Fix for Benq FP737s 17" (Q7T3)
Re: Fix for Benq FP737s 17" (Q7T3)
PlainBill answered this ...
https://www.badcaps.net/forum/showpo...7&postcount=20--- begin sig file ---
--- end sig file ---Comment
Hai Everybody,
I joined in this forum yesterday. It is a very useful and helpful one. I could get some essential information regarding my damaged Benq LCD Monitor. Could somebody give the values of Caps @ C501 and C509 in Benq Q7C5 Power Supply Inverter Board? Thanks....Comment
LCD monitor manufacturers use various power supplies and inverter boards for monitors with the same model number. You will need to open up the monitor and then you will be able to read the values of the needed capacitors. Many members here recommend replacing all of the electrolytic caps at the same time (except for the large main filter cap). There are several threads on here about ordering capacitors and recommended brands. If you make a list of the capacitors that are on your board, and list what replacement caps you think you should order, someone here can verify if you are ordering the right ones. Pictures also help people help you, use the manage attachments below the text area when posting through advanced messages.Comment
hi, please help me with a problem, i have a benq FP731 monitor with a strange problem,
the screen is white and nothing is displayed, only a few small lines colored.
i have try to press and the ribbon from the lcd panel to logical board, but nothing.
the monitor enters in standby or exit from standby when i disconect the input cable.
any ideea where is the problem?Comment
1) You could have a blown SMD fuse on the panel card that runs the length of the monitor. The panel card is usually at the top of the monitor.
2) There could be a bad voltage regulator on the main board.
3) You could have bad, but not bloated, caps on the main board.--- begin sig file ---
thx,
i have check the fuse from the lcd panel and is ok,
but after that i have power again the monitor and is just work, no white screen, just work, but after a few hours or running ok, after i reconnect the monitor to power i get again the white screen. The last thing that i have work on it is the connector from the panel and the logical bord.
After that i have try again to check the connector, to check again the connection but nothing, still withe screen
any idea what about that? strange thingComment
Hi check the fuse again - if you can get to it, try very gently pressing on it ( With something insulated )while everything is switched on -may be bad contact?
If it is a flat cable connector did you clean it. If it is pins have you checked for bent or broken pins.
"the monitor enters in standby or exit from standby when i disconect the input cable."
Do you mean the input from the PC - you should not plug/unplug any internal cables when it is switched on.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740Comment
I have 2 Benq FP737s, 1 work's perfectly well the other well I'll elaborate...
When switched on the LED will light up green but the backlight will flick on and off randomly, the signal/picture is still there as when it's flickering on and off if you shine a light on it you can still see the image.
So it hasn't completely died yet. I have searched this thread and apologise in advance if these symptoms have been seen before.
Thanks in advance.
NickComment
Hi All
New guy from Mozambique,
MAN! I wish I had a Pinch of the Knowlwdge floating around this forum, Good going Guys.
I have a Benq Q7T3 which has been good for years, now it has died a quiet death.
No lights no nothing, have done a cursory test of trannies and such, resoldered all joints, did not remove solder just resoldered and nothing happens.
I am a hobbyest and don't know much, am also 1000Km from civilization and batle to get spares quickly, have to wait till I go go to South Africa from time to time to purchase.
Please tell me where to start to look for the problem, I do have the diagram and understand a bit about testing.
Any help will be much appreciated
Kind RegardsComment
Thanks for the info in this thread, it saved me a screen! (Though I was thinking of buying a new HUGE one already... damn...)
I have two HP 1740, one of them first was not able to switch off the backlight (nice LCD-going-off effect, then white), then after a week it died completely.
It has inside a derivative of the Q7T3 board (48.l1g02.a01) for which I could not find an exact schematic... (annoying!) It is slightly different since it does not have the PF751 (Vinverter fuse). What happened is one of the MOS switches (FU9024) blew to short (that's probably the screen not going off anymore?) and one of the bipolar c5707 blew as well (that's the screen dying I guess).
I got a repair kit from ebay, replaced all transistors (4 c5707, 2 FU9024), replaced the (only) fuse PF701 (that's the fuse before the large diodes with heatsink) and it worked! Tadaaa!
Thanks again! I just wonder how much longer these old screens will live
(so I can finally buy myself something bigger
Kuba
BTW. I also resoldered the inverter's transformers. It indeed looked like there is some wear on the joints...Comment
I just joined this forum, and have read through numerous posts to try and fix my Q7T3 Benq monitor.
I have been getting the "2 seconds to black" problem. Although, at first, after switching the monitor off and on a number of times, it would work OK.
There's nothing immediately apparent on the board itself. So, I tested the following, but replaced them anyway...
1) the 3A picofuse
2) the 4 2SC5707 transistors
3) the 2 FU9024N fets
... but no difference.
I have just retouched the solder on the inverters, and still no change... at first, anyway. After switching the monitor on and off a few times, I now get the Benq logo flashing every second or so.
So, any ideas where I go from here, please?
I also read that the octocoupler might need resoldering. Is this IC602 on my board? [48-L8302-A30].
I'm fairly new to a lot of this stuff, so thanks for any help.Attached Filesif you find these attachements useful please consider making a small donation to the site
Re touching may not be enough - You need to get some leaded solder to mix with the old solder then remove it -or most of it then resolder with new solder.Please upload pictures using attachment function when ask for help on the repair
IC602 probably is - re solder it anyway wont do any harm 4 legs? cant see it on pic.
You should aso resolder those gray box caps with a k on between the 5707s and also the blue ceramic caps - and the inverter transformers and main transformer in fact if your good at soldering solder as much as you can be bothered with.
Last edited by selldoor; 03-21-2013, 09:02 AM.Please upload pictures using attachment function when ask for help on the repair
Sch:
The inverter transformer driving circuits are setup as self Osc Royer OSC, if the MOSFET which is PWM driven at the Gate to provide variable DC (more dc more brightness) for the Royer Osc, if the MOSFET shorted out (jump Source and Drain), the inverter will be running at full mode disregarding the PWM IC is working or not.Attached Filesif you find these attachements useful please consider making a small donation to the site
OK, thanks.IC602 probably is - re solder it anyway wont do any harm 4 legs? cant see it on pic.
IC602 does have 4 legs.
Will resolder all, and report back...Comment
by x_orange90_xI just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
I don't know how exactly to test the inverter itself. Is it... -
by GentianI have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...03-06-2023, 07:07 AM -
by valvashonFor some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...1 Photo -
by eccerr0rIf I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
Next thing is trying to charge the batteries using solar power, but that's another issue ... -
by caseyjay_48I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,... - Loading...
