Samsung UN55KS800DFXZA Ver. AA02 with the seemingly common power cycling problem
  • SoftwareHack
    • Oct 2020
    • 59
    Re: Samsung UN55KS800DFXZA Ver. AA02 with the seemingly common power cycling problem
    I'll look into that tomorrow.
      • 12229
      • U.S.
      I'm gonna give the ice cubes a shot, Tried the canned air, not much luck, must be a certain technique and I don't have it. I wonder if anyone has tried dry ice, that shit is cold.
      • diif
        • Feb 2014
        • 6978
        • England
        The cheap canned air uses butane as a propellant, inverting the can causes the heavier liquid butane to come out first.
        Maybe your air doesn't use propane, are you seeing frost on the nand when you do it ?
        • SoftwareHack
          • Oct 2020
          • 59
          I just tested it against some glass and I get frost and it is wet to the touch when the frost disipates.
            • 12229
            • U.S.
            This is the only time I wish it was below zero outside, for just an hour or two, would make it a lot easier.
              • 12229
              • U.S.
              #26
              Youtube to the rescue, I remember hearing about or seeing this before, put a bit of that on your metal bar, maybe work quick so it doesn't get too cold, now to hunt down mine: https://www.youtube.com/watch?v=g8hJyR6P-qM
                • 12229
                • U.S.
                #27
                One important thing he forgot to mention, DO NOT store in an airtight container, sublimation can cause it to explode, just need a little anyway, no need to store it actually, can burn like hell, adult supervision required.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  Originally posted by SoftwareHack
                  2017
                  That's still more than late enough!
                  ASRock B550 PG Velocita
                  Ryzen 9 "Vermeer" 5900X
                  Arc A770 16 GB
                  eVGA Supernova G3 750W
                  Alienware AW3423DWF OLED
                  • Kilroy2k1
                    • Aug 2009
                    • 69
                    #29
                    I have this exact model and had the power cycling issue. Turned out to be a diode on the driver board.
                    With the TV laying on the bench with the back facing you you'll see theres 4 driver boards along the bottom.
                    The main board connects directly to the 2 center ones and there are small flex cables attaching the outer boards to the inner ones.
                    On the left hand one disconnect the flex between boards and then plug it in, see if it power cycles..
                    if it still cycles, reconnect and do the same to the right hand one.
                    Let me know if you get the back lights to stay on at all.
                    Tom.
                    Last edited by Kilroy2k1; 10-09-2020, 09:02 AM. Reason: typos! (i'm great at those)
                    • SoftwareHack
                      • Oct 2020
                      • 59
                      Tom.
                      I haven't taken it that far yet. I tested the power board connected to the main board and backlights with nothing attached to the main board and it continued to cycle so I didn't dig down deeper in my testing so far. I'm focusing on the main board at the moment, but I'll take a look at the drivers too. I also tested the power board connected to the mainboard with nothin else except the standby LED connected (even backlight disconnected) and I observed the cycling pattern on the standby LED.
                      • SoftwareHack
                        • Oct 2020
                        • 59
                        Here's what I got when checking voltages on the power connector CNM803 on the power board to the main board. The odd thing is that in standby mode, I would get different values for Vamp and A13V when I ran it at different times. It's as if shutting it down by pulling the plug didn't reset it to standby, but it remained constant until I pressed the power button.
                        The 3 main checks were done in Standby (before pressing power button), Cycle On (when backlight flashed on briefly and sound was on for a second), Cycle Off (when backlight went back off and no sound was heard but not quite back in standby mode).
                        I ran the test 4-5 times with the same results except for what was noted above during Standby mode during different tests.
                        All cables connected in this test.
                        Thoughts?
                          • 12229
                          • U.S.
                          #32
                          Are you sure about the last column OVD ON/OFF=19.6 VOLTS and BLU ON/OFF=50 VOLTS? And your getting 4.8 volts at BLU ON/OFF when it's on. I believe your fail count should be 0 if all is well, that looks off too, wonder if that's a backlight SOS? It doesn't seem like it should be tho, because your backlights stayed on with main to powerboard cable unplugged.
                          • SoftwareHack
                            • Oct 2020
                            • 59
                            Yes, got the same numbers on at least 2 different runs.
                            When Cycle On BLU ON/OFF floated between 0 and 4.8, never stopping on one value.
                            Also, the PWM numbers 1.2/2.4 means it was 1.2 when backlight flashed on and of 2.4 when sound could be heard briefly and 0.36 when it cycled off (no backlight, no sound, standby light goes on for a few seconds).
                            When in standby mode (before I ever push the power button) I can hear an audible clicking on the main board for 2-3 seconds that cycles periodically but nothing else lights up until I press the power button.
                            • SoftwareHack
                              • Oct 2020
                              • 59
                              i ran tests again on OVD On/Off and BLU On/Off and here's the consistent results: (backlight goes on for a second or so, same with the sound)
                              ---------------Standby--Clicking--Backlight On--Sound--Back to Standby
                              OVD On/Off--20.0------floating--3.3-------------0.6-----20.0
                              BLU On/Off---50.0------floating--0.0-4.8--------4.2-----50.0
                                Are you sure the 20 and the 50 readings are not in mV?
                                They cannot be 20V or 50V since the logic circuit does not run on that high of the Voltage.
                                • SoftwareHack
                                  • Oct 2020
                                  • 59
                                  You are correct. My meter is not illuminated and I did not see it switch to mV on the fly, so those are mV numbers.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4430
                                    • Italy - Milan
                                    #37
                                    Can you point out which is precisely the behaviour of the TV? If you see no images at all consider that mainboard is all in one with tcon, the tcon is a common source of problems in theese very fragile boards, often there is a "dirty" tiny cap in crisis that keeps in mad chess an entire 1000$ TV and carries it along the way of landfill like a Doctor House unknown parasite... check well Youtube videos of Adamant IT, it reveals the mother of techniques of fault findings, i use a slighty different method but it doesn't matter.. i follow the one from my experience but maybe them are swappable..
                                    • SoftwareHack
                                      • Oct 2020
                                      • 59
                                      Upon plugging in the power, standby LED illuminates, but nothing else comes on. Pressing the on/off button, no picture at all, a bit of a delay, then backlight flashes on for a second then off, then sound comes on for a second then off, and then the TV goes into standby (or seemingly standby) for another 12 seconds then the cycle starts up again. Image never comes on.
                                      This mainboard does have a built-in TCON. I have not looked too carefully at the main board other than to try and spot burnt components or broken solder joints but didn't find anything. Also did a continuity check on the cable to the power board to see if there was a short in the cable. All wires continuous and none shorted to adjacent wires (of course it would never be such a cheap problem). I'm hoping to avoid doing much on the main board as I'm just a software hack (see my name) and my hardware skills light at best...
                                      Backlight will come on and stay on only under the condition that the connector to the mainboard is disconnected. Power cycling happens even when only the power board is connected to the main board and the standby LED is connected (to visibly verify the cycling). So I don't think the panel is responsible for this particular issue.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4430
                                        • Italy - Milan
                                        #39
                                        If you are not expert enough, better to search for a mainboard.. if it doesn't work sell tv for entire as faulty.
                                        • SoftwareHack
                                          • Oct 2020
                                          • 59
                                          I don't expect to be able to repair the main board myself. Just hoping to isolate the issue and buy the right replacement. Main boards for this model runs from $50-$230 with the lower prices coming from individuals with no background in repair so I don't even consider those. Shopjimmy.com is out of stock on boards for this model.
                                          I'm hoping it's just a corrupt flash issue that can be corrected by an update, but I have to get beyond this cycling problem to update.
                                          But yes, if it's not a simple fix, then I will be looking for a new main board.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • howardc64
                                            by howardc64
                                            Problem
                                            08-04-2024, 10:36 PM
                                          • astyrcz
                                            820-02020 board. 5V cycling on both ports
                                            by astyrcz
                                            Hi! I'm having very similar problem with 820-02020 board. 5V cycling on both ports, the rear one, closer to UF400 0.11A - 0.28A and resetting meter, the front one constant 0.24A resetting meter in faster cycle. I have replaced already both CD3217 and this behavior changed a little - previously the front port had also changing current draw and slightly longer reset cycle.
                                            These weren't chips pulled by me from another board. I got them on Ali 5pcs. Tried 4 of them, same effect.
                                            The computer was bought as not working with info that worked on battery till it drained. Did not charge it...
                                            11-15-2024, 10:32 PM
