820-02020 board. 5V cycling on both ports
  • astyrcz
    • Dec 2021
    • The Netherlands
    Hi! I'm having very similar problem with 820-02020 board. 5V cycling on both ports, the rear one, closer to UF400 0.11A - 0.28A and resetting meter, the front one constant 0.24A resetting meter in faster cycle. I have replaced already both CD3217 and this behavior changed a little - previously the front port had also changing current draw and slightly longer reset cycle.
    These weren't chips pulled by me from another board. I got them on Ali 5pcs. Tried 4 of them, same effect.
    The computer was bought as not working with info that worked on battery till it drained. Did not charge it back.
    PPBUS_AON = 12V
    USBC0_CC1 = 0.09V - both ports
    USBC0_CC2 = 1.60V - rear port, 0.09V front port
    SPI_UPC01 lines all measure 16ohm
    SPI_UPC01_CLK = 0V
    SPI_UPC01_MOSI = 0.16V
    SPI_UPC01_CS_L = 3.42V
    SPI_UPC01_MISO = 3.42V
    PP3V3_UPC0_LDO = 3.42V
    I do not have oscilloscope to check for data transfer.
    PP1V8_S2 = 1.8V
    USBC0_3V3LDO_EN = 0V
    USBC1_3V3LDO_EN = 0V
    Do you have any hints on this?
  • mon2
    • 14769
    Can you clarify this measurement? How and where are you measuring these lines?
    • astyrcz
      • Dec 2021
      • The Netherlands
      These were measured between far side of the resistor RF295, RF296, RF297, RF298 and corresponding pins of UF260.
      That was done in resistance mode, no power to the board.
      Next thing I measured the voltage drop to ground with USB-C plugged in and cycling 5V.
      Last edited by astyrcz; 11-16-2024, 11:28 AM. Reason: I want to provide as much information as possible.
      • high-tech
        Samsung UN55F7050AFXZA ver. TD01 power cycling
        by high-tech
        Hello everybody, I could use some help on this one... It's got me guessing...
        I took pictures of all the boards and the pin out of the connector on the power supply that goes to the main board... I measured all the pins in relation to chassis ground, here are the result.
        (B13v)1. 12.7 volts cycling (Vamp) 2. 12.7 volts cycling
        (B13v)3. 12.7 volts cycling (PWM5) 4. 1.0 volts cycling
        (OD_LE)5. 2.8 volts cycling (PWM4) 6. 0.9 volts cycling
        (OD_ON)7. 2.8 volts cycling (PWM3) 8. 0.9 volts cycling
        9. ground (PWM2) 10. 0.9 volts cycling...
        09-15-2020, 03:39 PM
      • usbdevice
        Acer X223HQ (Version Bbd) on/off-power-cycling
        by usbdevice
        Hi all
        There's two other threads about this monitor with seemingly the same problem. The problem was resolved in one case by replacing the entire PSU board and in the second one by replacing an unknown IC.
        https://www.badcaps.net/forum/showthread.php?t=50657
        https://www.badcaps.net/forum/showthread.php?t=40512
        The first one has pictures of the pcbs and I noticed that there's one IC and assorted caps not populated on mine (but the PCB itself looks identical) so I thought that'd warrant a new thread.
        It's my dad's old monitor. He...
        08-05-2022, 02:21 AM
      • iMuhtaseb
        A2279 - 820-02841 cycling
        by iMuhtaseb
        A2279 (14" M2 Pro | 820-02841)
        No power - switches to 20V for a swift moment then starts cycling/switching on all USB-C ports.
        Board is clean.. I looked over it three times and found little corroded caps for a display data lines.. replaced them and they have nothing to do with the issue.
        Customer is using a branded USB-C to MagSafe cable. I looked for shorts (diode mode) nearly all lines, PPBUS, 3v8_AON, 5V_S2, 1v2_S2, 1v2_AWAKE, 1v8_AON.. and coils around master PMIC and slave PMIC; all reads normal.
        I suspected that ISL might be bad, took an educated...
        09-23-2025, 06:58 AM
      • dbuergi
        MacBook A2141 one USB port dead and one power cycling
        by dbuergi
        I got a 16inch MacBook Pro showing 5v and 0,3a on the left ports and right side has one power cycling and one showing nothing. The one cycling shows 30c under thermal camera. Surrounding components show no corrosion or any shorts.
        Any ideas what to check next? The whole board looks clean compared to the other A2141s i saw....
        04-25-2025, 11:40 AM
      • mon2
        A2141 820-01700 Power cycling (DFU worked ok)
        by mon2
        Hi. Working on an A2141 that is power cycling. Powers up fine (20V @ 3.1A peak) -> fan spins ok and then at a higher speed (after we removed the trackpad so the sensors are missing) -> chimes ok but after the high fan spin -> power cycles and repeats this loop. We did manage to DFU the unit with revive mode (4/4 steps completed ok) -> resulted in a brief padlock graphic before power cycling. Unable to toggle the keycaps led since the boot does not reach this far of the cycle.
        Q: Does the DFU process validate that the nand flash is OK ? We do not wish to restore this board...
        11-24-2023, 12:17 PM
