UN55D6000 Blinking Standby Light
  • CoryDavis
    • Feb 2014
    • 11
    Re: UN55D6000 Blinking Standby Light
    Ok thank you. I have half of the right side burnt out and one completely fell off the strip. Lol
    • CoryDavis
      • Feb 2014
      • 11
      can you use one of the led strips you can buy online? like the aftermarket ones?
      • mmartell
        • Oct 2013
        • 3189
        For aquariums and outdoor lighting and such ? Not likely.
        First you have to make sure the current draw and voltage requirements are same for the output of your power supply. Then there are space requirements that can not be exceeded. Then there are possible colour temp issues and/or possible heat related problems.
        I would think there are a whole host of things needing to be overcome to customize the backlight system.
        • autospark
          • Mar 2014
          • australia
          #164
          i just read the whole post
          so was the issue one problem after the other
          or the backlight problem all along
          ive got a ua40d5500 doing the same thing
          b5v turning off and on
          • mmartell
            • Oct 2013
            • 3189
            In my case it is and always was open leds in the backlight array.
            • CoryDavis
              • Feb 2014
              • 11
              Ok lmk when you get the led from digi and let me know if it works
              • mmartell
                • Oct 2013
                • 3189
                That would be user LTank who's here somewhere.
                • CoryDavis
                  • Feb 2014
                  • 11
                  Well I had an issue where an led actually fell off the strip. Put it back on and tv worked for a few minutes and went back out. Gonna take it back apart and see what I can do. Is there a trick to soldering these. They are kind of difficult
                  • mmartell
                    • Oct 2013
                    • 3189
                    Still trying to find the best way to install them. How did you do it ?
                    • CoryDavis
                      • Feb 2014
                      • 11
                      I have a hot air soldering station. But they are tricky to solder. It has the 4 prongs on end of led. IN the middle of led, does that have to be soldered also?
                      • mmartell
                        • Oct 2013
                        • 3189
                        I think that's for heat transfer. I used thermal glue there to keep the led in place and facilitate led cooling.
                        • CoryDavis
                          • Feb 2014
                          • 11
                          Ok gotcha. Well I get off work at 2:30 today and gonna start working on the TV again. Hopefully I can get it goin. What stores carry thermal glue?
                          • CoryDavis
                            • Feb 2014
                            • 11
                            Wonder if an led strip from another tv would work? Like just splice the wires and wire them in or something?
                              Difficulty with matching colour balance and brightness, along with the number of LEDs and rated current. If it did work, the picture would probably look off in one corner...
                              • CoryDavis
                                • Feb 2014
                                • 11
                                Well lucky me. I found another tv same model but guy is 2 hours away. Looks like I'm going on a road trip. Lol. For 50 bucks has cracked screen but still works
                                • Ltank
                                  • Jun 2013
                                  • 776
                                  Well I finally gave up on the set. The LED stip had 19 bad leds. I replaced 8 of them but the board was looking bad from removing the LEDs. It just took so much heat to remove the old LEDs that the traces that jumper the series LEDs come off and using wire wrap jumpers was not pretty. The ciruit was unreliable as it was but with all the jumpers and heat to rmove the LEDs thermal glue was too hard on the strip. With that much work and issues of unreliability I called it quits. If I ever get another one of the sets in and the problem is not the LEDs then I can get a current measurement to figure resistance of the proper load. The DigiKey leds STW8Q14BE-U0U7-BA woroked but were not as bright as the original using meter diode test.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    Sorry to hear that. I wouldn't necessarily part it out yet, just keep an eye for a drop-in replacement strip. Or like in my case any from the same series (and same size) can be used with a little rewiring - no need to touch the leds if they are good.
                                    • autospark
                                      • Mar 2014
                                      • australia
                                      #178
                                      Any one tryed to bypass the led with a resister to trick the tv to startup
                                      I know the light output will be less
                                      • mmartell
                                        • Oct 2013
                                        • 3189
                                        You can trick it with a simple jumper if that's your goal.
                                        • dssence
                                          • Mar 2007
                                          • 31
                                          #180
                                          To OP, Hi listen maybe you an help me out I have a 46d7000 with the exact same problem as yours the main psu clicks on and off. At first I thougt it could be a bad psu so I ordered a new replacement but keeps on doing the same thing.
                                          - If I unplug PSU from the mainboard the clicking stops.
                                          - If I unplug the PSU from mainboard backlights are not coming on.
                                          - I even teared down the screen completely and seen the led stripes all light up I don't see any burnt one
                                          - So I jumpered A5v with pwm1 pwm2 pwm3 and pwm4 and all the led stripes turn on from top to bottom.
                                          - Measured all voltages and they seem fine B5v, Vamp and so on. By the way do you know what OD_LEVEL and OD_ON_OFF are?
                                          - If I leave psu plugged to main , and measure the a5v test pad underneath when it clicks A5v goes 0 to 5 , and 5 to 0 while clicking
                                          My question is , did you made the same test as me jumpering A5v with pwm1 ? to see if the led strips lit ? from what I can see all the led strips turn on fine.. but could they be bad ?
                                          I'm suspecting the eeprom got corrupted but I already tried to reset it bridging SDA line to ground and SDA to VCC. Nothing. I'm going to desolder the eeprom and solder a blank one. Some ppl on samytogo forums said the SoC regenerates all the data. But I'm suspecting my set got bad with power spikes leading to something internally , like the unit doesn't turn on at all. but seems like a watchdog timer or somehing it's cycling. I could be wrong.
                                          • mecha1166
                                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                            by mecha1166
                                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                            03-28-2024, 08:31 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
