Dell n5010 can be converted from graphic version to non graphic
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    #121
    Re: Dell n5010 can be converted from graphic version to non graphic
    correction: Compared to the time of Discrete graphics, now that PCH has additional voltages for graphics such as 3.3v and 1.8v, it gets about 20 degrees hotter, so that it reaches about 60'C.
    Does anyone know what is defective in this laptop?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      #122
      @caspian, i asked for good quality images of both sides of your converted mb which you didnt posted. Yes, PCH will be slightly more warmer and there is nothing wrong with that. No need to change bios-the original discrete bios works like charm after conversion.
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        #123
        thanks for your reply,
        I do not have a good camera to take big photos of the mainboard.
        I have used various versions of Bios and EC, but no signal changes in the mainboard. All the soldering that I did are OK according to the photos of Post#110. So, I do not know what to do next.
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          #124
          the good news is that the laptop can be restarted well by pressing Alt-Ctrl-Del using a USB keyboard. but it has still black screen.
          Do you think the GFX section of PCH or CPU is defective?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            #125
            It is difficult to say without having a look at the converted images. If you have a smartphone, you can take pics and upload. However, though it can be bad pch but i still beleive its some mistake in conversion process. I too faced issues while converting this mb at first attempt but now i've converted more then 50 mb's and they work perfectly. Btw, did you jumpered the marked area after scraping paint inside the cpu socket(TOP side??
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              #126
              Another important thing to check is those RN(8pins). Sometime there can be some residual solder between two adjacent pins on both top and bottom side. Re check RN2002 and point marked as B/C/D in image from dr bios.
              • caspian
                • Oct 2015
                • 1591
                • Laptop
                #127
                Finally, I fixed it. Thanks @mcplslg123.
                you were right. one of the resistors were bad. but something strange happened that I could not predict: one of the 0-Ohm resistors in a resistor array turned into a 200KOhm resistor. it happened probably due to extra soldering heat or due to the fact that the resistor array was taken from a donor mainboard.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #128
                  Congrats bro
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    #129
                    Update: The conversion that I did is successful. Windows8 boots successfully.
                    But now the PCH gets too hot about 80'C after a few minutes of using the laptop, even though I installed a heatsink on the PCH. Windows8 works slower than normal.
                    Sometimes the laptop boots fine, but sometimes it has black screen randomly.
                    Does anybody know what is wrong in this Dell 5010?
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #130
                      I never installed heatsink on pch on this mb after conversion and they are running for almost 1 year+. PCh do gets a liitle hot in this platform.
                      • caspian
                        • Oct 2015
                        • 1591
                        • Laptop
                        #131
                        The PCH does not get hot instantly. If there is a heatsink on the PCH, then it takes about 5 minutes to get hot to about 80'C. LCD backlight has a bit of flickering sometimes randomly.
                        What do you guess is wrong?
                        • caspian
                          • Oct 2015
                          • 1591
                          • Laptop
                          #132
                          The +1.8v power is 1.78v and the 1.05v power is 1.044v.
                          The +1.8v power is 209 Ohms and the 1.05v power is 10 Ohms.
                          CPU_vcore is 1.1v and 50 Ohms.
                          There is some power linkage to Ground so that I feel some electricity when I touch Ground by my finger on the mainboard.
                          Do these symptoms mean the PCH is defective or half-shorted?
                          • caspian
                            • Oct 2015
                            • 1591
                            • Laptop
                            #133
                            The power leakage to GND disappeared today. PCH gets hot about 80'C with heatsink.
                            is this temperature ok if I leave it like this?
                            are the above voltage and resistance values ok?
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              #134
                              Yes. All is well
                              • lapfix
                                • Mar 2020
                                • 2756
                                • my workshop
                                #135
                                Done without any problem , but the external didn't work VGA and HDMI..any idea!
                                • caspian
                                  • Oct 2015
                                  • 1591
                                  • Laptop
                                  #136
                                  Enabling intel graphics on VGA and HDMI needs an additional number of component soldering/replacement. Considering the facts that the Dell-5010 laptop is old and we cannot spend more time on this laptop, technicians usually refuse to enable intel graphics on VGA and HDMI on Dell 5010.
                                  • lapfix
                                    • Mar 2020
                                    • 2756
                                    • my workshop
                                    #137
                                    Thank you caspian
                                    • elwess93
                                      • Jan 2021
                                      • 7
                                      • tunisia
                                      #138
                                      Originally posted by vektro
                                      Hello friend,
                                      recently i converted an N5010 board using Dr. Bios way.
                                      It works only for laptop's display, not HDMI's or VGA's outputs.
                                      Now i am trying to resolve this too.
                                      Check the attachment.
                                      hello!
                                      i'm kinda new to this but i want to try the method you mentioned. can you please help me: there are some letters with yellow square but dont say what must be added. thanks in advance.
                                      • elwess93
                                        • Jan 2021
                                        • 7
                                        • tunisia
                                        #139
                                        Hello friend,
                                        and it says remove green shild of pcb and connect that to near capacitor pin, i didnt understand that too
                                        thanks
                                        • stingerchamp
                                          • Sep 2020
                                          • 425
                                          • Pakistan
                                          #140
                                          In short
                                          You have to remove connection from GPU and move it towards PCH
                                          If hdmi is directly interacted with PCH then no need
                                          Otherwise change clock signal change display control etc
                                          Additional you need Uma bios
                                          • Bowline
                                            by Bowline
                                            06-11-2025, 10:13 AM
                                          • minaedward
                                            Dell N5010 keyboard
                                            by minaedward
                                            Hi all
                                            I have a dell n5010 that shows black screen after the dell logo and freezes
                                            But when I remove the keyboard it works fine and boot the windows
                                            The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
                                            But after the dell logo it causes the laptop to freeze
                                            Any ideas why ?
                                            09-29-2024, 05:24 PM
                                          • sahamipoor
                                            how to Set graphic Discrete mode motherboard(no UMA) Dell XPS L502x - DAGM6CMB8D0
                                            by sahamipoor
                                            hello...
                                            the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
                                            i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
                                            according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
                                            1- EXT_LCD_PWM no voltage to enable pwm
                                            2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
                                            and screen is turn off and fan is high Speed!!
                                            Question:
                                            I need to Use Discrete graphic nvidia EXT_LCD ports...
                                            03-12-2024, 02:51 AM
                                          • Akhlz001
                                            by Akhlz001
                                            09-20-2025, 07:15 PM
                                          • master3112
                                            by master3112
                                            07-29-2025, 01:55 PM
