Dell n5010 can be converted from graphic version to non graphic
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    #81
    Re: Dell n5010 can be converted from graphic version to non graphic
    Originally posted by t34v2
    No it is not. You have to follow 4-photo method to get it working
    But i couldn't find any components like those 4 photos show on Dell inspiron N5110.
    • reddemonic
      • Jun 2015
      • 42
      damn, would be nice if we can do this on macbooks.
      • haritvr
        • Nov 2016
        • 22
        • India
        #83
        U want to remove the GPU chip then display I'll ok
        • raajkumar
          • Mar 2015
          • 354
          • Srilanka
          #84
          Do you think about Dell inspiron N5110 ?
          • haritvr
            • Nov 2016
            • 22
            • India
            #85
            Yes sir GPU and that sup ic and coil and cap and fet these are removed then DSP I'll ok
            • imranromi
              • Jan 2015
              • 1288
              • Pakistan
              #86
              yes i success convert to graphic to non graphic dell n5010. No need to remove graphic chip.
              last time i convert to non grahic little mistake display white but no data today i success.
              • haritvr
                • Nov 2016
                • 22
                • India
                #87
                Dear sir Some component not mentioned on the board for exm graphics ram ic and some one smd component also missed so
                • raajkumar
                  • Mar 2015
                  • 354
                  • Srilanka
                  #88
                  How did you success it. Can you explain it ?
                  • vickey_vip
                    • Mar 2016
                    • 134
                    • India
                    #89
                    I successful do it on my motherboard which part no is following
                    09909-1
                    DG15
                    48.4HH01.011
                    DO THE FOLLOWING CHANGES WHICH I POSTING IN IMAGES
                    FOR THOSE WHO HAVE WHITE DISPLAY FOLLOW INSTRUCTION WHICH SHOWN IN PICTURE
                    if any one have issue msg me
                    • oxonater
                      • Oct 2012
                      • 77
                      #90
                      Hi guys sorry to ask a noob question but looking for the 2.2k resistor in the 4 picture method but don't a[[ear to be able to locate please help!!!!!!1
                      many thanks in advance
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        #91
                        For the guys who couldn't be succesfull of doing this conversion by following the guide, at the 8th pic. of vickey_vip's message, marked with "D point" is the missing element. remove q5702 from its place which is near speaker-mic jacks. Solder it to D point.
                        • oxonater
                          • Oct 2012
                          • 77
                          #92
                          Hi thank you for your reply
                          I have since found this missing part by searching the net for a solution to my problem as there is various different guides.
                          The problem I have at the moment is my N5010 is beeping at me with a blank screen 3 beeps to be precise. I press the power button a few times and a white screen is present then press power button again and it returns to blank. Noticed the power button does not actually turn off when pressed it kind of blinks only way to switch off is remove power supply.
                          The only difference I have done to the previous guide is remove the IC near Northbridge chip (still has a cap were a 0 ohm resistor is on some boards).
                          Also coil and Mosfet and another IC left side of the GPU which is also removed.
                          3 beeps are noted as being related to the following :-
                          ◾chipset Error (North and South bridge error, DMA/IMR/Timer error)
                          ◾Time-Of-Day Clock test failure
                          ◾Gate A20 failure
                          ◾Super I/O chip failure
                          ◾Keyboard controller test failure
                          Thing beeps regardless if it has RAM,CPU, or nothing at all, confused I AM.
                          Any help on this issue would be greatly appreciated many thanks in advance OXY
                          • oxonater
                            • Oct 2012
                            • 77
                            #93
                            Hi yes it did have that gpu which has since been removed.
                            Just wondered my version board has the 4 VRAM chips, I have seen in earlier posts about placing 2 12p 50v resonator smd caps. Please if someone could clarify if these are needed.
                            There is lots of different guides out there to pinpoint one that is specific to my board Rev is difficult and somewhat confusing.
                            Many thanks for replies
                            • ktmmotocross
                              Boardkiller
                              • Feb 2014
                              • 3609
                              • slovakia
                              #94
                              i see more boards with bad NB balls than with GPU balls/ATI/. so u must double chceck, what ic have bad connection.
                              more when u have NB and GPU close
                              • ahmed33essawy
                                • Jul 2017
                                • 5
                                • egypt
                                #95
                                Originally posted by ibrahim03
                                is there anything new ?
                                hi ibrahim there some note
                                1- there are resistor rn2002 2700 ohm code (272) if u didnt find this use 4700 ohm code of it(472)
                                2- use crystal 25x under it 2 capstor under them and betwen them use res 1mega code of it (01c) or(105) or (1004)
                                i do it and work great
                                and follow the chines pdf
                                good luck
                                • GULSHAN SARWA
                                  • Dec 2015
                                  • india
                                  #96
                                  Originally posted by vickey_vip
                                  i successful do it on my motherboard which part no is following
                                  09909-1
                                  dg15
                                  48.4hh01.011
                                  do the following changes which i posting in images
                                  for those who have white display follow instruction which shown in picture
                                  still problem are same ,,, white display pls reply
                                  • vickey_vip
                                    • Mar 2016
                                    • 134
                                    • India
                                    #97
                                    Anyone who get white display or Blank screen check below two solution if you get white display only backlight then remove any cap under Intel VGA which is placed under 1 mega ohm resistor and if you get black display with backlight mean no data or character showing on screen then you must check R2603 (0 Ohms resistance) is there you put or not. If you forget to add this reg. Then you not get any data on screen I am attaching picture of that location. Today I successfully convert another motherboard of dell using my previous posting image method
                                    • barkinaksoy
                                      • 3
                                      • POLAND
                                      #98
                                      09909-1
                                      DG15
                                      48.4HH01.011
                                      Hello
                                      I am tring this method but i think there is missed page. Could you help me please ..
                                      • vickey_vip
                                        • Mar 2016
                                        • 134
                                        • India
                                        #99
                                        Originally posted by barkinaksoy
                                        Hello
                                        Yes bro tell me what problem you facing
                                        • kitsaras
                                          • Apr 2017
                                          • 4
                                          • greece
                                          #100
                                          Hi. I follow all the steps from vickey_vip but when i press the power button the screen flashes like is go to open and then get's again black.
                                          Note: I have removed the BGA chip and all the rams if there is any problem?
                                          Regards.
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • minaedward
                                            Dell N5010 keyboard
                                            by minaedward
                                            Hi all
                                            I have a dell n5010 that shows black screen after the dell logo and freezes
                                            But when I remove the keyboard it works fine and boot the windows
                                            The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
                                            But after the dell logo it causes the laptop to freeze
                                            Any ideas why ?
                                            09-29-2024, 05:24 PM
                                          • sahamipoor
                                            how to Set graphic Discrete mode motherboard(no UMA) Dell XPS L502x - DAGM6CMB8D0
                                            by sahamipoor
                                            hello...
                                            the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
                                            i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
                                            according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
                                            1- EXT_LCD_PWM no voltage to enable pwm
                                            2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
                                            and screen is turn off and fan is high Speed!!
                                            Question:
                                            I need to Use Discrete graphic nvidia EXT_LCD ports...
                                            03-12-2024, 02:51 AM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
                                          • F R 2568
                                            Dell Latitude 5420 does not start (no post) need help to find the reason why
                                            by F R 2568
                                            Hello all,
                                            this is my first post, so if I make mistakes please do not hesitate to point them out, thank you in advance.
                                            I got a Dell Latitude 5420 (Service Tag: 7RFM6D3, Motherboard: GDF40 LA-491P Rev.: 2.0 (A01)) which does not start and I want to repair it. These are the symptoms:
                                            If the laptop is only connected to the AC adapter (battery removed):
                                            When I press the power button, the keyboard backlight and the display backlight are turning on. Caps key light is lightning, but key does not respond to pressing it.
                                            The power/battery...
                                            01-08-2025, 05:45 AM
