UN55D6000 Blinking Standby Light
  • mmartell
    • Oct 2013
    • 3189
    Picked this up yesterday. Was told it just turned off then would only blink and not respond or power up. Don't know how long it was sitting in that condition but when I got it home it seemed to labour (saw the Samsung logo a few times) but came to life. Watched it a few hours. Turned it on and off a few times during that period with no trouble.
    Fired up again today but soon shut itself off and will not power up. Blinking standby light.
    Voltage at main filter cap(s) is 390v but every 4-5 seconds there is a subtle "tick" and the voltage pulses. With everything plugged in the voltage dropped by about 40v. With Main board and Inverter (though all I see is a connector that disappears behind the panel) disconnected the voltage seems to rise during the "tick" to just over 400v.
    Pics in next post. Any help is appreciated.
  • mmartell
    • Oct 2013
    • 3189
    Re: UN55D6000 Blinking Standby Light
    And the pics...
    • mmartell
      • Oct 2013
      • 3189
      and a bump..
      • Ltank
        • Jun 2013
        • 776
        I had one. I jumpered the PS on and it did the same. Ordered a new PS and same. I could
        Not get the new PS to jumper and stay on either. I did not know if I got a bad board or iwhat. It was a new not refurbished or from a trashed set. I did not resolve the problem. The A 5vdc was fine. The B 5vdc was ticking on and off. Jumped the PS on with or without load results were the same
        • mmartell
          • Oct 2013
          • 3189
          Exactly, the PS is pulsing with or without load. I assume the A5v is standby and the B5v is generated after Power On signal.
          Did you ever find schematics or a service manual for this set ?
          Also, how on earth does that lvds cable come out ? It's not a twisted pair type cable and the little tabs seem to be not connected to its removal.
            Quick Start guide (6900 series, step up from 6000 series but overall quite similar):
            • freakaftr8
              • Oct 2012
              • 3743
              try disconnecting the t-con board and powering up I know you won't see a screen but see if its power supply stays running
              had a very similar situation with a 32 inch version of this Set it turned out to be the tcon board that was causing the problem of course it was tIcking also
              • mmartell
                • Oct 2013
                • 3189
                Thanks for that. I think I may have some LED's out so I'll try that backlight test. Having a shorted led couldn't lock the set down with the error blink could it ?
                • mmartell
                  • Oct 2013
                  • 3189
                  Ya freak I was trying to disconnect that lvds cable but it's not a standard plug and I don't want to force it too much.
                  • mmartell
                    • Oct 2013
                    • 3189
                    I know it LOOKS standard but those tabs don't do anything !
                    • multimeter
                      • Jan 2011
                      • 739
                      • united kingdom
                      squeeze the 2 tabs sticking out in,push forward,and pull out
                      fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                      please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                      • mmartell
                        • Oct 2013
                        • 3189
                        That works for twisted pair pair lvds cables but does NOT work here. I've put enough pressure on these connectors to just about fold them in half. No go.
                        • Ltank
                          • Jun 2013
                          • 776
                          On the set I had. The PS was not stable by itself not connected. It would not jump and stay on the B side 5vdc. The main board / tcon combo board was disconnected as was the Led backlight. Two boards did same. Old and brand new
                          • mmartell
                            • Oct 2013
                            • 3189
                            It seems that ALL voltages except Standby (holding steady at 5.39v) are pulsing to their peak with the subtle "tick" of the power supply. Even those designated as inputs like PSON and BLON are pulsing upwards. This is without the Mainboard or backlights connected to the PSU.
                            Would that not indicate a short in the standby voltage to one or several of the other switched supplies ?
                            • multimeter
                              • Jan 2011
                              • 739
                              • united kingdom
                              how about on the black connector,there is an arrow either side pointing?,would there be a slot for a small screw driver there that pushes an internal tab?
                              • mmartell
                                • Oct 2013
                                • 3189
                                THAT I thought of but seems like a piss-poor design as anything pushed where I think it should go runs the risk of severing the cable below it.
                                Believe me I feel like an imbecile I'm just taking in the Safe vs Sorry route atm lol.
                                  BN44 num on PSU - I could have a schematic.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Bn44-00424a
                                      Some discussion here leading to main board conclusion.
                                      http://www.justanswer.com/tv-repair/...-warranty.html
                                      No schematic I'm afraid.
                                      • tibimakai
                                        • Jan 2012
                                        • 3680
                                        If I remember well, there should be a flip up tab and then squeeze and pull.
                                        I had a D6250 with shorted panel. With one ribbon to the panel I had image and with both only backlight.
                                        In these newer TVs, can't be the capacitors?
                                        • mecha1166
                                          QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                          by mecha1166
                                          I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                          03-28-2024, 08:31 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • brithepi2k
                                          Sony KD-65XE8596 no standby light
                                          by brithepi2k
                                          I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                          cheers...
                                          09-06-2025, 02:22 PM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
