Dead Vizio M43-C1
  • garry7263
    • Feb 2013
    • 105
    Dead Vizio M43-C1
    Have a dead 43 inch Vizio 4k TV
    I measured the voltage at the connector. Getting 19 volts at the 12 pins and with the main board connected I get the standby voltage. I get the 19 volts with the other boards disconnected.
    I hope there is some protection from over voltage on the main board. Don't want to do anything else till I can get the 12 volt pins reading 12 volts.
  • neilc6
    • Nov 2015
    • 1550
    Re: Dead Vizio M43-C1
    19V at 12V pin is red herring. Just mislabelled. Check for ps-on and b-lon signals
    https://www.badcaps.net/forum/showthread.php?t=76708
    • nomoresonys
      • 12307
      • U.S.
      Do test number 3 below try to do it just as instructed.
      • garry7263
        • Feb 2013
        • 105
        plugged in:
        BL_OFF/ON ( .001v ) | DIM ( .010v )
        3D_ON ( .000v ) | PS_ON ( .075v )
        GND ( .000v ) | GND ( .000v )
        +12V_A ( +19.03v ) | +12V_A ( +19.03v )
        +12V ( +19.03v ) | +12V ( +19.03v )
        +5V/+3.5V ( +5.16v ) | +5V/+3.5V ( +5.16v )
        Turned on:
        BL_OFF/ON ( .107v ) | DIM ( 3.333v )
        3D_ON ( .009v ) | PS_ON ( 3.690v )
        GND ( .009v ) | GND ( .009v )
        +12V_A ( +18.98v ) | +12V_A ( +18.98v )
        +12V ( +18.98v ) | +12V ( +18.98v )
        +5V/+3.5V ( +5.14v ) | +5V/+3.5V ( +5.14v )
        I checked the voltage without the main board plugged in. Same readings but 0.00v on the standby voltages. Shouldn't they read 5 volts leaving the power board to provide 5v to the main board for standby?
        Obviously .107v is not enough to turn on the backlights.
        • nomoresonys
          • 12307
          • U.S.
          Yes, recheck, doesn't make any sense unless those aren't the standby, maybe unplug the backlights from powerboard and see if those voltages come back??
          • garry7263
            • Feb 2013
            • 105
            Finally got around to checking again. Looking at the back of the board, that standby voltage must only come from the main board because there is nothing connected to it. Very short trace that leads to no components at all. So must be either the main board or the backlights. Will pull apart the screen and check them at least to eliminate them.
            • nomoresonys
              • 12307
              • U.S.
              "Obviously .107v is not enough to turn on the backlights" yep, that signal comes from the mainboard, good video on testing there: https://www.youtube.com/watch?v=ocqnqmBxiqY
              • R_J
                • Jun 2012
                • 9607
                The BL_ON/OFF and DIM on the power supply are used on this tv, the led driver board is controlled directly from the main board via CN805. It is not a simple ON/OFF signal, there are data signals that control the 14 led drivers. Check that you have DC (18V?) voltage on CN804 of the driver board.
                • nomoresonys
                  • 12307
                  • U.S.
                  Well is it a typo? "the BL_on/off and DIM ARE OR ARE NOT used??
                    This version of power supply board assembly does not have Backlights circuit, you can see that backlight section of the power supply board is not stuffed with parts, so this power supply board only supplies the running Voltage to the LED driver board, that is why the BL-ON/DIM control are not used on this power supply board, the main board controls the LED driver board directly.
                    • nomoresonys
                      • 12307
                      • U.S.
                      Thanks Bud.
                      • SS454
                        vizio e650i-a2 backlight flashes then turns off
                        by SS454
                        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                        panel: au optronics T650HVN05.4
                        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                        https://www.shopjimmy.com/vizio-56-0...-power-supply/
                        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                        08-20-2020, 03:57 PM
                      • BTubbs200
                        Dead Dell Latitude 5420 not receiving 20 volts from USB-C charger
                        by BTubbs200
                        Dell Latitude 5420 P137G
                        Board: LA-K491P REV A01
                        I have received this laptop which was described as "does not power on or accept charge." Battery shows no sign of charging when charger is plugged in, nor does the board show any signs of life when battery is unplugged and charger is plugged in. No light from the LED at all or any other indications of activity.
                        Board seems to have no shorts, all power rails are fine and show high resistance.
                        When charger is plugged in, voltage is present in 3.3V rail but absent in others....
                        01-24-2025, 08:15 PM
                      • Iain P
                        Vizio E65-F0 really dead
                        by Iain P
                        Hi everybody!
                        I've got a Vizio E65-F0 smart tv that is good and dead. It shows no signs of life when I press the power button on the back. The power LED in the lower right corner doesn't light, there is no backlight and no picture.
                        So I took the back off and started poking around figuring one or more of the caps had dried out. My esr meter says all the caps on the power supply board and the mainboard are less than 1 ohm.
                        I decided to check the voltages coming off the power supply they are as follows:
                        connector CN201
                        pin 1 (18vsb1)...
                        02-23-2023, 11:32 AM
                      • Nagyesz
                        Lenovo ideapad 330ICH - Dead, no volts on coils
                        by Nagyesz
                        Hi everyone, I replaced this motherboard because it was important to get it working, but it's been with me for a very long time. Now I finally have time to figure out what the problem is,
                        I've never encountered something like this before;
                        No charging light, full dead
                        Lenovo Ideapad 330-17ICH
                        • PL3102: 5 ohms
                        • PL3001: 3.2 ohms
                        • PL3101: 2 ohms
                        • PL5801: 3.5 ohms
                        • PL5501: 270 ohms
                        • PL701: 35 ohms
                        • PL501: 146 ohms
                        • PL503: 390 ohms
                        • PL402: OL (0.27V) +5VALW_P
                        • PL301: OL
                        • PL401: OL (0.03V) +3VALW_P
                        + Dc-in mosfet @PQ311 pin 5 20v, pin 1-4 0V , @PQ312 no volts...
                        10-11-2024, 10:12 AM
                      • Tynan Dill
                        by Tynan Dill
                        Assuming...
                        11-22-2024, 01:46 PM
