Vizio E55-E1 bad backlights or bad inverter?
  • x_orange90_x
    • May 2015
    • 798
    I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
    I don't know how exactly to test the inverter itself. Is it likely that 3 quadrants do in fact have bad leds? Or could the inverter be bad? I see backlights available on both SJ and eBay which is usually a good indicator that they are a common failure.
  • nomoresonys
    • 12370
    • U.S.
    I believe on this one, you would unplug connector cn801and put tester probes on pin 1 and 5, 3 and 5, 2 and 6, 4 and 6 of the connector and see if the backlights respond correctly.
    • x_orange90_x
      • May 2015
      • 798
      Oh, I see what you're saying. But I'm thinking all 6 of those are positives, notice it's 6 brown wires. Also it says 1, 3, 5 = LED1_+ and 2, 4, 6 = LED2_+
      If this we're the case there would 6 segments to the screen but I believe theirs only 4...
      If what you said is correct then 5 and 6 have to be GROUND wires in order for it to be quadrants, but the wires shortly wouldn't be the same color as the positives 😧
      After looking it up I don't there are 12 Active Zones... fwiw
      • Diah
        • Feb 2013
        • 6650
        socket must be unplugged
        Vcc + are brown
        Black are LED -
        Odd Pins No (brown ) + to Odd Pins ( Black ) -
        Even Pins No ( Brown )+ to Even pins ( black ) -
        • x_orange90_x
          • May 2015
          • 798
          Vcc + are brown
          Black are LED -
          So I can check 1, 3, and 5 to ANY of the odd numbered black wires on that connector? Likewise with 2,4,6 to even numbered black?
          • Diah
            • Feb 2013
            • 6650
            yes
            • nomoresonys
              • 12370
              • U.S.
              So was I right then?
              • x_orange90_x
                • May 2015
                • 798
                I checked 1, 3, and 5 to pin 7... No voltage draw
                I checked 2, 4, and 6 to pin 8... No voltage draw
                I also tried to check them to pins 23 and 24, same.
                I don't believe this test was accurate, because I know that at least once area lights up with the power on. Therefore at least one of the six words should have had draw on it. I did check these with it unplugged from the inverter.
                • nomoresonys
                  • 12370
                  • U.S.
                  It's pretty basic right, here's a guy doing it with a diy rig, one probe to + and one to - https://www.youtube.com/watch?v=rNqRZ2qaDJY
                  • x_orange90_x
                    • May 2015
                    • 798
                    😂 This surely isn't my first rodeo. But it IS the first time I've tried checking backlights that have 2 dozen wires going to them! None of which actually say LED- or even ground for that matter.
                    • R_J
                      • Jun 2012
                      • 9672
                      • Making Money
                      Pins 7 and 8 are marked as NC (No Connection) look at the pin def. Pins 1,3,5 are VLED1_+ (from supply C8108/9) pins 2,4,6 are VLED2_+ (from supply 8209/12) All the other pins 9~24 are returns (led-) All 14 separate FB circuits have a mosfet and a source resistor as return to ground, each mosfet source also has a return (current Sense) back to the controller so it knows if a single string is open and likely shuts down all. Also the leds are controlled by the video that is displayed on the panel.
                      You likely have bad led's or maybe bad connections in the panel between the led strips and distribution strip.
                      14 strips, 6 led's per strip
                      Shopjimmy has the led strips, it looks like there are two different ones, so be sure to order the correct ones.
                      • x_orange90_x
                        • May 2015
                        • 798
                        I just held the positive on one of LED2_+ pins and went along each of the black wire pins on the same side with the negative probe until I found something. When I touched Pin 16 FB9 I got 16.4v. so I checked the other 2 LED2+ pins and also got 16.4v. so that side appears to be working. I tried pin 15 FB10 with LED1_+ pins and got nothing. I suppose this means that side has bad LEDs.
                        • lotas
                          • Jan 2016
                          • 5203
                          • Russia
                          Check the voltage here for each channel.
                          • nomoresonys
                            • 12370
                            • U.S.
                            I read it wrong, so 1,3,5 are vled 1 and 2,4,6 are vled 2.
                            • bpcannan
                              VIZIO M557-G0: Backlights or ???
                              by bpcannan
                              'Morning,
                              I get sound and picture when powering on the TV and its stays that EXCEPT that the left half of the screen will dim every few seconds then return to normal while the right side of the screen performs as designed.
                              Did the soft and hard reset options pulling the plug, using the reet option in the vizio menu to no avail.
                              I checked the mainboard - found some popped capacitors so replaced it - but that did not change the situation.
                              I checked the t-con board. It is getting good power. Then I removed one ribbon cable to see if I could isolate...
                              10-29-2023, 06:36 AM
                            • csmith
                              Vizio-D50u-D1 Pulsating Backlights
                              by csmith
                              This Vizio came in the shop with no backlights. Replaced all the strips with replacement from Shop Jimmy. Set now has backlights but lights pulsate on left side. Half the screen brightens up then goes to normal then repeats.
                              Am I looking at a defective strip? Thanks in advance.
                              11-07-2024, 02:56 PM
                            • x_orange90_x
                              Replacing backlights in Vizio V755-J04
                              by x_orange90_x
                              I've had this monster for several months as I've hesitated to order backlights for it. Finally did order them and they are due to arrive tomorrow. Besides having ample space to work, are there any recommendations for working on such a massive screen? Should I remove the panel by myself or would 2 people be a better choice? I bought the double-cup suction cups from Harbor Freight and have been using them for the last few repairs on smaller screens. They are far superior to the single cup orange ones I used previously that would often let go without warning 😱.
                              I have not replaced...
                              12-03-2024, 07:03 AM
                            • Francesc V.
                              Jiguun 1500W inverter stops after a while.....no matter the load.
                              by Francesc V.
                              A friend of mine bought this inverter in Amazon and never test it........now that the warranty is over, he decided to use it.
                              The inverter starts working (I am using a 100W load). It works for about 1 minute and then it stops and reboots..........1 minute more and so on. Let's say that is partially working.
                              I thought it was a feedback topic, so I replaced the opto (PC817) with same result.
                              Measuring the opto collector (pin 3) I get 5.038V coming from a 78L05
                              Measuring the opto emitter (pin 4) I get about 5.055 when it's working and decreases about 5.038...
                              02-19-2026, 12:50 PM
                            • Tynan Dill
                              by Tynan Dill
                              Assuming...
                              11-22-2024, 01:46 PM
