SVOD4 NPCX997
  • RethoricalCheese
    • Mar 2013
    • 1517
    • Estonia
    #121
    Turns out my successor was not able to update, so I've sat on 2024 january version this whole time. Now I understood the issue and got it updated. So ordering svod4 was pointless
    • spacez
      • Nov 2023
      • 54
      • FR
      #122
      HELLO please help me to unlock Thinkpad T16 gen 1
      NM-E981 SN PF-4A0GLW
      • volinakis
        • Jan 2021
        • 2701
        • N/A
        #123
        try
        • spacez
          • Nov 2023
          • 54
          • FR
          #124
          Originally posted by volinakis
          try
          THANK YOU . but no access bad data svp
          • Stefan Steff
            • Mar 2024
            • 238
            • Romania
            #125
            Try this patched content and provide feedback.
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1220
              • France
              #126
              try
              • spacez
                • Nov 2023
                • 54
                • FR
                #127
                THANKS BUT SVP DATA ERROR NO BIOS ACCESS
                • spacez
                  • Nov 2023
                  • 54
                  • FR
                  #128
                  Originally posted by Maxpower3
                  try
                  OH THANKS ITS WORKING FINE . GREAT MASTER . je te remercie
                  • Stefan Steff
                    • Mar 2024
                    • 238
                    • Romania
                    #129
                    Thanks for the feedback.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1220
                      • France
                      #130
                      There are some pieces to remove, compare with my file.
                      volinakis, you weren't far off, just forgot the checksum.
                      • volinakis
                        • Jan 2021
                        • 2701
                        • N/A
                        #131
                        yep, saw it now! Thank you.
                        • Stefan Steff
                          • Mar 2024
                          • 238
                          • Romania
                          #132
                          Big thanks!
                          I allready did and get it.
                          • 2elw
                            SVOD4 PCB pictures + parts
                            by 2elw
                            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                            GW1N-UV9UG169C6/I5 FPGA - Its a...
                            07-04-2025, 12:23 PM
                          • couillu76
                            yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
                            by couillu76
                            before you start the procedure read the bios eeprom and save it you might need it at the end
                            1do not power on your svod yet
                            2plug you ribbon 30x0.5 to the left of the keyboard connector
                            3test pin with testeur if it beep go to next stage
                            4 open svod software select 1.8v
                            5 now plug your svod
                            6 select nuvoton
                            7 plug charger on the board/laptop
                            8 press read id
                            9 select 256k
                            10 read nuvoton
                            11 save reading, now unplug the svod
                            12 open HxD software and open your 256k file the one you just saved
                            13look...
                            03-26-2023, 06:19 AM
                          • vanminhscdt@gmail.com
                            Read EC NPCX997 Lenovo T14 Gen 4
                            by vanminhscdt@gmail.com
                            I can't read EC Npcx997, device not found
                            Can anyone help me?
                            Where did I go wrong or what else am I missing to read it?​
                            Lenovo T14 Gen 4
                            S/N :PF4YA55W
                            M/B : NM-F261 RE 1.0
                            Thank...
                            03-31-2025, 12:46 AM
                          • x16
                            Lenovo L14 gen 2 unlock with svod4
                            by x16
                            I have a problem with a Lenovo L14 gen 2 (intel) with Nuvoton npce68b.
                            I connected my svod4 with a 32pin cable to the keyboard connector. Ground is also connected and power for the mainboard. I can read the Nuvoton ID, but the dump is always empty. Does anyone have an idea?
                            12-09-2024, 03:15 AM
                          • magicpc
                            Svod 4 reading emmc
                            by magicpc
                            Hello, is svod 4 able to read emmc? Do I need a special board or is it enough to solder into the pinout and insert the other side of the cables into the programmer? somehow especially set the svod?
                            08-29-2022, 02:41 PM
