Lenovo Thinkpad Ec Pwd Bypass
  • Usering
    • Sep 2024
    • 50
    Originally posted by rediii
    this is strange, too. i tried it like 100 times and nothing died (t15 gen 2).
    nm-d362 io mec1503 (short ESPI inside CPU)
    nm-981 io npcx997
    (short 3V PCH inside CPU)
    • Usering
      • Sep 2024
      • 50
      Originally posted by Andreasbest
      One day we will manage to remove pass from MEC1503 too, for example right now we know there is 2kb rom on it that writes all data (serial, model, bios pw) everytime the laptop posts. One day someone will manage find a workaround on it too.
      It may be difficult, Lenovo ThinkPad will work on protection like MacBook, M1 M2 M3, no solution
      • Andreasbest
        • Aug 2014
        • 1195
        • Hellas ( Greece )
        #383
        the data won't be rewritten with every post, that's wrong. the 2 kb eeprom information is not stored in the bios but only in the mec.
        I'm not deep in programming, i read only what others, much skilled than me are saying ↓
        Originally posted by azanwaqas771
        It's PROGRAMMBLE but MEC1503 SRAM-based nature. It's not a rom. So you can't program from programmer. Mec1503 collect data from main bios when power on. • SRAM is volatile memory, which means it does not retain data when the power is turned off.
        • Andreasbest
          • Aug 2014
          • 1195
          • Hellas ( Greece )
          #384
          Life have show me that eventually everything cracks or bypass somehow, for example before 3 days someone managed to decrypt the Hypervisor of PS5, a task that before some years seemed impossible.
          One day this will crack too.
          Problem with Mac is other, you can't bypass iCloud lock because laptop must connect to Apple servers and download ticket with decryption to work 100%, perhaps one day we will manage to bypass it but Apple services will not work.
          Except if someone cracks the encryption but that's very unlikely to happen.
          • rediii
            h???, spurrrn
            • Mar 2018
            • 498
            • somewhere in europe
            #385
            this is nonsense.
            • Stefan Steff
              • Mar 2024
              • 327
              • Romania
              #386
              this is nonsense.
              Right...
              MEC1503
              Flash : 16384 kB
              Flash bank : 0x1000000 Bytes @ 0x60000000
              RAM : 224 kB
              RAM : 0x00038000 Bytes @ 0x00038000
              Architecture : Cortex-M4
              • ibo
                • Oct 2019
                • 95
                • Turkiye
                #387
                Originally posted by Stefan Steff
                Right...
                MEC1503
                Flash : 16384 kB
                RAM : 224 kB
                So you can read the chip?
                • Usering
                  • Sep 2024
                  • 50
                  The new and upcoming generation, the userdata information will be inside the CPU, and until now no one has been able to decode the access to the CPU via JTAG, also the microchip is used on the MEC1723 chip, the stubborn Cortex processor, it is not possible to enter or pass to the EEPROM chip except with commands and key Checksum , each kbc chip and each spi rom image , And also lock the jtag port, This is good for protecting people's information, and killing help computer thieves.
                  • Stefan Steff
                    • Mar 2024
                    • 327
                    • Romania
                    #389
                    No my friend...I don't know anyone who did that.
                    Readed somewhere that the swapping method is the only way ro get rid of the password on this models.
                    • arestlessknight
                      • Jul 2024
                      • 11
                      Well it's known that it can be done but with programmer.
                      If you have many Lenovo with eSPI then it's worth it to buy a SVOD programmer and do it your self.
                      Hello again,
                      does this apply to the T14 Gen. 3 AMD laptop's as well?
                      If so do you know where I might find more information on reprogramming the npcx997?
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 498
                        #391
                        Originally posted by arestlessknight
                        Hello again,
                        impossible atm.
                        • Usering
                          • Sep 2024
                          • 50
                          Hello again,
                          Risk
                          Devices with ESPI Protocol, IO Mec1503 , Mec1723 , NPCX997 (do not work in LPC Method , can burn and short CPU).
                          • arestlessknight
                            • Jul 2024
                            • 11
                            impossible atm.
                            Impossible for this method or in general?
                            I can get some of these npcx977 ICs pre-flashed for a thinkpad motherboard.
                            Would a chip swap work (I understand that it's not the easiest solder job)?
                            • rediii
                              h???, spurrrn
                              • Mar 2018
                              • 498
                              #394
                              it works neither via the espi nor via programming (as currently no programmer can communicate with the chip in such a way that it can be read or written to). it is possible to exchange it, of course. the problem here is probably most likely to remove the sealing cleanly. as is well known, lenovo has not done itself any favours in terms of ease of repair.
                              • arestlessknight
                                • Jul 2024
                                • 11
                                Ah, okay. I will likely take the latter route then.
                                Just for the sake of curiosity, does the Nuvoton (Nu-Link2-Pro) programmer not work with the npcx997 either? I'm surprised that these chips cannot even be read from.
                                • rediii
                                  h???, spurrrn
                                  • Mar 2018
                                  • 498
                                  #396
                                  that's a good question, but reading and writing the ec flash while the chip is ON the mainboard is not possible as far as i know (the same applies to npcx797). however, this refers more explicitly to the programmer successor and svod4.
                                  • arestlessknight
                                    • Jul 2024
                                    • 11
                                    Ah okay. So regardless, desoldering is currently a must (as far as anyone is aware at least). Thank you for all of the valuable info rediii.
                                    • rediii
                                      h???, spurrrn
                                      • Mar 2018
                                      • 498
                                      #398
                                      thank you. i would appreciate a feedback, after you did the soldering job.
                                      • Andreasbest
                                        • Aug 2014
                                        • 1195
                                        • Hellas ( Greece )
                                        #399
                                        Anyone knows what EC is on NM-C881 ( Lenovo ThinkPad X1 Carbon 8th Gen ) ?
                                        • Maxpower3
                                          Bad Veteran
                                          • Feb 2018
                                          • 1314
                                          • France
                                          #400
                                          Originally posted by didouche1200
                                          Re: mec 16xx dump with info block
                                          how to read mec1663 with vetyanov ihave nm-c881 motherbord thanks
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
