Lenovo Thinkpad Ec Pwd Bypass
  • santoslao
    • Apr 2017
    • 94
    • BZ
    #361
    Originally posted by rediii
    this is no proof for me, sry. i doubt it. i once went to the trouble of unlocking a locked t15 g2 by replacing the mec1503.
    Yes, I heard that changing the MEC1503 works, can you tell me where you bought it? Has it already come programed?
    • anhbanxoi
      • Sep 2021
      • 168
      • VN
      #362
      Base on datasheet there is 2KB ROM inside which is used to store password and other informations like serial number, model, .... You can use lenovo tool to dump this rom content but cannot reach the part that store password.
      • system_fans
        • Sep 2023
        • 8
        • china
        #363
        Thank you for sharing, you are a tech gurus
        • rediii
          h???, spurrrn
          • Mar 2018
          • 485
          • somewhere in europe
          #364
          i harvested one from a dead board.
          • rediii
            h???, spurrrn
            • Mar 2018
            • 485
            #365
            exactly that's the point.
            • kouider
              • Sep 2023
              • 10
              • Maroc
              #366
              I have found on one Russian Website that they are able to read the chip, but only if desoldered if i understood that correctly
              https://mslw.com/bb/showthread.php?t...c1503#pid97749
              • kouider
                • Sep 2023
                • 10
                • Maroc
                #367
                they are also able to read NPCX797 and NPCX997 chip:
                https://mslw.com/bb/showthread.php?t...cx797#pid94250
                • anhbanxoi
                  • Sep 2021
                  • 168
                  • VN
                  #368
                  MEC1503 you can buy it on aliexpress. Just replace it and rewrite serial number, product id with Lenovo tool.
                  • Usering
                    • Sep 2024
                    • 43
                    Share experience
                    1)
                    very Risk method lpc on espi board
                    killed 2 laptop cpu short
                    nm-d362 io mec1503
                    nm-981 io npcx997
                    I would have made a little money, now I would have paid over $500 for the board on aliexpress .
                    2)
                    regarding changing the chip, you must be a professional because the chip is glued from the inside with a black substance that can spoil the welding place and also the source of purchasing the chip.
                    • Kind_Drop
                      • Aug 2024
                      • 5
                      • United states
                      #370
                      Have you tested this method on P53s 20N6 Serial number PF292CDY? I can't find the schematics for this motherboard, and it seems different from the P53.
                      • rediii
                        h???, spurrrn
                        • Mar 2018
                        • 485
                        #371
                        same like these:
                        T490, T590, P43s - NM-B901
                        • Needthinkpad
                          • Sep 2024
                          I'm not familiar with by passing bios password but I've a x13 gen 1 intel and it is locked, but I don't know what you doing in the video or what I need to do. I've only understood that it's necessary to to stick a screwdriver in it.
                          • jagadish
                            • Aug 2015
                            • 14
                            • india
                            #373
                            Originally posted by Maxpower3
                            1 wire to ground on one of the points following 1 or 128/127/126 of your choice
                            at startup as indicated in previous posts
                            EC : NPCE68AP
                            L14/L15 gen1 GL40-GL5A0 NM-C631
                            of course, check that the diagram matches
                            Click image for larger version Name:	Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631.jpg Views:	0 Size:	372.8 KB ID:	3259076
                            Click image for larger version  Name:	Thinkpad GL40-GL5A0 NM-C631.jpg Views:	1730 Size:	286.4 KB ID:	3259090
                            Click image for larger version  Name:	Thinkpad L14 GEN 1  GL40-GL5A0 NM-C631.jpg Views:	1736 Size:	44.5 KB ID:	3259091
                            Who has now used this technique and is satisfied with it here ??
                            just to give some feedback
                            sir I am satisfied with this unique technique thanks lot maxpower I tried on NM-D422 T14 Gen2 Amd IT5679VG
                            • jagadish
                              • Aug 2015
                              • 14
                              • india
                              #374
                              Originally posted by Andreasbest
                              hach
                              santoslao
                              Hello.
                              Both of you must find schematics and search for words "LAD" and "eSPI"
                              If you found "LAD" is possible
                              If you found "eSPI" is not possible.
                              DEAR Andreasbest I found "ESPI' in NM-D422 it work fine and it is possible , 100% work 😊
                              • Andreasbest
                                • Aug 2014
                                • 1138
                                • Hellas ( Greece )
                                #375
                                Yes because it's LAD too.
                                If you found only eSPI it won't work
                                • rediii
                                  h???, spurrrn
                                  • Mar 2018
                                  • 485
                                  #376
                                  shorting espi doesn't work, andreasbest is right... mec1503 and mec1723 will never be supported i guess (jtag interface). the jtag interface is software locked.
                                  • Usering
                                    • Sep 2024
                                    • 43
                                    LAD working
                                    eSPI don't working (After several attempts, the processor shorted died )
                                    • Andreasbest
                                      • Aug 2014
                                      • 1138
                                      • Hellas ( Greece )
                                      #378
                                      One day we will manage to remove pass from MEC1503 too, for example right now we know there is 2kb rom on it that writes all data (serial, model, bios pw) everytime the laptop posts. One day someone will manage find a workaround on it too.
                                      • rediii
                                        h???, spurrrn
                                        • Mar 2018
                                        • 485
                                        #379
                                        Originally posted by Usering
                                        LAD working
                                        this is strange, too. i tried it like 100 times and nothing died (t15 gen 2).
                                        • rediii
                                          h???, spurrrn
                                          • Mar 2018
                                          • 485
                                          #380
                                          the data won't be rewritten with every post, that's wrong. the 2 kb eeprom information is not stored in the bios but only in the mec.
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
