Cheap PSU: Piece of junk or semi-decent?
  • Behemot
    • 4845
    • CZ
    #221
    Re: Cheap PSU: Piece of junk or semi-decent?
    Originally posted by TELVM
    This crappy PSU doesn't have any PI coil in the output
    I can see one from here on +3,3 V
    If you remember that Eurocase of mine, it actually had two coils on +3,3 V. I think that's the reason why this rail stayed in spec almost under all circuimstances. Other rails were so-so, barely in spec even with 50 % higher total capacitance
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      #222
      1,2 (+5V) · 1000uF · 10V · 105C · ASIA
      3 (+5VSB) · 470· 16V· 105C · ASIA
      4 (-12V) · 470· 16V· 105C · ASIA
      5,6 (+12V) · 1000uF · 16V· 105C · ChengX
      7,8 (+3.3V) · 1000uF · 10V · 105C · ASIA
      12 (+5VSB) · 1000uF · 16V· 105C · ChengX
      13 (+5VSB) · 47uF · 50V · ChengX
      1,2 (+5V) · 2200uF
      3 (+5VSB) · 1000uF
      4 (-12V) · 470· 16V · don't change the value of that cap
      5,6 (+12V) · 2200uF · 16V
      7,8 (+3.3V) · 2200uF
      12 (+5VSB) · 1000uF · don't change the value of that cap
        master hoarder
        • May 2008
        • 12175
        #223
        ^ what goodpsusearch said. Those are good values to use. The Panasonic FJ may actually work due to lack of PI coils and small output inductors. Also make sure to change #14, 15, and 16. Use same or higher voltage and same capacitance values. #13 looks like a filter cap for the auxiliary rail that powers the PWM controller. Not necessary to replace unless it plays part in the 5VSB regulation. On older Deer/L&C units, I know it doesn't, but not sure about this one. Probably doesn't so you can leave it alone.
        You must have the ability to see ghosts too then because I don't see any PI coils either .
        • TELVM
          • Oct 2012
          • 547
          • Spain
          #224
          Thanks!
          Hmmm ... I'm wondering about adding PI coils to a PCB that lacks parking slots for them ... ...
          If I understand it correctly,
          to add a PI coil for say caps no. 1 & 2, I should cut the direct trace from 1+ to 2+, then bridge 1+ and 2+ with the PI coil. Right?
          • Behemot
            • 4845
            • CZ
            #225
            Well it's not typical, but still SOME output filter in there. See the big toroid coil? I bet it sits on +3,3 V.
            • c_hegge
              • Sep 2009
              • 5219
              Yes. Exactly
              • TELVM
                • Oct 2012
                • 547
                • Spain
                #227
                Originally posted by c_hegge
                Yes. Exactly
                Thanks C_hegge . Piece of cake then .
                  master hoarder
                  • May 2008
                  • 12175
                  #228
                  Which torroid are you referring to? There are 3, but they are all required for proper operation of the PSU. 1 is for the common mode choke for the 12V, 5V, and -12V rails, 1 is for the 3.3V rail, and the last small one between the 2 heat sinks is used for deriving the 3.3V rail from the 5V rail output pins on the transformer (the mag amp circuit).
                  The PI coils/bobbins, on the other hand, are not required but they can improve the ripple and noise filtering quite a bit.
                  Piece of cake then
                  I think I foresee more ghetto PSU modding here
                  • Behemot
                    • 4845
                    • CZ
                    #229
                    This. There are PSU without this one When it's present, it greatly improves ripple. So I personally take it as part of the filtration.
                      master hoarder
                      • May 2008
                      • 12175
                      #230
                      The PSUs that don't have it use a totally different design to get their 3.3V rail. On such PSUs, there will also be no mag amp torroid - that's because there is no mag amp circuit. Most PSUs that don't have the 3.3V rail torroid use linear regulation to get the 3.3V rail and most of these designs will actually have even cleaner 3.3V rail with much less noise.
                      So just because there is a torroid for the 3.3V rail doesn't mean the PSU will have cleaner output on the 3.3V rail.
                      • Behemot
                        • 4845
                        • CZ
                        #231
                        I gess you are out of picture. I thoguh we are talking about cheap chineese craps here. So how the hell got things like „a totally different desing to get their 3.3V rail“ here? You are way of price region we are in.
                        • goodpsusearch
                          • Oct 2009
                          • 2850
                          • Greece
                          #232
                          No, he is right. If I get it correct he talks about using a mosfet to get 3.3V. Many cheap psus use that solution because they save some cents not having to use some parts and the result is cleaner 3.3V, but lower in A.
                          • Behemot
                            • 4845
                            • CZ
                            #233
                            I have never seen it in my life yet and only once here on pictures. Also getting it from +5 V is pure insanity, efficency is terrible. Better to get it from +12 V.
                            More common is to get +5 V SB using refference from some higher voltage from small transformer.
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              #234
                              The MOSFET is used a linear regulator - efficiency would be even worse if they would take it from 12v. Why do you think that even the lowest end units use 40A parts there? They'd cheap out on those if they could. Highest i've seen so far was rated 80A.
                              That's how any regulated SMPS works.
                              A working TV? How boring!
                                Most of the time it is actually magamp regulated, not linear regulated. But it almost always uses the same transformer tap.
                                I think maybe 10A would be the maximum practical from a linear regulated 3.3V, a low end motherboard would probably be OK with that (it usually only provides RAM and chipset power; both of which are usually linear regulated on the motherboard again... so almost all of the power is thrown away.)
                                • Behemot
                                  • 4845
                                  • CZ
                                  #236
                                  I mean refference like, for example, http://pdf1.alldatasheet.com/datashe...ICS/LM123.html. The refference component, not using comparator against refference voltage
                                  • Wester547
                                    • Nov 2011
                                    • 1269
                                    • USA.
                                    #237
                                    Do you mean the amount that would be practically used by the +3.3V rail or literally the practical maximum DC-DC converted +3.3V (or linear regulated) would be good for? Some would contest that more than 15A is not drawn. You'd probably be right though if you consider the DC-DC converters on a motherboard and how many ICs essentially use even lower voltages than +3.3V because of that.
                                    Do you mean DC-DC conversion/linear regulation is less effective than the traditional 2-toroidal coil setup and schotty barrier rectifiers? I always thought a secondary circuit made up of MOSFETs (for DC-DC conversion, considering the limitations of group-regulated power supplies) instead of diode packages would be more effective (synchronous rectification in place of diodes).
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #238
                                      Well, I know we're going off-topic, so I'll try to keep this post to a minimum...
                                      I thought so too, but then I noticed a lot of the older 200-250W HiPro PSUs from OEM PCs use that and they are rated usually 14A or more. Those, however, do have a separate transformer tap for the 3.3V rail. I never measured it but I'm guessing it's probably just a bit higher than 3.5V.
                                      There's 2 ways to do DC-DC conversion in a PSU. One is with 2 MOSFETs in a synchronous buck DC-DC circuit, the other is with a single MOSFET in a linear regulated circuit. The linear is very inefficient but very simple to build. Buck is extremely efficient but complex and requires a buck PWM controller.
                                      Synchronous rectification is a totally different animal, so I won't discuss it here. And yes, it's very efficient too.
                                      • TELVM
                                        • Oct 2012
                                        • 547
                                        • Spain
                                        #239
                                        ... we're going off-topic, so I'll try to keep this post to a minimum...
                                        Please feel free, it's very interesting and educative stuff .
                                        • goodpsusearch
                                          • Oct 2009
                                          • 2850
                                          • Greece
                                          #240
                                          Quoted for truth. Thanks momaka!!
