SVOD4 NPCX997
  • rediii
    h???, spurrrn
    • Mar 2018
    • 501
    • somewhere in europe
    #101
    guys start using the lstc tool from lenovo. greetings
    • zomi
      • Nov 2011
      • 511
      #102
      Do you have a link to it, i didn't think it was in the wild yet ?
      • Mullahs
        • Nov 2022
        • 8
        • Philippines
        #103
        I bought SVOD 4 recently to test if can detect EC chip for Lenovo t14 Gen 5 NPCX997KAABX but unfortunately it is not detected. Maybe anybody can help me?Thanks
        Im using SVOD 4 Software : 0.0.5.9
        SVOD Firmware version : 0.0.4.2
        Machine Model : 21MDS2WR00
        S/N :PF56VM9T
        • Stefan Steff
          • Mar 2024
          • 379
          • Romania
          #104
          S/N :PF56VM9T
          Try :
          Select Nuvoton
          Read ID
          config NUVOTON - 256kb
          Read
          • Mullahs
            • Nov 2022
            • 8
            • Philippines
            #105
            Originally posted by Stefan Steff
            Try :
            Select Nuvoton
            Read ID
            Read
            The same still not detected.. i also tried both 3.3v and 1.8v, also with and without battery and cmos battery.
            • Stefan Steff
              • Mar 2024
              • 379
              • Romania
              #106
              Do not remove the CMOS battery because the laptop will start right away when you plug in the power cable. The other battery must be disconnected.
              So, before you try again be sure that the laptop does NOT start automatically when you plug in the power adapter.
              • Mullahs
                • Nov 2022
                • 8
                • Philippines
                #107
                same thing. not detected .
                • Stefan Steff
                  • Mar 2024
                  • 379
                  • Romania
                  #108
                  I'm truly sorry...hope to solve your problem somehow...
                  • james-b0nd
                    • Mar 2025
                    • 20
                    • Deutschland
                    #109
                    Originally posted by james-b0nd
                    3. Connect the ribbon cable EXACTLY to pin 1 on the left (see photo)
                    Click image for larger version Name:	Pins.jpg Views:	0 Size:	118.9 KB ID:	3642180
                    I had exactly the same problem. The ribbon cable wasn't plugged in correctly. Please use a magnifying glass and flashlight to check that the pins are aligned correctly.
                    • Mullahs
                      • Nov 2022
                      • 8
                      • Philippines
                      #110
                      I used microscope to make it sure that the pins are aligned..(Pin 1 in KB and PIN 32 in the programmer) I don't know if my programmer is faulty, its brand-new i just received it a week ago.
                      • james-b0nd
                        • Mar 2025
                        • 20
                        • Deutschland
                        #111
                        I don't think the problem lies with the programmer. Maybe it has something to do with the "Gen 5."
                        If everything else was done correctly, I can't figure out where the error lies.​
                        • Sbaro
                          • May 2025
                          • 4
                          • Guyana
                          #112
                          Hello everyone, (et surtout Max :P)
                          I try to remove the SVP from a Thinkpad L15 Gen 4 with a NPCX997​. I extracted the locked EC file (in attachement) but do not manage to clear the password from it. Can someone help to clean the file or explain a bit more in details how to do it ? I tried to "zero-out" some part of it as shown in this topic before writting it, but without success.
                          Merci d'avance !
                          • Maxpower3
                            Bad Veteran
                            • Feb 2018
                            • 1356
                            • France
                            #113
                            I try to remove the SVP from a Thinkpad L15 Gen 4 with a NPCX997. I extracted the locked EC file (in attachement) but do not manage to clear the password from it. Can someone help to clean the file or explain a bit more in details how to do it ? I tried to "zero-out" some part of it as shown in this topic before writting it, but without success.
                            Merci d'avance !
                            solved or not??
                            serial number for respect rules
                            PW07KVHM
                            • Sbaro
                              • May 2025
                              • 4
                              • Guyana
                              #114
                              yes it is solved, works like a charm ! Merci
                              • Kodza
                                • Jun 2016
                                • 194
                                • South Africa
                                #115
                                I think some of these programmers are faulty, I have gone thru the same issue like you. If you select Nuvoton and try to read it does not detect and if you try support for Svod you don't get any useful help. But the only way I was albe to read the NPCX997 but with ERROR 20 was to select motherboard and click read the same time you connect the charger
                                • Mullahs
                                  • Nov 2022
                                  • 8
                                  • Philippines
                                  #116
                                  Good day.
                                  Can you give me the step by step process you took for it to work. It will be a great help. Im really having a hard time with this for a couple of days now. What specific motherboard did you select? The SVOD TEAM only told me that's it working as reported to them by other customers.
                                  • volinakis
                                    • Jan 2021
                                    • 2875
                                    • N/A
                                    #117
                                    no, they are working. Error 20 appears when pins are not aligned or ribbon is faulty. I changed 32pins 0,5mm ribbon with 30pins 0,5mm from the svod kit because I had a lot of error 20 with 32pins ribbon after I used many times. You have to use a multimeter to check pins alignment microscope won't help. Check if you have last firmware and last software for SVOD4. Don't select any board, just select NUVOTON on Mode of programmer, 1,8V for Power and DISCONNECT trackpad, fingerprint, card reader, main battery, etc. Leave RTC batt. on. After plug in power adapter in motherboard check if power led is red then hit Read ID.
                                    Few days ago I unlocked a L14 gen.3 and I had "Power up fault " error beside "Error20", check photos.
                                    • Mullahs
                                      • Nov 2022
                                      • 8
                                      • Philippines
                                      #118
                                      I tried almost every guide and suggestion here in this thread but i was not able to make it work. Maybe it has something to do with the laptop model i have (Lenovo thinkpad T14 Gen 5 -amd). I think i just will wait for new firmware and software update from SVOD.
                                      • rediii
                                        h???, spurrrn
                                        • Mar 2018
                                        • 501
                                        #119
                                        try to use the right method. read id JUST BEFORE YOU insert ac adapter. unplug battery, read id again if it fails. it has to work
                                        • joby91
                                          • Sep 2018
                                          • 43
                                          • german
                                          #120
                                          I was successful flashin the EC using Successor Programmer.
                                          Everything working fine.
                                          My Mainboard was NM-E441 P14s Ge3 AMD
                                          • 2elw
                                            SVOD4 PCB pictures + parts
                                            by 2elw
                                            Hey, I find it very absurd that the SVOD4 costs so much and has zero documentation. I had no other choice than to buy it to unlock ECs, if there was any documentation or firmware avalible I could've made it or something simmilar. Anyways here are some of the most important parts:
                                            STM32H723VGT6 MCU - It's a microcontroller by STMicroelectronics and its the whole brain of the SVOD4. It has flash memory for the firmware which can be updated by the SVOD4 program. Its also powered by the AMS117 which converts 5v into 3.3V. 7€ on AliExpress.
                                            GW1N-UV9UG169C6/I5 FPGA - Its a...
                                            07-04-2025, 12:23 PM
                                          • couillu76
                                            yoga x390 (x13 to confirme )nuvoton npce288/388 sv password removal guide with svod4
                                            by couillu76
                                            before you start the procedure read the bios eeprom and save it you might need it at the end
                                            1do not power on your svod yet
                                            2plug you ribbon 30x0.5 to the left of the keyboard connector
                                            3test pin with testeur if it beep go to next stage
                                            4 open svod software select 1.8v
                                            5 now plug your svod
                                            6 select nuvoton
                                            7 plug charger on the board/laptop
                                            8 press read id
                                            9 select 256k
                                            10 read nuvoton
                                            11 save reading, now unplug the svod
                                            12 open HxD software and open your 256k file the one you just saved
                                            13look...
                                            03-26-2023, 06:19 AM
                                          • vanminhscdt@gmail.com
                                            Read EC NPCX997 Lenovo T14 Gen 4
                                            by vanminhscdt@gmail.com
                                            I can't read EC Npcx997, device not found
                                            Can anyone help me?
                                            Where did I go wrong or what else am I missing to read it?​
                                            Lenovo T14 Gen 4
                                            S/N :PF4YA55W
                                            M/B : NM-F261 RE 1.0
                                            Thank...
                                            03-31-2025, 12:46 AM
                                          • x16
                                            Lenovo L14 gen 2 unlock with svod4
                                            by x16
                                            I have a problem with a Lenovo L14 gen 2 (intel) with Nuvoton npce68b.
                                            I connected my svod4 with a 32pin cable to the keyboard connector. Ground is also connected and power for the mainboard. I can read the Nuvoton ID, but the dump is always empty. Does anyone have an idea?
                                            12-09-2024, 03:15 AM
                                          • magicpc
                                            Svod 4 reading emmc
                                            by magicpc
                                            Hello, is svod 4 able to read emmc? Do I need a special board or is it enough to solder into the pinout and insert the other side of the cables into the programmer? somehow especially set the svod?
                                            08-29-2022, 02:41 PM
