  • master3112
    • Mar 2024
    • 132
    • Slovakia
    The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type YRDD6, 11.4V and original Dell 65W power supply PA-12, model: LA65NS2-01. At pin 4 ( PS_ID_R) of the DCIN connector are 3.3V present. Normally it should be okay. Since there is a lot of discussion in the forums about the Dell power supply recognition problem, I ordered a new power supply first. I wanted to make sure that it wasn't the power supply unit. In fact, it was the best decision because it worked with the new power supply unit. However, with the new power supply I also have 3.3V on pin 4 of the DCIN connector . Can someone explain to me how the Dell power supply detection works? How can the signal be measured?
    Thanks to the Tech community
  • m1ch43lzm
    • Mar 2019
    • 2489
    • Peru
    Dell uses a 1-wire EEPROM inside the AC adapter to determine the power rating, you'll need an oscilloscope or logic analyzer
    Check if the middle pin on the non working AC adapter isn't damaged, the cable may also be broken on the inside
    Here's more detailed info
    https://hclxing.wordpress.com/2014/0...power-adapter/
    https://github.com/KivApple/dell-charger-emulator
