Lenovo Thinkpad Ec Pwd Bypass
  • kicker12
    • Jul 2022
    • 10
    • Italy
    #701
    Hey!
    Just to inform/confirm it works on X1 Yoga 4th (board FX490, NM-B861, same as X1 Carbon 7th): shorted J5 (which is located o the side of the battery connector), pin 4-6-8-10 (all connected together).
    Took some attempts, lost the serial number trying (not big deal) and, as user 64xgeo reported, a weird message where I had to press Z...
    All fine and clean now: thanks MaxPower!!!
    • Andromedus_81
      • Aug 2023
      • 46
      • United Kingdom
      #702
      Hello
      Has anyone unlocked the Lenovo T470 model? If so, could they suggest which pin they used?
      Lenovo ThinkPad T470
      Type 20jn
      S/N pf-0y25az
      • Stefan Steff
        • Mar 2024
        • 243
        • Romania
        #703
        Originally posted by Andromedus_81
        Hello
        Type 20jn
        S/N pf-0y25az
        Unlocking T470 works with Lenovo Autopatcher : https://www.badcaps.net/forum/troubl...oval#post78215
        • Maxpower3
          Bad Veteran
          • Feb 2018
          • 1222
          • France
          #704
          Hello
          Type 20jn
          S/N pf-0y25az
          NM-A931 MEC1653
          J5 too 4/6/8 or 10
          Click image for larger version  Name:	image.png Views:	0 Size:	36.9 KB ID:	3666465
          • kapiras
            • Jun 2025
            • bobr Kurwa
            #705
            Originally posted by Maxpower3
            T480 NM-B501
            tested ok
            Hi all, i am trying to unlock BIOS, protected by password of my Lenovo t480, I’ve tried flashing bios chip using CH341A tool with no success, then i came across this post and please correct me if I’m wrong, i am not good at reading schemes , is the pin that i marked in red is the right one?
            • Maxpower3
              Bad Veteran
              • Feb 2018
              • 1222
              • France
              #706
              Yes it's good.
              you can use the 4 or 6/8/or 10 with a short shunt with a ground during startup
              watch my different videos as an example
              • jackx
                • May 2020
                • 208
                • casa1
                #707
                hello maxpower i need solution for t14s gen2 mec1503
                • Maxpower3
                  Bad Veteran
                  • Feb 2018
                  • 1222
                  • France
                  #708
                  _
                  • Maxpower3
                    Bad Veteran
                    • Feb 2018
                    • 1222
                    • France
                    #709
                    No, not at the moment.
                    I actually have one on my desk.
                    It's going to suffer from the exams.
                    • Maxpower3
                      Bad Veteran
                      • Feb 2018
                      • 1222
                      • France
                      #710
                      The only PC I killed was an X390 when I played around with modifying the Lenovo utility to remove the password.
                      I replaced 54h with 57h but I made a mistake in my modification.
                      The EC is corrupt now
                      repaired, Bios + MEC16​
                      • tdelfy
                        • Aug 2014
                        • 109
                        • usa
                        #711
                        Originally posted by Nikolson
                        Hello, I need unlock bios password Lenovo Thinkpad P15v Gen1 S/n PF-2VZK7T Type number 20TQ motherboard is nm-c641
                        KBC is NPCX897
                        I reed ec and tried to modify dump but I get these errors and the machine shut down. Please help.
                        you read NPC897 somehow.please share
                        • Polar Bear
                          Polar Bear
                          • Jun 2025
                          • 8
                          Could you clarify on information in original post regading Mec1663?
                          Mec1663 Dmi start from 0x00
                          Pwd 0x300 - 0x34F replace with FF
                          Do I understand correctly that you utilized JTAG to remove the password? Can you describe the procedure?
                          I wonder if FT232H with openOCD can be used for such approach to remove supervisor password.
                          I luck exprience in this field and looking if inexpencive JTAG adapter can be used in such situation.
                          A consultation with ChatGPT indicates that perhaps it would not work as only SWD protocol implemented.
                          Thank you
                          Polar Bear​
                          • Usering
                            • Sep 2024
                            • 47
                            CHANGING CHIP EC MEC1503 , WORKING
                            • Usering
                              • Sep 2024
                              • 47
                              REPLACING EC MEC1503
                              • leancash
                                • Jul 2025
                                • Colombia
                                #715
                                I really want to thank you, because I was worried about two Thinkpad T480s I bought with a supervisor password, but looking for a solution on the internet, I came here, and after two days reading the threads and watching the videos, I figured it out, and now the two PCs are working perfectly. I did it like in the 5th or 6th try.
                                Merci beaucoup.
                                • Andromedus_81
                                  • Aug 2023
                                  • 46
                                  • United Kingdom
                                  #716
                                  Hello
                                  Has anyone unlocked the Lenovo X380 Yoga 20lj model? If so, could they suggest which pin they used?
                                  S/N 1htx0j
                                  • veridiux
                                    • Jul 2025
                                    • 3
                                    I purchased an X1 Carbon Gen 8 a few years ago, but unfortunately discovered it’s locked with a BIOS password. Will this method work to bypass or reset it?
                                    • Usering
                                      • Sep 2024
                                      • 47
                                      no solution bypass chips mec1503 , mec1723/24 yes solution Hardware by replacing mec1723 chip
                                      • Usering
                                        • Sep 2024
                                        • 47
                                        Hello
                                        S/N 1htx0j
                                        there is 3 way solutions
                                        solution by patching bios if size 16mb
                                        solution programming EC , by programmer (svod, vertyanov or rt809…)
                                        solution LPC by jumper pon LAD0
                                        • veridiux
                                          • Jul 2025
                                          • 3
                                          Do you happen to know anyone who does this online? I live in a rural area, so not very many repair shops.
                                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-06-2024, 11:40 AM
