  • howardc64
    • Jun 2017
    • 653
    Problem
    This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached.
    Usually this problem starts manifesting itself with brighter settings only. Can work around by reduce brightness. Eventually, even the lowest brightness won't work anymore.
    Skill Level
    This repair requires quite high skill level. Furthermore, much of the LCD frame is sticky taped on and fragile LCD and frame construction makes it quite difficult. Gets easier with experience but most people reading this are probably first timers. Anyway, you must be fairly skilled and go slow… multiple days if necessary
    Additional Docs
    Previously made a PDF for repair directions. This posting is more update to date. Including it for reference
    https://drive.google.com/file/d/13Gq...usp=share_link
    Tools
    2 drives are Torx-10 (T10) and Phillips.
    Orient the iMac/TB Display
    Screen assembly is heavy so when laying it on its back puts significant pressure on the stand hinge (it can break internally) Roll up a bath towel and use as support
    Remove Protective Glass
    Use 2 suction cups and pull up.
    • Thunderbolt Display lift from bottom corner
    • iMac lift from upper corner
    Stand the glass somewhere safe. I usually tilt slightly so the inside of the glass (LCD facing side) face downwards to avoid getting dust inside of the glass.
    Remove 8 screws holding the display to the chassis
    Use a decent size T10 handle (you will need to tighten it securely on reassembly to avoid thermal cycling popping noises)
    Put 2 fingers around the tip of the T10 driver whenever removing or installing these screws. LCD glass surface is VERY soft (The removed protective glass is the real protection) and scratches easily. One slip and you will have a visible scratch on the LCD. I've actually accidentally dropped a small light weight T-10 onto the LCD and instantly got a scratch. Be really careful here
    Disconnect the LCD
    Pull up on the 2 black tabs and place a ~4” box to keep screen tilted while reaching in to disconnect the cables. Sometimes the tabs are broken or breaks easily. A L shaped hook tool / Allen key can help lift up by the corner.
    4 connections to remove. First 3 with LCD supported by the box
    Power cable connection to the main board is just under right edge of the board. Cable is also taped down to the Aluminum chassis. First remove the tape to release the cable. Then press the tab (blind since under the board) and pull gently to remove.
    Next remove the 6 pin connector. Just pull straight out
    Next unlatch the LCD connector (latch keep the connector secured against the board and need to be unlatched (rotated 90-180 degrees CCW) latch has a tab so its easy to grab. After unlatched, pull straight out
    After these 3 connections are off, tilt the LCD screen up about 60-70 degrees and T-10 to remove the ground screw.
    Now the LCD is free, remove and place somewhere safe if not working on it right away. Again, I tilt it and lean the LCD facing downwards to avoid dust build-up.
    Opening the LCD
    This is where all the complexity is and need to completely strip it down to get to the LED light bar connectors. This including removing 3 magnetic bars that secures the protective glass, layers of framing. Fragile LCD and its fragile edge buffer board. Diffuser sheet and light guide before finally getting to the inner most metal tub with LCD bars.
    3 magnetic brackets
    Each is secured by 4 T10 bolts. The 2 L shape ones have a really sticky surface and is quite difficult to remove the first time. Wedge tool is helpful. However, there is another couple of layers framing internally so probably want to review the steps ahead to make sure don't wedge into the wrong place.
    Outer Metal Frame
    This frame clams over LCD and internal diffuser/light guide/LED bar assembly and is one of the most difficult steps. Looks like this once removed
    • Once this frame is removed, LCD can fall out so need to be quite careful handling and orienting.
    • Frame is aluminum duct taped on and then need to be wedged off of few clips. Again, more internal framing so need to be familiar where to wedge.
    • Frame folds over the T-Con and LCD buffer boards which are also double sided taped down.
    Anyway, challenging the first couple of times with lots of prying pulling off stuck on parts and not familiar where to pull and wedge. View all the after removal pictures to get a good glimpse of where all the assembly points are.
    Foil Tape Removal
    First remove the aluminum foil tape. Quite laborious. Can cut this IF know where to cut but maybe too dangerous for first timer. On reassembly need to be refoiled to avoid thermal cycling metal popping noises. Can just tape over cut foil but maybe best to remove all the old foil tape for first timers. Take a lot of time but is safer process to remove the frame without so many sticky parts and not sure where to pull / wedge etc.
    Click image for larger version  Name:	frames.jpg Views:	0 Size:	578.4 KB ID:	3322743
    • Foil is along the 2 sides AND all 4 corners. Foil also over the flip metal cover for the LCD buffer boards and t-con.
    • Side foil also cover a brown fabric tape that covers wiring so be careful and not cut that.
    • To lift corner of tape off of metal chassis, a razor blade is helpful and much easier than fingernails.
    • No need to remove the 3 foil tape that cover the LCD buffer board + t-con cover seam.
    Open T-Con LCD buffer board metal cover
    After the side + corner foil tape removed. On to opening the LCD buffer board + T-Con flip metal cover.
    • 4 screws + numerous tape secures the cover.
    • Remove ground strap and screw
    • Peel off all black tape (can carefully save it and reuse but I used electrical tape instead to minimize chance of thermal cycling noises)
    Peeling near the LCD connector is quite tricky. Connector has a latch just like on the main board. Handle tape on the latch is sandwiched taped between layers of tape… Just a big messy taped mess. iMac and TB Display also differs in this area. Can easily damage the connector if not careful. If not can easily determine how to remove, maybe better to cut to handle tape to avoid breaking the connector on the board. Anyway, be ultra careful here.
    Click image for larger version  Name:	LCD connector.jpg Views:	0 Size:	239.0 KB ID:	3322733 Click image for larger version  Name:	LCD connect lock handle tape.jpg Views:	0 Size:	289.1 KB ID:	3322735
    • After black tape removed, removed the remaining 3 screws
    • Unlatch the LCD cable and remove it
    • Disconnect 6 pin connector
    • Disconnect LCD temp sensor connector
    • Lift up the cover
    • Carefully clear the temp sensor cable
    Rotating the cover will feel some resistance the first time. Cover will rotate along the seam to the frame with 3 foil tape partially covering the seam.
    Remove T-Con
    Flip open T-Con to buffer board flex connection lock. I do the connection on buffer board side (less stuff to dangle later) Use both hands, 1 finger from each hand on both side of this long flex lock.
    T-Con is taped down in 2 spots, just need to pull to separate. Once T-Con is freed from sticky tape, wiggle side to side to free the flex from buffer board.
    Free Buffer board
    Buffer board is also stuck on with double sided tape. Gently pull until they separate. Note buffer board has super fragile flex bonded to it and the LCD. Don't want to yank on this. So go slow and gradual until buffer board separates. A tool maybe helpful knowing with the double sided tape is. But the buffer board is thin and fragile so be gentle
    Removing the outer frame
    Peel back the 2x black lifting tabs off of the outer frame.
    Finally able to remove this frame. But note all the fragile LCD buffer board is exposed now AND LCD screen can easily fall out once this frame is removed. Need to be ultra careful.
    NOTE it is MUCH safer to wedge up frame from the opposite end to the buffer board for removal. This way you never squeeze the frame against buffer board to LCD flex. During reassembly, its the reverse, you want to insert the buffer board end first to keep it safe while clipping on the opposite end.
    Dangle T-Con / buffer board cover and buffer board over the edge of the table so these don't get damaged. However, it is then harder to use a wedge to pry loose the metal frame clipped into the plastic frame underneath. But this is what I do. Tilt up and wedge open from the opposite (to the buffer board) end. 7 Clip points total (see removed outer metal frame pic above). First 2 corners are the hardest.
    Maybe good to have a 2nd person to help handle LCD/tilt while the other find wedge points and free the 2 challenging corners.
    Click image for larger version  Name:	IMG_2536.jpg Views:	0 Size:	3.02 MB ID:	3322752
    Removing the LCD
    Now maybe good time to wear gloves to handle LCD glass, diffusers and light guide.
    Only 1 or 2 brown fabric tape on edge of the LCD blocks the LCD from coming out. Just peel these back, 2x suction cup to lift LCD onto a clean surface (I open a new trash bad (want to mark sure no oily surface) and line it on a table) Dangle the buffer boards over the edge so they hang free. Note the underside of the LCD is critical to not get dirty. The protective glass side can be easily cleaned. Any dirt getting to the underside require full LCD disassembly to remove.
    Remove suction cup after moving LCD glass. On LCD TVs, I have seen suction cup leave a distorted mark on the LCD for a few hours if not removed for long periods.
    Remove the plastic frame
    This plastic frame holds the diffuser sheets and light guide and the LED bar and the tub they all sit in. 6 Phillips screws on one side of the plastic frame and wedge off its clips to the tub (fairly easy. Finally plastic haha)
    NOTE there are other holes near the 6x screws for the magnetic bar. Probably good to mark which screws are for the plastic frame to avoid mixing it up (If use the wrong hole, will find out in the last steps assembling the magnetic bar and have to disassemble the outer frame again)
    NOTE diffuser sheets will fall out as soon as plastic frame is removed so best to remove this while LCD is sitting on the metal tub with diffusers facing up. Rotate the tub over edge of the table to gain space to remove screws and unclip.
    Remove diffuser, light guide, and white reflector sheet
    There are 3 diffuser layers, a 1/4” thick plexiglass like light guide and a white reflector sheet on the Botton of the tub. Can all be removed together and rest it on a table on the back of the reflector sheet that was facing the tub. Use a clean trash bag to cover the top diffuser sheet.
    NOTE if diffuser sheet is bent or crimped, it will be visible on the LCD with uneven light. Be very careful.
    Finally the failed LED connector
    No need to remove the LED bar (will destroy the heat transfer tape underneath) , 90 degree reflector from the tub (brittle and will break) Just clean off old solder on the connector and reflow nice fresh leaded solder. Protect the general area with Aluminum foil from soldering iron heat.
    Note will need fairly good soldering iron. Area is small as are the traces.
    Click image for larger version  Name:	led bar connector.jpg Views:	0 Size:	323.5 KB ID:	3322723
    Reassembly
    Largely reverse. But there are few key points
    Diffuser Reassembly
    The tub has guide posts that diffuser sheet must align to. They are slippery so carefully align these
    Click image for larger version  Name:	diff guide.jpg Views:	0 Size:	308.8 KB ID:	3322726
    Snap and screw in plastic diffuser frame
    Note to use the correct holes for this frame rather than magnetic bar hole.
    Make sure screw is on tight. Use something bigger than a tiny Phillips driver. It is plastic hole so don't want to put too much torque.
    Install LCD
    Before installing LCD, it is critical to make sure no debris on top of the diffuser to sandwich under the LCD glass. Best not to wipe with lint cloth etc. Maybe gentle sprayed air is best. Again, avoid strong force (including air pressure) any damage on the diffuse will be visible as uneven backlight. Out of 10-15 LCDs I have refurbed, only 1 had a tiny hair that was trapped here and visible when finished and required a 2nd disassembly to remove.
    • Extend the tub over the edge of the work table so LCD buffer boards dangle in air when LCD is installed.
    • User suction cup to handle the LCD for reinstall
    • Insert the 2 corner opposite of the buffer board into the slotted corner on the plastic frame
    • Lay down the buffer board end, note the buffer board flex cables will lay into cut open channels in the plastic frame.
    • Reattached the 1-2x brown cloth tape on the edge of the LCD.
    Reinstall the outer metal frame
    • Extend the assembly over the edge of work table so buffer board + tcon cover can dangle over the edge
    • Insert/install the buffer board end first
    • Gently press and clip in the opposite end
    After outer metal frame is installed, can finally flip over the LCD tub as LCD is now secure and won't fall out. LCD is still easy to scratch so be careful where to place it face down.
    Reinstall buffer board + T-Con
    • Buffer boards and T-Con screw holes are also alignment posts for board screw holes. Line these up
    • Insert the tcon to buffer board flex cable and latch it, lock the wide latch with 2 fingers from both hands.
    • Use a little pressure to secure board against their double sided tape.
    • Attach the LCD cable, 6pin cable, temp sensor cable
    Closing the con buffer board cover
    Its really important to reseal this cover properly or likely will produce popping noises between metal cover and metal tub and the rotating seam.
    • Close the metal cover. Becareful not to smash the temp sensor cable
    • Install 3 cover screws and ground cable screw.
    • I use electrical tape to secure the cover seams against the tub
    Foil tape the outer metal frame
    This step is really really important. The T-Con/buffer board cover is thin sheet metal folded against the sheet metal tub with a long seam between them. Cover is also a long piece only held on by 4 screws. If the foil and black retape is skipped, display will have random pop/click noises as it thermal cycles.
    • Peel off the 3x foil along the seam and install new ones. This is a long metal to metal seam. Important to secure this area without movement as display thermal cycles.
    • Cut strips of foil tape and seal the left and right side similar to original.
    • Foil tape all 4 corners
    • Foil tape both edge of the buffer board cover firmly against the tub.
    Click image for larger version  Name:	IMG_2544.jpg Views:	0 Size:	410.0 KB ID:	3322727
    Click image for larger version  Name:	IMG_2546.jpg Views:	0 Size:	295.4 KB ID:	3322728 Click image for larger version  Name:	IMG_2547.jpg Views:	0 Size:	229.1 KB ID:	3322729 Click image for larger version  Name:	IMG_2554.jpg Views:	0 Size:	293.9 KB ID:	3322730
    Magnetic bracket installation
    Lay LCD face down on a flat surface (and make sure nothing scratches it) Use the flat surface as a guide to level the magnets on the magnetic bar. Note the LCD will rest on the foam around 4 sides of the LCD. This foam is easily damaged so be gentle rotating and sliding the LCD AND when working over the table edge (for better screw access) where it can damage the foam.
    Make sure the bars are as straight as possible. The L bracket likely have slight bend due to difficult disassembly with its sticky inner surface.Click image for larger version  Name:	IMG_2553.jpg Views:	0 Size:	395.0 KB ID:	3322736
    • Install bottom straight bar. Make sure the 2 black lifting tabs are under the bar (between the bar and outer metal frame) Press down with magnet flush on the table and therefore flush against the foam around the LCD on the outer metal frame.
    • Tighten the screws reasonably tight but not over torque.
    • Install L brackets. Press down and alignment magnet to table surface. Top maybe more difficult to get it completely flush to table surface.
    Final assembly
    • Tighten all the screws on the board, fan, speaker, etc on the chassis. Note some are plastic and maybe rubber bumpers so avoid over torquing.
    • Insert LCD top (camera side) first, tilt 60 degrees and attach ground cable (good to have 2 people : 1 hold LCD, 1 attach ground cable)
    • Lay on 4” tall box, attach and latch lock LCD cable, 6 pin cable, power connector
    • Drop LCD onto chassis, 8x T10 screws. Again, hold 2 finger over driver head to avoid slipping and scratch LCD. I usually leave the screws just a little loose and tighten them when the screws is vertical on the stand. Tighten 8x T10
    Reinstall protective glass
    • Clean the LCD before closing up. Use microfiber cloth. LCD surface very soft.
    • Line up guides top near camera. Make sure top is flush the close the bottom. 2 people helpful as magnet is strong and makes it more difficult with 1 person.
    Bonus Problems
    Additional bonus problems
    Light guide tape distorted
    The 1/4” light guide has a tape near the LEDs. This tape is below the LCD viewing region. However, I have seen one where tape has bent towards the viewing region and appears as dark spots on the bottom of the screen. Cleaning off this tape with ISO fixed it.
    Bleeding left vertical edge on LCD
    Have seen quite a few TB Display with this. Appear when left unplugged in and gradually goes away in a couple of hours when plugged in and used.
    PSU resistor drift
    https://www.instructables.com/Fixing...le-27-Display/
  • howardc64
    • Jun 2017
    • 653
    Additional Note on iMacs
    09-11 iMac 27" LCD extraction slightly different. Consult the many online guides available. 09-11 changed nearly all the connectors between these years. Make sure consult the exact year and model. Some connectors are particularly fragile including 2009 27" vsync (probably > 50% removal results in cable damage). Here are some 09-11 iMac 27" HW tips
    https://sites.google.com/view/imac-m...u/imac-hw-tips
    iMac LG LCD also slightly different than TB Display but is basically the same. LCD cable etc have some differences. Also assembly slightly different (2011 has foil tape across the entire seam between tub and T-Con/buffer board cover, likely to decrease chance of popping noise from the 2 metal contacts further)
    • howardc64
      • Jun 2017
      • 653
      Long guide with many edits which can't be done with no editing after an hour after post. Moved it to ifixit
      https://www.ifixit.com/Guide/Apple+T...+Repair/175666
      Perhaps the moderator can just delete this thread.
      • mecha1166
        Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
        by mecha1166
        Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
        06-13-2024, 02:28 PM
      • RetroComputingGrotto
        IBM LTO 7 Tape Drive - Dust Sensors??
        by RetroComputingGrotto
        I have a Quantum SuperLoader robotic tape library that uses an IBM LTO 7 tape drive which is constantly complaining that it needs cleaning. If you insert a cleaning tape, it performs the clean and resets the cleaning counter to 0 hours. It should only require cleaning every 50 or so working hours but after as little as just 1 hours use it requests cleaning. We've purchased a new cleaning tape along with new LTO backup tapes but that has not resolved the problem.
        I have taken the library apart and can see no noticeable signs of dust inside. I have removed the tape drive from the...
        09-19-2024, 01:54 AM
      • howardc64
        LG 55UN7000PUA fixed with just dis/reassembly
        by howardc64
        TV runs, backlight on, have sound and no image (dark grey/blue/black LCD)
        Disconnected right (looking from rear of TV) tcon-buffer board cable, LCD left half displays.
        No shorts on right buffer board.
        Started masking tcon-buffer board signals... (connection #1 in main board pic) about 20+ pins from top of connector... LCD fully displays with some anomalies.
        Gradually reduced # of masking signals... eventually down to 1. Removed that... LCD works perfectly.
        No obvious damage on right buffer board 3x COF to the panel like another 43" LG fixed ( link ) with...
        09-19-2024, 11:16 PM
      • howardc64
        Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
        by howardc64
        Failure Symptom
        No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
        Where is the short?
        Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
        Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
        05-27-2025, 02:56 PM
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
