UN55D6000 Blinking Standby Light
  • mmartell
    • Oct 2013
    • 3189
    Re: UN55D6000 Blinking Standby Light
    Originally posted by tom66
    Most 2000 count meter (max reading 19.99V, etc.) cannot drive white LED
    What do you mean by that and is that what I have ?
    • Ltank
      • Jun 2013
      • 776
      With this TV the power supply is not able to run by itself even if jumpered with resistors to simulate signals from the main board? This set uses the same Power Supplyas the
      UN55D6003, But different main boards. I have a UN55D6003 in shop with the samepower supply that had the same problems,I too replaced the power supply and it had the same problem. Jumpering the power supply by it self the A side 5vdc was stable. The B side
      5vdc cycled on/off not staying on long enough to get higher voltage fo the backlights.
      If we can figure this out it willhelpalot op people, Including me! I guess when I get slack time Iwill disect it best I can checking all thet I can but without schematics I can only go so far, Not sure about EEPROMs availability on the power supply
      • Ltank
        • Jun 2013
        • 776
        The MannualI posted forthe UN55D6003 shows on page 4-2 on flowchart that is A side is
        bad replace SMPS if B side is bad replace main board. I guess the PS supplies A side 5v stby to main board then the Main board supplies the Bside back to the power supply then
        is strange but it may be whats happenig. When My dad gets well i willget back to shop and give a good 5vdc input to main board and check voltage regulators and replace what is needed and reinstallit and check again!
        • mmartell
          • Oct 2013
          • 3189
          They're saying to replace main because no B5v probably means no PSON sent from main.
          I think I've got some failed led's and the supply will not run without a load.
            Yes, your meter is 2000 count so may not be able to drive white LEDs. That is just my experience with them.
            • mmartell
              • Oct 2013
              • 3189
              Ok maybe I'm dense but what does "2000 count" mean like four digit display or... ?
              • mmartell
                • Oct 2013
                • 3189
                How much voltage can an LED light safely handle ? I have a quick and dirty idea...
                As seen in one of the pics I posted in this thread there are four wires going to the backlighting. The center two are connected together at the board so if I assume (!) there are two led strips then I can isolate the individual strips by manipulating the harness.
                The board says there is 330v at the connector or 165v per strip. Is it safe to run full voltage through one strip ?
                  2000 count MAX reading is 19.99V i.e. it can read from 00.00 (zero) to 19.99 (1999) and has 2,000 total counts, or 1.999V max from 0.000 to 1.999, and so on.
                  I have a 6,600 count meter, many high end meters do 10,000 to 40,000 counts.
                  Each LED only rated around 3.5V to 4V but the key is they are non-linear current driven devices which means just 100V would not make the 1/4 bright they would not light up at all.
                  I don't know the configuration of this panel but if you give the model of the LCD panel (probably SAMSUNG, AUO, CHIMEI... plus model number) then configuration of LEDs might be available in my panels datasheet listing or another site.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Gotcha on the 2000 count.
                    Here's the sticker on the panel itself.
                      Unfortunately, I can't find a datasheet for that; probably a custom part for that TV .
                      • mmartell
                        • Oct 2013
                        • 3189
                        Actually I was trying to do the opposite - double the rated voltage by only running one string at a time at full voltage. Would that just destroy the LED's ?
                          That would probably kill a great many LEDs, unless the PSU is current limited. Even then, damage would likely occur.
                          • mmartell
                            • Oct 2013
                            • 3189
                            Thanks for that tom, I'm going to take off the panel then. Here's hoping I don't crack the lcd
                            • mmartell
                              • Oct 2013
                              • 3189
                              Well that was harrowing. I can't be sure I didn't damage anything I guess I won't know until I get it back together.
                              The LED strips are arranged as they are in another thread where another user did a teardown of his UN55D6400 - one strip on the right and one strip on the left. Each strip consists of 100 LED lights.
                              The right strip (as seen from the front) has all working LED's.
                              The left strip has 20 dead LED's in no particular order, except that all but one are on the lower half.
                              Two have failed open which I suppose presents the same to the Power Supply as not being connected at all.
                              Is it safe to short the two open LED's and see if the power supply will light up the rest even though the load is 10% smaller than designed ?
                              • mmartell
                                • Oct 2013
                                • 3189
                                Some pics...
                                  How many LEDs each side? 165V total I expect about 40~50 LEDs. I would say it is OK to jumper a couple, any more may risk failure of further LEDs.
                                  • mmartell
                                    • Oct 2013
                                    • 3189
                                    100 LED's per side so 200 total of which 20 have failed (my meter lights them, not too bright but enough). Two of the twenty have failed open, the rest short.
                                    The supply is rated at 330v total or 165v per string.
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      How do you explain it being so low (1.65v per led) ?
                                        Probably 50 LEDs/string but two strings in parallel.
                                        • mmartell
                                          • Oct 2013
                                          • 3189
                                          What's the easiest way to present a dummy load based on the fact 20 led's are out so I can test the power supply and the remaining led's ?
                                          • mecha1166
                                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                            by mecha1166
                                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                            03-28-2024, 08:31 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            07-07-2025, 11:53 AM
                                          • brithepi2k
                                            Sony KD-65XE8596 no standby light
                                            by brithepi2k
                                            I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
                                            cheers...
                                            09-06-2025, 02:22 PM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
