List of transformer size types/output powers
  • Behemot
    • 4845
    • CZ
    Since we run to this every time and I guess I am not the only one who does not remember it all the time, I have been thinking about some list of transformer core sizes and their corresponding maximum power output. Consider normal ATX power supply with combined output on all rails. Would be good to type both average and maximum power. Think about average crappy PSU (efficiency wise, lets say it has input transistors and capacitors of enough capacity for the power).
    So, some sizes I can think off…
    EI-28 - 200 W continuous, 250 W peak
    EI-30
    EI-33 - 250 W continuous, 300 W max
    EI-35 - 350 W continuous, 400 W max
    EI-39 - 500 W continuous (?)
    EI-40
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: List of transformer size types/output powers
    EI-33 ~250W max, 300W peak
    EI-35 ~300-350W normal, 400W max
    • c_hegge
      • Sep 2009
      • 5219
      ERL-28 - 200W Continuous, 250W Peak
      ERL-39 - Never been able to max one out before (Most PSUs I run into with them seem to feature OPP), but they seem to be able to manage at least 500W continuously
      • Behemot
        • 4845
        • CZ
        Thanks. What bout the EI-40? Run into it in one generic PSU. It is somewhat thick, but lower on the other hand. I think it is arround 300-400 W level, are you familiar with this one?
        • Behemot
          • 4845
          • CZ
          I'll just add it states 4 mH. Does the numbering have something in common with their inductance, e.g. EI-33 having 3,3 mH and so on?
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Inductance has to do with the number of turns, the core Al value and the air gap (if any, not used in half bridge, and usually not used in single or double forward either, but could be). It's got nothing to do with the core size, although, for a given number of turns, a bigger core will yield higher inductance. Hence for bigger cores you can use less turns.
            A working TV? How boring!
            • Behemot
              • 4845
              • CZ
              Isn't there some magnetic inductance flow through the core? Considering this the core size should matter, now? Because of all those saturation things and so.
              • Pentium4
                CapXon Be Gone
                • Sep 2011
                • 3741
                When you say for instance, "350W continuous" is that usable watts or including inefficiency?
                • Behemot
                  • 4845
                  • CZ
                  Output from the PSU as a whole. Sure, it includes some 50 W for heat only than…
                  • Pentium4
                    CapXon Be Gone
                    • Sep 2011
                    • 3741
                    Just curious
                      Switching frequency comes into play also.
                      • Behemot
                        • 4845
                        • CZ
                        Man don't make it too difficult for once, can you? Fifty thousand things come into play, this way we will have shit again, not list. As I said lets talk about average PSU, lets say 2003/2005 driven. You usually dont find much over 60 kHz in there.
                        • Th3_uN1Qu3
                          Believe in
                          • Jul 2010
                          • 6031
                          • Romania
                          Inductance is an electrical property, like resistance and capacitance. It does not "flow". You meant magnetic flux, or "induction" which is noted B and measured in Teslas. Yes, you do get a magnetic field. Saturation flux (Bsat) is given by core size and geometry (more specifically: effective area, noted Ae), number of turns of primary winding and how much voltage is applied to it, for how long.
                          Inductance is just a byproduct of the number of turns and the core Al value. If you're making an inductor, you would still need to respect the number of turns per volt so that the core does not saturate - then, if the inductance ends up too high with the required number of turns, you use an air gap to bring it back down.
                          Yes, because the bipolar transistors used work best at <70kHz. Also the cores become less efficient over that - the number of primary turns does not decrease, because the material saturates earlier. They work best at 30 to 50kHz.
                          • Behemot
                            • 4845
                            • CZ
                            Ah, didn't know the terms in english, thanks
                            • Behemot
                              • 4845
                              • CZ
                              Is there really any difference between EI- and ERL- cores? Mean transfered power wise.
                              • ahmedtou
                                HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                by ahmedtou
                                Hi everyone,
                                help me please
                                I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                I will share all the details with you, including the disc information.
                                Code:
                                HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                Current Profile: BD-R
                                Disc Information:
                                Status: Empty
                                State of Last Session: Empty
                                Erasable: No
                                Free Sectors: 12,219,392
                                Free Space: 25,025,314,816 bytes
                                Free Time: 2715:27:17 (MM:SS:FF)
                                Next
                                08-27-2025, 08:49 AM
                              • mikey5791
                                Is it possible for transformer substitution?
                                by mikey5791
                                Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                                Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                                My questions are
                                1. How do i test to see if the transformer is in good working condition?
                                2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                                Hope you guys understand what i was asking. My intention is...
                                11-03-2022, 02:11 AM
                              • dennis_elx33
                                3PHASE STEP-DOWN Transformer in Check
                                by dennis_elx33
                                Hello All,
                                i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                                Problem statement: Power tripped Off
                                Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                                Action Done:
                                1) Replaced the faulty parts with good spare.
                                2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                                12-02-2024, 06:52 AM
                                ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                                This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 04:40 PM
                                ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) Pro Specification for Upgrade or Repair
                                This specification for the ASUS Transformer T304UA-P71SP-CA Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T304UA-P71SP-CA boardview and T304UA-P71SP-CA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-06-2024, 12:00 PM
