Fix for Benq FP737s 17" (Q7T3)
  • Bobdee
    • Jun 2008
    • 461
    #201
    Re: Fix for Benq FP737s 17" (Q7T3)
    Hello Cliffpage
    The transistors can be tested in circuit, also the voltage on fuse is no problem ( I believe )
    Try these links they should help
    http://www.kpsec.freeuk.com/components/tran.htm
    https://www.badcaps.net/forum/showpo...1&postcount=96
    https://www.badcaps.net/forum/showpo...&postcount=104
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Originally posted by cliffpage
      I note the fuse is 125v 3amp. is the voltage actually important on a fuse. I thought from my physics lessons at school (over 30 yrs ago) that all that mattered on a fuse is the current (amp). would it make any difference if i used a 250v 3a fuse?
      Should be fine as long as you don't replace a fast-blow with a slow-blow or something like that.
      Volts on fuses is (I think) how much they can go up to without arcing.
      Lesser volts is fine.
      Mann-Made Global Warming.
      - Dr Seuss
      • cliffpage
        • May 2009
        • 6
        #203
        thanks for replies. I got 6 of these model of monitors from a pile of rubbish being chucked out of some offices. they all have labels on them saying faulty, but one of them seems to work fine (perhaps an intermittent fault?). i dont have much time at the monent to work on them but will get around to taking them apart someday to gibe me the 'challenge' of fixing thwm
        • Bobdee
          • Jun 2008
          • 461
          #204
          Duhhh nice one, something to look forward to
          good luck
          • mecklan
            • Oct 2008
            • 5
            #205
            I have here a Benq 767 and have replaced 2x C5707, 1x FU9024n and 1x fuse MS3A. The backlight is working again, but it is not switched off, so even in the standby mode on. What can still be broken? Someone an idea?
            • Bobdee
              • Jun 2008
              • 461
              #206
              Re-check the 2x FU9024Ns they can be the cause of the Backlights staying on
              • diabolik_0ne
                • Feb 2009
                • 5
                #207
                hi, i have a benq monitor lcd fp737 , i've just change the some capacitor and the fuse,
                now it swicth on but the screen is white, no image visualizze
                i need help please
                • Bobdee
                  • Jun 2008
                  • 461
                  #208
                  i need help please
                  First check your lead from mainboard to panel ,this can be easily unseated or left off in some cases when monitors have been opened.
                  Also if that not problem check tiny fuse on panel (not much bigger than pinhead in most cases) that is under metal plate at top of screen
                  • diabolik_0ne
                    • Feb 2009
                    • 5
                    #209
                    sorry for my last information it' no complete.....
                    i,ve just change the pico-fuse on mainb 3 amp. the lamp swicht on ,the screen only white colours....nothin image visualizze , i need to change other components??
                    • Bobdee
                      • Jun 2008
                      • 461
                      #210
                      Not sure that I understand that last post,
                      but when the panel fuse is open the Backlights (lamps as you call them) do come on to give you white screen but no visual image,
                      So a dead panel fuse leaves you with white screen (lamps on) no image
                      • diabolik_0ne
                        • Feb 2009
                        • 5
                        #211
                        the lamp are light on... and the screen i see only white color if i connect the vga cable the screen to the pc i don't see any image i see only white colour
                        • Bobdee
                          • Jun 2008
                          • 461
                          #212
                          yes I do understand that, those are the symptoms of the PANEL fuse dying so check panel fuse first to see if that is your problem, If the panel fuse is OK then the problem will be mainboard, but I and a few members have repaired this problem on various monitors just by replacing the usual 1 amp fuse on the panel (not the power or mainboard the Panel board)
                          • diabolik_0ne
                            • Feb 2009
                            • 5
                            #213
                            now i repeir a benq model t905 i change two 5707 and the fuse 3 amp ....the Backlights now are ok and visualizze image ....but when i turn off to the power button....the Backlights still light on ....why?? if i turn off the monitor i cut the corrunt cable ...some help me please.
                            • Bobdee
                              • Jun 2008
                              • 461
                              #214
                              Check the 2 fets out for shorts (FU9024Ns) they look the same as the C5707s and they will be near to them
                              read this by Krankshaft it will help
                              https://www.badcaps.net/forum/showpo...&postcount=240
                              • diabolik_0ne
                                • Feb 2009
                                • 5
                                #215
                                while i been waiting your answer ..i try by my multimeter tester to measure and i found the fq11p06 short..so in this condition the backlights is always on , also the power button is off
                                i think to have the same problen in both monitor
                                well i hope to solved this problem ..and thank you very much for your help
                                • EGuevarae
                                  • Nov 2008
                                  • 1336
                                  The shorted FU is the cause for your always-on backlight. The one with the white only display is another story, as it will be the input fuse almost for sure as Bobdee said. if the Fuse is OK, then you will have a bad LCD panel.
                                  There are 10 kind of people in this world: those that understand binary, and those who don't.
                                  • ASUS ROG Maximus IX Code
                                  • Intel Core i5-7600K 3.8GHz
                                  • 16gb GSKILL TridentZ RGB DDR4-3200
                                  • 1 M2 SSD + 2 WD Blue 1TB (Mirrored)
                                  • Windows 10 Pro x64
                                  • GeForce GT1050
                                    2 x Acer KA240H + 1 Vewsonic VP2130 21 (a cap replacement job )
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    Hehe FU how ironic.
                                    Think the component is telling you something ?
                                    • Bobdee
                                      • Jun 2008
                                      • 461
                                      #218
                                      Originally posted by Krankshaft
                                      Hehe FU how ironic.
                                      Very sharp, cant stop laughing, nice one
                                      • EGuevarae
                                        • Nov 2008
                                        • 1336
                                        Yes. It is ironic indeed, a FU FU component...
                                        "You must replace the FU."
                                        "Which one?"
                                        "The one that is FU..."
                                        • GeForce GT1050
                                        • vicrowley
                                          • May 2009
                                          #220
                                          Hi Dave,
                                          I have recently been given one of these Benq 17” monitors, but only because it had died. I'm only an amateur dabbler in electronics, and I think I've just about been able to follow most of your circuit mods, and the reasoning behind them. Now I know from the dates on the posted articles, it was some time ago you were working on this monitor, but I was wondering if you now have a final definitive modification list, and final circuit diagrams. I ask this as reading through the various posts, you were obviously developing and changing things as you found new problems, and from reading through, it is hard to be sure I'm using your final solution for all the mods.
                                          PS. I hope I've entered this in the right place, I'm new to this forum.
                                          Vic
                                          • eccerr0r
                                            inverter H tree driver imbalance in an AC inverter
                                            by eccerr0r
                                            My cheap crappy 1KW grid tie inverter (GTI) seems to keep blowing IGBTs. When I first got it, it had two failed IGBTs. It used four 60N100's (TO264). I bought 5 from a dubious source (fleabay) and replaced just the two that were dead. The GTI worked for almost two years but recently one of the two that I replaced failed. Since I had three spares, I replaced the dead one. Then a few weeks later it failed again. Weird. Well since I bought dubious China-sourced IGBTs from fleabay it could very well just be a mixture of fakes. I replaced it, but then a day later it failed again! I put in the last...
                                            11-16-2025, 12:34 PM
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
