Vizio M43-C1 - How closely do I need to match the mainboard number?
+ More Options
Posts
  • Devonavar
    • Aug 2022
    • 5
    I have a Vizio M43-C1 stuck in a reboot loop with no backlight.
    I've tested all the voltage rails coming out of the power supply and they are "normal" for this model (PS_ON & DIM go high when turned on, BL_ON & 3D_ON are close to zero due to backlight power flowing through the mainboard, 5VSB is 5V, and 12V is 19V, which is apparently normal for this board).
    Basically, I get similar results to Garry in this post: https://www.badcaps.net/forum/showthread.php?t=80346
    So, I've ruled out the PSU for now.
    The reboot loop sounds pretty similar to this thread: https://www.badcaps.net/forum/showthread.php?p=1156275 . Basically, the front LED lights up bright and then fades down as usual, and then ~90 seconds later, it lights up bright again in a cycle. With so many other people reporting mainboard failures on this model due to overheating, I'm thinking mainboard failure is the likely cause.
    So ... what to do about it? I'd like to just order a new mainboard, but I can't find an exact match that is in stock, which makes me think I probably won't find one on a TV released in 2015.
    I've identified two different board numbers, and I'm trying to figure out how closely they need to match.
    There is a barcoded sticker that reads: (Q)XFCB0QK003040Q 1536
    And there is a board number etched onto the board itself: 715G7288-M02-000-005T
    I've managed to find a board that's in stock that matches the second number but not the first: https://www.tvpartstoday.com/756TXFC...fcb0qk0120.htm
    I'm guessing here, but would it be reasonable to assume that this is the correct piece of hardware (the number etched onto the PCB) with the wrong software / firmware (the number on the sticker)?
    The model number for this board is identified as M50-C1, which is just a larger version of my TV.
    So ... if I purchased this board and installed it in my TV, would it work? I'm hopeful that it would based on this this post: https://www.badcaps.net/forum/showpost.php?p=1132740 , where a user reported success installing a mainboard for a D50u-D1 in this model (though, he didn't identify the board number of the board he replaced).
    What would be the ramifications? I end up with a 43" TV that thinks it's 50"? Would this matter in any material way? Could I re-flash the firmware to the correct model? I'm assuming most of the relevant differences in the LCD logic, not the mainboard. Is this worth trying?
  • Devonavar
    • Aug 2022
    • 5
    Re: Vizio M43-C1 - How closely do I need to match the mainboard number?
    Option 2: If buying a mis-matched mainboard is a bad idea, I've found an eBay vendor that repairs this model of mainboard. https://www.ebay.com/itm/11483653602...cAAOSwOJ1gneEy It's a bit more expensive than option 1, but it comes recommended by someone else on this forum (shout out to @Neilc6!)
    I guess what I'm wondering is whether I can trust a random eBay vendor to do a real repair (presumably, a reflow / re-solder of the BGA that is beyond my amateur abilities) and not just do a toaster-over repair that will fail in weeks or months? Does anyone here have experience with this vendor (and maybe Neilc6 could chime in if he sees this)?
    • handsworth
      • Oct 2015
      • 174
      This guy has done 2 of the M50-C1 boards for me this year. No problems, fast turnaround.
      • nomoresonys
        • 12097
        • U.S.
        good option If they give a decent warranty.
        • maricm
          Vizio P65 with P55 mainboard
          by maricm
          IH all, Got this vizio tv P65-E1 from FB marketplace hoping to be able to reflow mainboard as selerrstated that it was diagnosed with bad mainboard. However they must have tried to repair tv by putting another board in and they put P55 board in .
          Tv starts and responds to remote but screen does not look right , It looks like low resolution with some image ghosting. Now not having original board I dont know what to order ? Any advice how to figure out what exact board fits this tv ?
          And another question Would it be possible to adopt this board to this tiv by chagning eeprom or tcon...
          04-23-2024, 08:25 AM
        • SS454
          vizio e650i-a2 backlight flashes then turns off
          by SS454
          vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
          panel: au optronics T650HVN05.4
          72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
          link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
          Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
          https://www.shopjimmy.com/vizio-56-0...-power-supply/
          Vizio 55.75J01.001G (91.75J10.004G) Main Board...
          08-20-2020, 03:57 PM
        • Mirenia
          Dell Latitude 7420 - Touchscreen not working since Mainboard replacement
          by Mirenia
          I've got a little "problem child": my Dell Latitude 7420 2-in-1, which had a faulty mainboard.
          I replaced it, but ever since, the touchscreen no longer works — and honestly, I’m running out of ideas…
          In Windows Device Manager, I just see an I2C HID Device with error code 10. Sporadically, the touchscreen is recognized correctly for just a few seconds, but I haven’t been able to determine under which circumstances this happens.
          The touchscreen also doesn’t work in UEFI/BIOS, although it’s enabled...
          03-30-2025, 06:47 AM
        • orcic
          MASTER TL240 and new mainboard LW36BKC01
          by orcic
          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
          Now I have some doubts about how to connect the new mainboard to the old power supply.
          First of...
          05-12-2023, 08:10 AM
        • Malva
          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
          by Malva
          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
          Mainboard model: EAX65684604
          PCB marking: EBT62954607
          SPI chip: Winbond W25X20CLNIG Problem description:
          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
          • I bought another
          06-25-2025, 02:07 PM
