UN55D6000 Blinking Standby Light
+ More Options
Posts
  • johnboy1313
    • Nov 2012
    • 1959
    Re: UN55D6000 Blinking Standby Light
    Nice job!
    • Ltank
      • Jun 2013
      • 776
      What was the part# and whom did you buy from? Digikey? Mouser?
      • freakaftr8
        • Oct 2012
        • 3743
        Good job! Again. Lol
        • Ltank
          • Jun 2013
          • 776
          I humbly bow to your success! Well I have not been sucessful in removing the Leds. I tried my X-Tronic Preheater and Hot Air Wand,no luck. Tried Zepher and QuikChip Low melt solder and two different Soldering Irons and now really agrivated with myself. I did indusdtrial electronics for 28years and never had this kind of problem trying to remove an LED. May I ask what Iron or station did you use? Wattage? Tempature? Tip style and width? Did you use heat. Were the little Suckers glued down then soldered?
          I am asking because I have 20 to remove and replace and I cant seem to get One off!
          I want to give up but its pricipal of it now and I am not to proud to ask for help.
          What Led did you use? Thanks
          • mmartell
            • Oct 2013
            • 3189
            Haha you are thinking much too high tech. I used an exacto knife. Stand the strip on edge so the leds are vertical and push the knife straight down under it. Requires a little force. Once done a couple of times you will be able to remove them cleanly.
              So where are the LEDs from? Good to see it running.
              • Ltank
                • Jun 2013
                • 776
                GRRRR!. Man, I used wick with a pretinned tip to transfer the heat to remove solder the leads. Then used Exacto-Knife so blade was parallel with aluminum strip to attempt to get it to go under the LED. I dont have the gentle touch no more it pushed too far breaking the LED and tearing the pads off. Bummer.TWICE! Three others the pads were dammaged from too much heat. With the LEDS being glued they dont come off after being unsoldered. VERY FUSTRATING!
                • mmartell
                  • Oct 2013
                  • 3189
                  Harvested from a strip from another set. I still have no idea where to source them from individually.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Don't worry about breaking the leds, they are already broken. As for the pads I could never find where they were soldered anyhow and the spacing is so fine it's not worth the bother. Solder them with a jumper to the ones to the left and right.
                    A good bit of downward force all at once and they should "pop" off. You want to stay parallel to the strip because there are traces that run the length of the leds, depending on grouping amount.
                    If you have 19 dead leds then you have many to practice on to get it right. Then you will be able to harvest good ones from a donor strip and glue them in place. Don't give up !
                    • mmartell
                      • Oct 2013
                      • 3189
                      LTank check your PM
                      • Ltank
                        • Jun 2013
                        • 776
                        The Leds have 4 leads but only two are used. Looking through the mary variations of the Seoul Acrich Series LEDs i concluded that this is the correct
                        one to use. See page 4 for Schematic and dimentions. I ordered 30 from DigiKey 897-1093-6-ND STW8Q14BE-U0U7-BA SMD Cool White 5650 Leds
                        I contacted a member here and hopefully we can work something out on his units that needs and Led or two. I bought extra to practice with as they seem to be glued in with a high temp thermal conducting adheasive and the leads are soldered. I have ruined my board practicing on what not to to do but have not got the hang of what to do repeatably without damaging the board.
                        • mmartell
                          • Oct 2013
                          • 3189
                          How did you ruin the board if the leds you were attempting to remove were shorted or open already ?
                          • Ltank
                            • Jun 2013
                            • 776
                            It seems the LEDs are glued with a heat conductive glue that is bonded to the strip, then the 4 leads are soldered but only 2 are used. the Led had a metal bottom that conducts heat and gets glued down.
                            When pushing the Exacto knife at edge of LED it came loose suddenly ripping the lands off the strip. (once) Then I tried a Xtronic tool with IR heat on bottom and Hot air wand on top did nothing. Then tired a a 45 watt larger tip to unsolder both leaeds at once on each side but it was too much head and the small trace came unglued. (2 times)
                            I was able to use big iron from longer side of led that melted the led and the heat transfered to the leads and it came off cleanly. (2 times). then tried same twice again but not as pretty. Small jumpers can be made for some between the leds. I tried cutting the leds in half but that also damaged traces when they poped up when being cut.
                            • freakaftr8
                              • Oct 2012
                              • 3743
                              Anyone thought of using a dremel?
                              • Ltank
                                • Jun 2013
                                • 776
                                I will try a Dremel on the bad board come Monday. Eventually I hope to figure how to cleanly remove the LEDs with repeatable success. I can see why Samsung dont use these anymore. The 2011SV55 search shows at least two different types of LED strips for the same number. I dont know if I can damage more that it is already. I am saddened that it has come to this. I take pride in my work and with over 28 years in Industrial electronics I never had this kind of problem. Fustrating for Sure!
                                • freakaftr8
                                  • Oct 2012
                                  • 3743
                                  man don't let it get you down. After all think about it it's just an LED strip in your learning its not like the TVs is ruined or anything
                                  • Ltank
                                    • Jun 2013
                                    • 776
                                    Yea, I know. Its a Pride thing of fixing it and not letting it Win. The LED strips have no part number in the Service Manual and are considered part of the pannel and not sold or to be replaced.. We all know when the Pannel is toast the boards get parted out. I had this set for a while and reading about troubleshooting these sets, it gave me want to see for myself and fix it as a Challenge. As I read from this Excellent Forum , there is no shortage of Challanges!
                                    • mmartell
                                      • Oct 2013
                                      • 3189
                                      There is a part number for the strip - I would have to find it again. Its in the exploded parts list but it's useless anyhow.
                                      The jumpers I have made seem unreliable as the space between the leds is so small you must essentially heat up both joints at the same time. Tricky.
                                      I'm not worried about the traces at all if I can find a reliable way to connect the leds together.
                                      • CoryDavis
                                        • Feb 2014
                                        • 11
                                        I have bad LED strip also. Anyone have a good strip for sale or found out where we can buy LED?
                                        • Ltank
                                          • Jun 2013
                                          • 776
                                          I just ordered STW8Q14BE from DigiKey p/n STW8Q14BE-U0U7-BA 69 cents each.
                                          I have noy received them yet but from my check it should work. Seoul Acrich series LED
                                          The best way I found through experimentation in removing them with the least amount of damage to the strip was to cut them in half with small pointed Xcelite MS54-9J cutters then unsolder the leads. A small exacto knife is used to help lift the cut halfs from the strip when unsoldering. Then use a Flux solvent remover to clean the strip.
                                          I know of no one that has them. I have seen them posted in the past.
                                          • mecha1166
                                            QN750Q8FNBFXZA Service Error Codes Needed - Error code 1-3-1-2 ? Dead set, only blinking standby light in repeating sequence
                                            by mecha1166
                                            I am working on a QN750Q8FNBFXZA. Dead except the standby light. It blinks what appears to be 1 3 1 2. 1 long blink, pause, 3 short, pause, 1 long, pause, 2 short, pause, repeat. A service manual would be very helpful, or if anyone knows these error codes. Thanks!
                                            03-28-2024, 08:31 AM
                                          • ChristianBr01
                                            LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                            by ChristianBr01
                                            I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                            The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                            What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                            04-23-2025, 01:48 AM
                                          • YasaCh
                                            Sony kdl 40p5500 red light keeps blinking 3 times
                                            by YasaCh
                                            Hello...
                                            my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                            i opened the back cover no sign of damage on the powery suply or motherboard
                                            when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                            another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                            Yesterday, 11:53 AM
                                          • AleMonti
                                            LG 55EG910V - no power and no standby light
                                            by AleMonti
                                            I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                            I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                            The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                            After checking the basics I did the following:
                                            • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                            11-04-2024, 05:02 PM
                                          • Kaar3l
                                            Samsung QLED QE65Q7FNAT only standby light
                                            by Kaar3l
                                            TV: Samsung QLED QE65Q7FNAT
                                            PSU: BN4400940A
                                            MB: BN94-12832K
                                            I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                            09-24-2024, 01:35 PM
