Perhaps somebody could share board view and schematics? Thank you....
      06-01-2024, 12:49 PM
    • Andreasbest
      Lenovo Thinkpad T14s completely dead.
      by Andreasbest
      Hello.
      I received a T14s Gen1 ( NM-C891 motherboard ) that is completely dead, no indication of life at all.
      I tried hard reset without RTC battery and short both pins of it for 1 minute but no luck.
      Since it's type C connector i have no idea what to measure or where to inject voltage, so any advice are welcomed
      Thank you in advance!
      Schematic & boardview -> https://www.badcaps.net/forum/troubl...cfc-nm-c891-sc...
      03-19-2024, 03:18 AM
    • armini
      18VDC PSU completely dead - ZD-915 desoldering station
      by armini
      Hi everyone!
      Three years ago I got a ZD-915 desoldering station which failed just after a few months of light use. During a short desoldering session, the station simply shut down, and since then it has been completely dead and unresponsive. The failure was silent, without any pops.
      Due to a lack of time, I set it aside and didn't look at it.
      Yesterday, I took it apart and did some basic measurements. The 18v terminal shows 0v. In addition, there is no visible damage to the board itself.
      According to replies in 18VDC PSU has dropped to...
      04-25-2023, 07:49 AM
