So the 16v 1500uF capacitor C9B1 near the power connector on the back of a Phat started leaking. Haven't been able to find the right cap, so I replaced it with a larger 25v 2200uF capacitor a couple weeks ago and everything is working fine since then. I didn't replace the other six 16v caps, they were all good.
When putting the fan plastic cover back I remember there were maybe 2-3 mm of clearance on top of it and 1-2 mm of clearance to the side of it.
For those that don't remember what the fan cover looks like I found this picture https://cdn.quade.co/wp-content/uplo...327_182209.jpg
As you can see on the top right there is a piece of plastic that is going over a capacitor, that is a picture of a original capacitor, the one I replaced it with is slightly bigger.
After running the console and turning it off, there wasn't any overheating issue and the cap was cool to the touch. What risk am I running if in a couple of years the cap starts leaking and makes contact with the plastic fan cover. Also what risk am I running using a larger uF capacitor? I know using more voltage is safe but not sure of uF.
 , since the Xbox 360 has such piss-poor cooling, that the GPU is more likely to die before the replacement cap(s) do, even if the replacement caps are of crap quality and/or not the right type (ultra-low ESR.) So as a side note, if anyone still cares to extend the life of their Xbox 360, consider buying a 2nd CPU heatsink for your Xbox 360, and then replace the undersized GPU heatsink with the CPU heatsink you bought. Of course, if you do that, the CD/DVD drive will no longer fit in the Xbox 360 case... so this is probably better-suited towards modded Xbox 360's that have mod chips to run games off the HDD... or if you don't mind uglier looks, just relocate the optical drive outside of the case.
