Lenovo Thinkpad Ec Pwd Bypass
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1224
    • France
    #601
    Originally posted by judamex
    OMG Your post works! Thanks!
    i can change the SN thanks!
    https://www.badcaps.net/forum/troubl...17#post3542717
    • mazoot
      iFixit
      • Jan 2019
      • 41
      • Moldova
      #602
      Originally posted by Maxpower3
      What is the Lenovo utility for in this case?
      If there is no BIOS password, it has access to change the serial number!
      And it won't disable absolute because it's still active in bios?
      It won't disable,but if you change the serial and format ssd mdm is gone away
      Kill the state in yourself and you will be free like a wind...
      • Rainbow
        • Aug 2005
        • 1371
        #603
        Thanks for sharing this method, Maxpower3!
        I've just recovered two ThinkPads E14 Gen 1 (Intel) - NM-C421 board with IT8227E-256 EC.
        There's no debug connector on this board so I soldered a wire to unpopulated C0705 (LPC_AD3), which is conveniently located on the top side of the board. The other end of the wire is grounded through a tactile button.
        The correct moment to press the button is immediately after the Lenovo logo appears. If pressed too late, fan error will appear. I once got into SETUP with only the Config tab present - rebooted and retried and got full SETUP after a couple of tries.
        The 2nd machine had diagnostic screen enabled - no Lenovo logo. The correct moment in this case is after backlight comes on but before the diagnostic screen appears.
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1224
          • France
          #604
          Originally posted by Rainbow
          Thanks for sharing this method, Maxpower3!.
          Thanks for feedback
          • Usering
            • Sep 2024
            • 47
            Is there a solution for devices with
            mec1503 and mec1723 ?
            • rex98
              • Feb 2023
              • 1273
              • Mandaue CEBU, Philippines
              #606
              thinkpad E15 Gen 4
              SVP offset_0003adf0 to 0003aedb
              ITE_nm-e211
              tested
              • Maxpower3
                Bad Veteran
                • Feb 2018
                • 1224
                • France
                #607
                Originally posted by rex98
                thinkpad E15 Gen 4
                ITE_nm-e211
                tested
                did you need the lenovo utility afterwards for the numbers?
                or no error​
                • rex98
                  • Feb 2023
                  • 1273
                  #608
                  or no error​
                  not it doesn't have any error i tested it.
                  • wraster
                    • Jan 2025
                    • 18
                    Originally posted by volinakis
                    Maxpower3
                    I confirm your genius method is working for T14 gen 1 AMD GT4A1 NM-C801 rev.1.0 Thank you very much!
                    volinakis Are you up for sharing a picture of the part of the board that you shorted? I am confused because the ITE IT5261 on mine has some kind of covering-looking thing over it and the pins are not visible. Do you have to use the other side of the board? Or am I looking at the wrong part? Thank you!
                    • black0hackers
                      • Jul 2020
                      • 365
                      P1 Gen 6,
                      Boad code : LCH-3 P MB 223027-1 448 OSR04 0011
                      IO name is NPCX997
                      this one can read? @Maxpower3​?
                      • volinakis
                        • Jan 2021
                        • 2728
                        • N/A
                        #611
                        marked part to ground, as Maxpower3 instructions
                        • alexrockzill
                          • Jan 2025
                          • Sweden
                          #612
                          Hi all! First of all I’d like to express my gratitude and appreciation to Maxpower3 for the shorting method which helped me to remove SVP from my T14 Gen1 Intel based laptop. Everything went smoothly - I shorted one of the required pins to ground, disabled SVP and cleaned the security chip (a couple of times) and rebooted by ctrl alt delete. Password is gone. But i stii get the 2204 Error after rebooting from Windows. I tried reinstalling Windows, that didn’t help. I used Lenovo Utility flash drive, initialised the EEPROM, rewritten all S/Ns and other ids to EEPROM. But that didn’t help as well. I disconnected cmos and main batteries and tried again - same error. Does anyone know what I can do about it? I have a suspicion that it throws this error because I am disabling Security Boot in the Bios settings. I need it to be disabled for Linux installation. I attached some photos of the errors I get. Is there a way to solve this issue? Thanks in advance for your help, it is highly appreciated!
                          • Mahesa09
                            • Nov 2021
                            • 63
                            • jakarta
                            #613
                            does anyone have success on l14 g2 HL4A0/HL5A0 NM D271
                            • Maxpower3
                              Bad Veteran
                              • Feb 2018
                              • 1224
                              • France
                              #614
                              Originally posted by alexrockzill
                              Hi all! First of all I'd like to express my gratitude and appreciation to Maxpower3 for the shorting method which helped me to remove SVP from my T14 Gen1 Intel based laptop. Everything went smoothly - I shorted one of the required pins to ground, disabled SVP and cleaned the security chip (a couple of times) and rebooted by ctrl alt delete. Password is gone. But i stii get the 2204 Error after rebooting from Windows. I tried reinstalling Windows, that didn't help. I used Lenovo Utility flash drive, initialised the EEPROM, rewritten all S/Ns and other ids to EEPROM. But that didn't help as well. I disconnected cmos and main batteries and tried again - same error. Does anyone know what I can do about it? I have a suspicion that it throws this error because I am disabling Security Boot in the Bios settings. I need it to be disabled for Linux installation. I attached some photos of the errors I get. Is there a way to solve this issue? Thanks in advance for your help, it is highly appreciated!
                              post 11
                              https://www.badcaps.net/forum/troubl...02#post1711774
                              post 3153
                              https://www.badcaps.net/forum/troubl...58#post3243817
                              • Mahesa09
                                • Nov 2021
                                • 63
                                • jakarta
                                #615
                                hy max, why not work to l14 g2 HL4A0/HL5A0 NM D271
                                • Maxpower3
                                  Bad Veteran
                                  • Feb 2018
                                  • 1224
                                  • France
                                  #616
                                  you're talking about my video L13 Gen2, you left a comment??
                                  at the beginning for the suspense, I didn't show,
                                  I did with switch
                                  • Laptop@Expert
                                    • Jan 2023
                                    • 6
                                    • pakistan
                                    #617
                                    Please unlock NM-C801 ITE 256KB
                                  • adamgouadma
                                    • Jul 2017
                                    • 183
                                    • setif
                                    #618
                                    When I read the EC Thinkpad p15 GEN1 read it, I found it empty inside
                                    What to do
                                      SMDFlea commented
                                      Editing a comment
                                      Off topic, post in the P15 Gen 1 thread topic.
                                    • 20781
                                    Originally posted by black0hackers
                                    hi. how to update to new version 0.5?
                                    Off topic, lets get this Lenovo Thinkpad Ec Pwd Bypass thread back on topic
                                    • Maxpower3
                                      Bad Veteran
                                      • Feb 2018
                                      • 1224
                                      • France
                                      #620
                                      sorry, it's me who started it, Possible to move all the off-topic posts into a new therad SVod info and problem
                                        Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                        This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                        09-06-2024, 11:40 AM
