LCFC NM-C891 Schematic & Boardview
    • 22176
    LCFC NM-C891 boardview required if anyone has it please.
  • Mike_Ho
    • Sep 2022
    • 25
    • Hong Kong
    Here
      • 22176
      Originally posted by Mike_Ho
      Here
      Thank you
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1356
        • France
        @SMDFlea
        visible from both sides, but only accessible in one place, you must follow the 2774 lines​
          SMDFlea commented
          Editing a comment
          Thanks, i`ll check that ;-) and continue our discussion later.
        • 22176
        Schematic
        • vicmark63
          • May 2023
          • 10
          Schematic
          Thanks alot!
          • questore
            • Dec 2015
            • 575
            • csongrád
            Schematic
            Thank you
            • Mikereevers
              Lenovo IdeaPad Slim 3 15IAN8 | LCFC KS480&KS580 NM-E901 REV 1.0 Schematic & Boardview
              by Mikereevers
              Would anyone have a schematic and/or boardview for the LCFC KS480&KS580 NM-E901 please?
              01-22-2025, 02:13 PM
            • mard312
              Legion Go 8APU1 boardview or schematic
              by mard312
              I’m working on repairing a Lenovo Legion Go that suffered liquid damage. Unfortunately, one of the ICs on the motherboard burned out, and I haven’t been able to find any boardview or schematic for this model anywhere.
              Does anyone happen to know what this particular chip is, or have access to the schematic/boardview for this motherboard? Any help or reference would be greatly appreciated.
              11-12-2025, 01:01 PM
            • AustinCER
              In Search of Schematic/Boardview for Lenovo Ideapad Flex 5 14ALC7
              by AustinCER
              I am in search of a schematic or boardview for Lenovo Ideapad Flex 5 14ALC7.
              No power and no charging LED with AC Adapter connected. AC Adapter is functioning at 19V, and also tried another Lenovo AC Adapter -- no charging LED still.
              There is an active 19V from the USB-C port to the motherboard with AC Adapter connected, so the port is also fine. I am assuming there is a short on one of the power rails, but don't know where to start looking.
              Any insight, schematic or boardview would be greatly appreciated.
              Model: Lenovo Ideapad Flex 5 14ALC7...
              11-04-2025, 03:49 PM
            • PacoGT
              HP ENVY x360 gidget 8L 203038-1, boardview and schematic need
              by PacoGT
              hello firends
              i search the schematic or boardview
              I have this motherboard, but I can't find the schematic or the boardview.
              The problem is that on the chip marked where 3V should be, there are 5 volts, which indicates that the two are connected.
              So the computer doesn't turn on, and the 3V disappears after a few seconds.
              The original problem was that when I turned off the computer, the fan stayed on and saw that it was bad since it was directly in the 5V area.
              The new problem arose after removing the bad chip.
              3V and 5V remained together,...
              08-19-2025, 08:25 PM
            • hosain0489
              Request for Schematic and Boardview for HP Omen 16-xf0006AX (AMD Ryzen 7 7840H Version)
              by hosain0489
              I’m looking for the schematic and boardview files specifically for the AMD version of the HP Omen 16 laptop, model xf0006AX, equipped with the Ryzen 7 7840H CPU.
              Most of the files I’ve found are for Intel CPU versions, and I need the exact files for this AMD Ryzen 7 7840H model to assist with repair and troubleshooting.
              If anyone has access to these files or can kindly share the boardview and schematic for this particular AMD version, I would really appreciate your support.
              Thank you very much in advance!
              07-15-2025, 11:20 AM
