Dell n5010 can be converted from graphic version to non graphic
Re: Dell n5010 can be converted from graphic version to non graphic
damn, would be nice if we can do this on macbooks.Comment
yes i success convert to graphic to non graphic dell n5010. No need to remove graphic chip.
last time i convert to non grahic little mistake display white but no data today i success.Last edited by imranromi; 11-24-2016, 05:45 AM.Comment
How did you success it. Can you explain it ?Comment
I successful do it on my motherboard which part no is following
09909-1
DG15
48.4HH01.011
DO THE FOLLOWING CHANGES WHICH I POSTING IN IMAGES
FOR THOSE WHO HAVE WHITE DISPLAY FOLLOW INSTRUCTION WHICH SHOWN IN PICTURE
if any one have issue msg me
Attached Filesif you find these attachements useful please consider making a small donation to the site
For the guys who couldn't be succesfull of doing this conversion by following the guide, at the 8th pic. of vickey_vip's message, marked with "D point" is the missing element. remove q5702 from its place which is near speaker-mic jacks. Solder it to D point.Comment
Hi thank you for your reply
I have since found this missing part by searching the net for a solution to my problem as there is various different guides.
The problem I have at the moment is my N5010 is beeping at me with a blank screen 3 beeps to be precise. I press the power button a few times and a white screen is present then press power button again and it returns to blank. Noticed the power button does not actually turn off when pressed it kind of blinks only way to switch off is remove power supply.
The only difference I have done to the previous guide is remove the IC near Northbridge chip (still has a cap were a 0 ohm resistor is on some boards).
Also coil and Mosfet and another IC left side of the GPU which is also removed.
3 beeps are noted as being related to the following :-
◾chipset Error (North and South bridge error, DMA/IMR/Timer error)
◾Time-Of-Day Clock test failure
◾Gate A20 failure
◾Super I/O chip failure
◾Keyboard controller test failure
Thing beeps regardless if it has RAM,CPU, or nothing at all, confused I AM.
Any help on this issue would be greatly appreciated many thanks in advance OXY
Hi yes it did have that gpu which has since been removed.
Just wondered my version board has the 4 VRAM chips, I have seen in earlier posts about placing 2 12p 50v resonator smd caps. Please if someone could clarify if these are needed.
There is lots of different guides out there to pinpoint one that is specific to my board Rev is difficult and somewhat confusing.
Many thanks for repliesComment
i see more boards with bad NB balls than with GPU balls/ATI/. so u must double chceck, what ic have bad connection.
more when u have NB and GPU closeComment
hi ibrahim there some note
1- there are resistor rn2002 2700 ohm code (272) if u didnt find this use 4700 ohm code of it(472)
2- use crystal 25x under it 2 capstor under them and betwen them use res 1mega code of it (01c) or(105) or (1004)
i do it and work great
and follow the chines pdf
good luckComment
still problem are same ,,, white display pls replyComment
Anyone who get white display or Blank screen check below two solution if you get white display only backlight then remove any cap under Intel VGA which is placed under 1 mega ohm resistor and if you get black display with backlight mean no data or character showing on screen then you must check R2603 (0 Ohms resistance) is there you put or not. If you forget to add this reg. Then you not get any data on screen I am attaching picture of that location. Today I successfully convert another motherboard of dell using my previous posting image methodAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello
I am tring this method but i think there is missed page. Could you help me please ..Comment
Hi. I follow all the steps from vickey_vip but when i press the power button the screen flashes like is go to open and then get's again black.
Note: I have removed the BGA chip and all the rams if there is any problem?
Regards.Comment
by BowlineMy question pertains to understanding the control circuity inside a Dell PT434 type battery used in Dell E6400, E6410 and other Dell notebooks?
I have tried multiple different Dell power adapters. My Dell... -
by minaedwardHi all
I have a dell n5010 that shows black screen after the dell logo and freezes
But when I remove the keyboard it works fine and boot the windows
The keyboard is working as I can press F1 and F2 and inter the bios settings and change it
But after the dell logo it causes the laptop to freeze
Any ideas why ? -
by sahamipoorhello...
the Dell XPS L502x ( Model P11F ) [ DAGM6CMB8D0 rev.D ..3 of lines output LVDS from PCH has short ohm(0 -70) than LCD displat turn ON but is white !!!
i decide to change LVDS ports to Lcd from EXT_LCD graphic Studio Discrete to No need it LVDS lines of PCH use...
according to ُSchematic ,I changed any resistor and... Config_0 and Config_1 EC...but:
1- EXT_LCD_PWM no voltage to enable pwm
2-EXT_LVDS_VDDEN no High to Enable LCD_vcc
and screen is turn off and fan is high Speed!!
Question:
I need to Use Discrete graphic nvidia EXT_LCD ports... -
by Akhlz001Hi,
Could someone help trying to unlock this BIOS, seems that Dell have changed the layout of new Dell Pro 8FC8 bioses from checking HXD - 4000 bits do not need changing, only 2000. However after FF the section starting from '01000' upto 2000 bits and then soldering the chip back it seems that the microchip on the motherboard is recovering the bios back to original settings after first boot. Has anyone found a way to crack this extra layer of security Dell have implemented? Seems both HP and Dell have upped bios security to match Lenovo by implementing extra measures on a separate...-
Channel: BIOS Requests ONLY!
by master3112I would like to share my experience about charging issues with Dell power supplies with the tech community. I am working on a Dell Inspiron 5590, Mainboard 18778-1 with charging problems. The device can be switched on and works so far, only the message appears at startup:
The power supply unit is not recognized in the Bios and the charging process is set to "idle". I use original Dell battery, type...-
Channel: Schematic Requests ONLY!
- Loading...
