Guest - Try our new boardview, Bios, & schematic search. Over 1.1 million files for download!
the gutless, bloated, and fried power supply hall of shame
This is a sticky topic.
    Re: the gutless, bloated, and fried power supply hall of shame
    Another thing to look at is the half-bridge coupling cap -- that dipped red one. It is much smaller than it should be for 400W rating. Usually it is a few uF at 630V. The size dictates the maximum primary current (well, the dI/dt, but with a fixed inductance and on time, fixes the maximum current.)
    • Pentium4
      CapXon Be Gone
      • Sep 2011
      • 3741
      This thing was $10, bought by a friend of mine Even though it isn't seized, the fan will not spin at all...This thing was manufactured in February, 2011. Can't believe shit like this is still being made!
      • Heihachi_73
        • Jun 2012
        • 713
        Yuck, even the fuse lacks a socket. Talk about saving 4 cents on every PSU they churn out... The exact opposite of HongKongFlyApartCompany is ChineseThrowawayCompany I suppose. I wonder if they even have wheelie bins over there, let alone recycling...
        If it's not seized, the IC on the fan's PCB is probably fried. Generally, the windings are the last to go open on a PC fan, unless someone put line voltage to it or something equally ridiculous.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8750
          I haven't seen a PSU with a socketed fuse for ages... Then again typically if the fuse burns on a PSU, something else already blew up and the PSU needs much more repairs than just the fuse...
            master hoarder
            • May 2008
            • 12182
            #425
            Not only are PSUs like this still made, but some manufacturers are starting to cut more and more corners. For example, cheap PSUs before used to only remove the second set of PI coils and use jumpers in their place. But now, they completely remove the spots for them from the PCB design! - That screams super-cheap IMO. I'm also starting to see those paper-thin heat sinks more and more often in bottom-of-the barrel PSUs along with much smaller PCBs being used. Back in the early 2000's and prior, the cheapest you could get was a low-end L&C, but even that had thicker heat sinks and bigger caps than many newer low-end PSUs today. I am seriously starting to think the Chinese are doing this just for a joke. What's next, remove everything and just have a few resistors bring down the line voltage down to 12/5/3.3V??
              No, include a 12V 2Ah lead acid battery and some LM317Ts!
              Maximum 12 hour warranty from shipping date!
              • ttn328
                • Jan 2011
                • 12
                • Vietnam
                #427
                Seen this on the internet
                • Behemot
                  • 4845
                  • CZ
                  #428
                  Yeah we got few pictures here too, somewhere
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Wow, i wish my power supply had fake PPFC! I just love the extra weight
                      I do wonder why they bother?
                      If the PSU manufacturer wants to make a PSU heavier -- they should just add weights. Many unreputable ones do that.
                      Are they being conned into buying fake PPFC chokes?
                      Or are they attempting to impress inspectors/reviewers? Most would point out other obvious failings such as lack of line filtering or poor clearances.
                      So, which is it?
                      • Pentium4
                        CapXon Be Gone
                        • Sep 2011
                        • 3741
                        So, which is it?
                        Yeah good point it just seems like a waste of time and money, and it's really easy to identify a fake one
                        • mariushm
                          • May 2011
                          • 3799
                          #432
                          EU regulations... they sort of force an power supply above 80w or something around that value to have PFC, passive or active.
                          I assume it's to pass visual inspection at import.. as they're not really opened up and the customs officers don't have the means to test them, they just visually inspect them.
                          Saw a couple of years ago a French customs officer in a tv documentary about CE mark and counterfeit stuff... he just opened a container, picked a random box, and it was supposed to be microwaves.
                          Opened the smaller box with a single microwave, pulled it out, opened the door, saw there's the platter, looked at the power socket to see if it's French and that's it.
                          Legally, he wasn't able to do more, if there was a report or complaint about a potential import all he could do was to send a few samples to an official testing lab but he couldn't hold the import until the lab gave the results.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5214
                            • New Zealand
                            #433
                            That's sad...
                            -David VanHorn
                              Technically you can get away without PFC up to 150W, but you need to keep the 3rd harmonic in check -- which is far easier to do with PFC.
                              • Behemot
                                • 4845
                                • CZ
                                #435
                                Yes, there is no reguation for PFC, just for harmonics. Quite common mistake.
                                  Well, 150W upwards specifies a PF >0.75 I think. I can't remember the specification at the moment.
                                  • Behemot
                                    • 4845
                                    • CZ
                                    #437
                                    Docs or didn't happen, you know the drill. The EUs norm ppl are usually refering to does not say a word about PFC, I have done the work of searching for it's contents, unlike everybody talking about it.
                                      The specifications are documents you must pay for. I will see if I can get IEC 61000 via my university access to this stuff, it's usually free.
                                      • Behemot
                                        • 4845
                                        • CZ
                                        #439
                                        You don't have to. Just there are fucking thieves who sit on government output organs, save all the norms when they are being published for free (as government usually has to provide it for free when some change has been made to it) and than sell it when the organs pull it off after few weeks/months.
                                          The IEC are charging for it. They appear to be the only source. If I get hold of it, I will publish it on some torrent site or elektrotanya or something. I pay taxes (VAT) I should have access to this stuff -- which dictates CE certification and helps us determine if it is validly applied.
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
                                          • eccerr0r
                                            Gutless, not bloated, killer, and should be hall of shame POS
                                            by eccerr0r
                                            Introducing... the POS-124Z which really is a POS:
                                            Yep it's a POS allright.
                                            I tried powering it up. It's a KILLER - not fried, but sure will fry things! I got 21V out of it unloaded according to my DMM!
                                            I tried 21W load (car lamp) - got 16V, which is really pushing that lamp.
                                            Then I tried a 50W load (car headlight) - got 13.2V. Not too bad but this is with the heavy load...except the circuit breaker kept tripping.
                                            So I had to take a peek:
                                            EIEW. Looks like a Darlington emitter follower + Zener device. Heatsinking?...
                                            10-05-2022, 01:28 AM
                                          • tamerelapute
                                            [LA-J891P] Warm cpu on 19v rail injection, is it fried ?
                                            by tamerelapute
                                            I'm learning electronics(already have some basics) by fixing a FH52M LA-J891P rev1B. It come from an acer nitro 5. The charger was defaulting upon pluging. The 19V rail resistance is 0ohm (I believe that caps screw my measurement). When i inject 5A, I get a rail tension of 1.3V, and 0.8V vcccore.
                                            Except the cpu, I cant feel anything getting warmer.
                                            I believe that it is normal, because the cpu is "eating" half the power I'm imputing.
                                            I dont know if the cpu is fried, because I did not remove the big capacitor on vcccore.
                                            I believe that if the cpu was fried,...
                                            07-08-2024, 03:28 PM
                                          • serwanjaf7
                                            hp victus (la-m787p) hall sensor problem
                                            by serwanjaf7
                                            hello friends
                                            pls i need help with hp vicuts it have problem on the hall sensor i want to change it bu i dont find and i dont now what is the part no
                                            pls need help
                                            thank you...
                                            12-08-2025, 01:23 AM
                                          • x_orange90_x
                                            Samsung UN65AU8000FF fried by water
                                            by x_orange90_x
                                            I was given this tv today. It was purchased just last month and only used for 3 weeks until recently when water leaked down the back and behind the cover. I removed the boards and WHOA 😲 did this thing get fried. Unfortunately the water got directly onto the backlights portion of the PSU. The board appears to be completely unrepairable, but I'm not certain about the backlights. I managed to get the probes of my tester into the slits of the plug and I DO get readings from both strings. I'm getting 26v from both. The PSU says LED Output is 167.4v however. Would this indicate that the backlights...
                                            10-16-2025, 08:40 PM
