Fix for Benq FP737s 17" (Q7T3)
  • EGuevarae
    • Nov 2008
    • 1336
    Re: Fix for Benq FP737s 17" (Q7T3)
    Originally posted by vicrowley
    Hi Dave,
    I have recently been given one of these Benq 17” monitors, but only because it had died. I'm only an amateur dabbler in electronics, and I think I've just about been able to follow most of your circuit mods, and the reasoning behind them. Now I know from the dates on the posted articles, it was some time ago you were working on this monitor, but I was wondering if you now have a final definitive modification list, and final circuit diagrams. I ask this as reading through the various posts, you were obviously developing and changing things as you found new problems, and from reading through, it is hard to be sure I'm using your final solution for all the mods.
    PS. I hope I've entered this in the right place, I'm new to this forum.
    Vic
    Welcome to the forums.
    While the post is in the right place, you might want to PM davmax directly.
    There are 10 kind of people in this world: those that understand binary, and those who don't.
    • ASUS ROG Maximus IX Code
    • Intel Core i5-7600K 3.8GHz
    • 16gb GSKILL TridentZ RGB DDR4-3200
    • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
    • Windows 10 Pro x64
    • GeForce GT1050
      2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
    • vicrowley
      • May 2009
      #222
      Thanks, will look and see how to do that.
      Vic
      • davmax
        • Dec 2005
        • 899
        #223
        In response to a request for the final modification details
        I have made this easy by posting the final versions at an online album here: http://picasaweb.google.com.au/davmax60/MonitorRepairs#
        Use the full screen facility to see the detail.
        Please note that there are two versions of current sense resistor, either a single resistor or two in parallel. Therefore the photo of the board underside shows the 0.082 ohm resistor version (alternately this resistor would be 0.56 ohm). The photo of the upper board shows the position of the 0.1 ohm resistor.
        160Gb WD SATAII Server grade
        Nvidia 8500GT 256Mb
        Samsung 18x DVD writer
        33 way card reader
        Windows XP Pro SP3
        17" Benq FP737s LCD monitor
        • davmax
          • Dec 2005
          • 899
          #224
          I feel I should add that to achieve the modification I describe you will need all the tools.
          A soldering iron and self fluxing solder.
          A PCB drill and bit 0.8 - 1 mm
          A sharp knife to cut tracks.
          Nvidia 8500GT 256Mb
          33 way card reader
          Windows XP Pro SP3
          • vicrowley
            • May 2009
            #225
            Thanks for the advice, and as far as the actual work of the board is concerned, I'm fairly confident on that score. In the past when I used to work for my living (now retired), I was for a few years in a data collection lab, and soldering strain gauges, some of which were only thirty thou long, and that included the two solder tags. So we had to work under a 30 to 1 microscope. I guess that's why I now need glasses. So like say the physical stuff I can deal with, it's the technical working of these modern electronics I know nothing about. It's all black boxes (Chips), and unless I know what each of these does and how it achieves it, I'm lost. So thanks for doing all the hard work, and I'll let you know once I've completed the task, if my confidence was well founded or not.
            Vic
            • Lim Yong Seng
              • Jun 2009
              #226
              Hi Everybody,
              Thanks all of you for the useful postings which help me to repair a BenQ FP731.
              It does not have any display with the green LED stays on.
              Things done
              1. Replaced fuse (BEL MS 3A), PF751 is open-circuit. I used a 2A pico fuse because I do not have a 3A fuse on hand.
              2. Solder inverter transistors (2SC5707), Q739, Q740, Q759 and Q760. The solder cracked when I moved these 4 transistors.
              3. Solder power MOSFETs (FU9024N), Q743 and Q751. The solder cracked when I moved these 2 MOSFETs.
              4. Solder transformers, T751, T752, T753 and T754. No solder cracked, just re-solder to prevent dry joints.
              5. After power on, left half of the monitor displays information correctly but right half has pink background with a continuous black line in the centre of the screen.
              6. Remove the two flex-cables and clean the contacts (dirt found) with alcohol.
              7. Power on and the monitor is in working condition.
              Once again, thanks all you for the important information.
              Have a nice weekend...Yong Seng
              • EGuevarae
                • Nov 2008
                • 1336
                Originally posted by Lim Yong Seng
                Hi Everybody,
                Things done
                Congratulations, and welcome to Badcaps.Net!
                • GeForce GT1050
                • enterthehatrix
                  • Nov 2008
                  • 8
                  #228
                  Hey guys.
                  Got all my monitors working except one, which virtually burst into flames.
                  The good news is that the LCD and the little VGA board still work.
                  Has anyone else tried to manually power this up? I intend to use the screen as a light weight portable screen backlit by LEDs and powered by batteries (if possible)
                  Could someone try this and if it works, could they do a diagram of the VGA board and point out which pins require what voltages, etc?
                  On the schematic, it has BLT_ON and BOLT_ADJ which I assume is the backlight, PW_DOWN (no idea), Volume On/off and volume (not used), GND, P12V, P3.3v, +3.3v, and +5v
                  What's the difference between P3.3v and +3.3v?
                  • Caloute
                    • Jun 2009
                    #229
                    Go the parts from ebay (Actually bought 2 sets), replaced all 7 parts.
                    Before it was completely dead, now with the new parts, it actually shows benq logo, or destop image, but just for 2 seconds and then nothing. Any idea?
                    I kind of gave up, so if anybody from Australia is interested in buying the parts, or the screen for further part such as casing etc...I suppose the screen is still good...
                    Anyways let me know.
                    • EGuevarae
                      • Nov 2008
                      • 1336
                      Resolder the transformers and other common solder points (see all the thread). You'll be fine.
                      • GeForce GT1050
                      • fety
                        • Jan 2007
                        • 27
                        #231
                        LOOK people! 9 times out of 10, Cold solder joints DO exist on the board. Looky what I found on mine! BE SURE TO REMELT OR (better yet) RESOLDER THE TRANSFORMERS!!!
                        btw, this is from a Dell E172FP / E172FPb
                        • fety
                          • Jan 2007
                          • 27
                          #232
                          Well CRAP!! It didn't work! I got the kit on ebay and replaced all 7 parts and resoldered the transformers as well as resoldered a few other suspiciously lame looking solder joints. Nothing shows up on the screen now, just the power LED blinks about every 1.5 seconds AND I can hear a faint tick sound. Like what HelpQuick experienced... What is this a symptom of? what can I try next? replace all/most of the caps? Btw, I'm not an electrical guru, I just have a A. W. Sperry AMM to work with so don't ask me to test this or that if I'm not capable of doing so. Thanks
                          HEEEEELLLLLLLLP!!!!!!!!
                          • PlainBill
                            • Feb 2009
                            • 7034
                            That ticking sound is a symptom of the power supply shutting down and restarting. Have you checked the transistors you installed?
                            PlainBill
                            • fety
                              • Jan 2007
                              • 27
                              #234
                              PlainBill
                              Check them, how? they're brand new...from the 7 piece kit on eBay. Would they fry instantly? Solder looks good.
                              • PlainBill
                                • Feb 2009
                                • 7034
                                Use an ohmmeter.
                                Yes, they can short instantly if the problem that caused them to short is still present.
                                PlainBill
                                • steven.va
                                  • Jun 2008
                                  • 8
                                  #236
                                  Hi All,
                                  I got a Benq 17" Q7T3 TFT like you all.
                                  It had it's two 2SC5707 shorted, FU 9024n shorted, 3A fuse open.
                                  So far I have replaced the fet with an IRF9540, wich according to
                                  my suppier is a good replacement.
                                  I replaced the two broken 2SC5707's with TIP132. I know this is not good, however it was the only thing I could get my hands on...
                                  Resoldered the transformers, resoldered other suspicious joints too.
                                  Powering the TFT up:
                                  Well: it did not go up in smoke
                                  Backlight works, and it shows the "Benq" logo. Went out after 4 seconds.
                                  I Tried that again:
                                  So I connected a PC and it showed the window desktop just fine, but again, the monitor shutted itself down after a few seconds (faster every time)
                                  Things tried with data cable disconnected:
                                  - Connected CCFL lamps to inverter 1 (the good one)
                                  ---> Screen is lit, shuts down after a few seconds
                                  - Connected CCFL lamps to inverter 2 (the repaired one)
                                  - Connected CCFL lamps to inverter 1 & 2
                                  However: when feeling at the TIP 132 transistors they get HOT.
                                  I can barley touch them with my hands.
                                  ....while the two remaining 2SC5707 are actually cool running.
                                  Is the TFT shutting down because of the improper transistors used, or is there another fault I can check that overheats the TIP 132's
                                  Should I swap the two remaining good 2SC5707 with TIP132 too just to see that they overheat too or not?
                                  Greetings and thank you in advance!
                                  S.
                                  • Bobdee
                                    • Jun 2008
                                    • 461
                                    #237
                                    You need to go with 4 of the 2SC5707s or 4 of others, but the TIPs are known to run hot (not recomended)
                                    • steven.va
                                      • Jun 2008
                                      • 8
                                      #238
                                      Could that explain the shutting down of the inverter after 4-5 seconds?
                                      Greetings,
                                      S.
                                      • Bobdee
                                        • Jun 2008
                                        • 461
                                        #239
                                        Yes in one
                                        You need to go 4 of same type
                                        Easy and quick to get 2SC5707s on ebay
                                        • steven.va
                                          • Jun 2008
                                          • 8
                                          #240
                                          My 2SC5707s arrived. Soldered them in, and my Benq FP731 works!
                                          I did resolder the connections to transformers.
                                          Greetings,
                                          Steven
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
