UN55D6000 Blinking Standby Light
  • Ltank
    • Jun 2013
    • 776
    Re: UN55D6000 Blinking Standby Light
    On the set I worked on the A 5vdc was good but it was the B 5vdc that cycled on/off. A new PS did same thing. Itwas due toast bad LED strip. If all your Leds turn on it may be a current issue. Measure the current of each strip. Compare it to the current rating listed on the PS. Is the voltage to the LEDs correct?
    • dssence
      • Mar 2007
      • 31
      #182
      Hi so even if all the strips all light up fine by bridging A5v to pwm1 - 4 . You say it could be a current issue. For this I would have to put my dmm in series and I don't think it would tolerate amp measurement of current going through.
      What troubles me is that by manually forcing them they light up like it says here.
      • w98seeng
        • Apr 2014
        • 19
        Sorry
        • darkronin619
          • Apr 2014
          Not sure if anyone is still following this…first time post. I have the same unit and believe the LED's are to blame. The main board was replaced one year ago under warranty. Since the LED's are so friggin hard to effectively replace, does anyone want the FRU boards? -OR- does anyone have a good led set they would like to sell? I got the unit for free, and really hate to junk the thing, but this looks like a trip to Costco would be much easier in time and frustration.
          • mmartell
            • Oct 2013
            • 3189
            ShopJimmy has them listed now for $55 but "out of stock". Maybe contact them and see if they can locate some for you.
            The repair itself isn't so bad it's getting to the led strips that's a bitch.
            • kevinm34232
              • May 2012
              • 1884
              So I just got one of these in (UN55D6050TFXZA), the standby light blinks and backlight flashes intermittently, is there a way to test if it it's the LED's or the main/PS board??
                If the power supply PS-ON pin and the Backlights pin have built-in pull-up resistors then you can disconnect the cable between the power supply board and the main board, apply the AC then you will see the backlights come on right away (no need to activate the power switch).
                • kevinm34232
                  • May 2012
                  • 1884
                  If I disconnect the main board from the PS, I get a constant bright blink of the backlight every 3 seconds. With the main board connected it's a dim flash about every seconds.
                  Although I can't find a service manual for this model, the newer manual suggests that the 2011 model's backlight should stay lit when disconnecting the connector to the main board.
                  My question is did the backlights blink every few seconds when the problem was confirmed to be bad LEDs?
                  • mmartell
                    • Oct 2013
                    • 3189
                    Not in my case however many have reported the set to reboot due to failed leds causing the backlights to come up for a short period during the cycle as in your case before the PS shuts down and the cycle starts over.
                    • kevinm34232
                      • May 2012
                      • 1884
                      How did you determine the LEDs were bad, did you have to expose them to see that some were out?
                      I thought these lights were supposed to last a very long time!
                      • mmartell
                        • Oct 2013
                        • 3189
                        Haha yes you have to separate the panel assembly from the backlight assembly. Then you can plug it in and see what's happening.
                        You can put a meter across each led in diode mode and see which will not light. I bet in your case bad leds will be clearly visible.
                        • Hookup31
                          • Mar 2015
                          • Pr
                          #192
                          Re: Samsung UN55D6000 Blinking Standby Light
                          Originally posted by mmartell
                          Picked this up yesterday. Was told it just turned off then would only blink and not respond or power up. Don't know how long it was sitting in that condition but when I got it home it seemed to labour (saw the Samsung logo a few times) but came to life. Watched it a few hours. Turned it on and off a few times during that period with no trouble.
                          Fired up again today but soon shut itself off and will not power up. Blinking standby light.
                          Voltage at main filter cap(s) is 390v but every 4-5 seconds there is a subtle "tick" and the voltage pulses. With everything plugged in the voltage dropped by about 40v. With Main board and Inverter (though all I see is a connector that disappears behind the panel) disconnected the voltage seems to rise during the "tick" to just over 400v.
                          Pics in next post. Any help is appreciated.
                          Hi, i'm new in the forum but came up with your same problem. Don't know if you still have the problem or the tv but i fix mine moving the potentiometer in the PSU counterclockwise 10 to 15 degrees. It is not that brighth as before but it's been working for four days now. Good Luck!
                          • kevinm34232
                            • May 2012
                            • 1884
                            Yes taking it apart does suck! But not too bad just make sure you're patient. I had the hardest time getting the screws out without stripping them, had to drill 2 out.
                            • kevinm34232
                              • May 2012
                              • 1884
                              Mine was definitely the LEDs, replaced the right side strip and all good!
                              Note: After going thru testing each LED on the old strip they were all good. One was shifted and touching the adjacent one, and one had fallen off completely which I may have done when removing. Seems they weren't soldered very well, or heated up too much and moved.
                              • kevinm34232
                                • May 2012
                                • 1884
                                OMG put it all back together, connected a source and a few vertical lines down the right side of screen. I was very careful with the panel. They may have been there before I dunno I never got the TV to come on before. What a waste..
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  I got some more patience and took this apart again, the tab bonds are relatively easy to get to. Put some Bergquist thermal pad (recommended by Budm in the past) under the offending tab bond, and got lucky. Hope it holds up.
                                  http://www.digikey.com/scripts/DkSea...70029008143555
                                    You probably flexed the tab slightly when putting the panel together or taking it apart. They are so damn delicate. I *hate* taking apart panels. I feel like I'm doing open-heart rocket surgery.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      I agree, I would not have done this if it wasn't a nice larger TV.
                                      Yea, you know how the ribbons flex around to the back of the panel with that long board attached? They had some masking tape holding it there along with the ribbons to the T-con. I thought it would be a good idea to tape that board to the top of the panel while working on the lights, but maybe that was too much flexing. Hope I never have to do it again.
                                      It would seem so easy for them to design a small access on the sides for the LED strip.
                                      • pablo6414
                                        • Mar 2015
                                        • usa
                                        #199
                                        Hi Guys. I am new here. I am working on sony kdl46hx800 with similar power problem. Got stand_by 3.3v all time. after startup PS does 3 rounds to start and ends shut down with error code (4times blinking red led).Did some troubleshooting, Disconnected harness between tcon and led backlight drivers helps to start power supply , I can here startup sound in speakers but no picture and no backlight. Suspect Tcon or backlight drivers ? Please help to determine problem, THX
                                        • gbalab1
                                          • Sep 2016
                                          Hi All,
                                          After having read this entire thread and trouble shooting my UN55D6000SFXZA it appears that my LED light bar is the issue. I get all the right voltage levels when checking the SMPS board (standby signals switching periodically on/off) and after removing the connector to the main board (with jumper between A5V_PW and PWM_DIMMING) there is absolutely no light. I haven't opened up the panel to actually confirm damaged individual LED's.
                                          Before I go through the trouble of tearing apart the panel I wanted to see if there are any spare parts available.
                                          Googling the light bar part number for my panel, LTJ550HJ05-C, the part number BN96-16609B shows up but I can't seem to locate any stock.
                                          Does anyone have suggestions, tips? Spare LED strips?
                                          Thanks!
                                          • mecha1166
                                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                            by mecha1166
                                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                            03-28-2024, 08:31 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
