Fix for Benq FP737s 17" (Q7T3)
  • imalearner
    • Apr 2010
    • 38
    #241
    Re: Fix for Benq FP737s 17" (Q7T3)
    Originally posted by steven.va
    My 2SC5707s arrived. Soldered them in, and my Benq FP731 works!
    I did resolder the connections to transformers.
    Greetings,
    Steven
    Greetings to all on this very informative forum. I'm cutting my teeth as a hobbyist in this field of work and I have stumbled upon your website. It's so jammed packed full of info on this particular monitor, that I am about to blow a fuse myself!!! Some of the mods may be outside of my skill level at present but hey, we all start somewhere right? Not sure exactly where I should start but if anyone could kindly point me in the simplest of terms, I would be very grateful. Thanks in advance.
    My symptoms....monitor turns on momentarily, enough to see a flash of the Benq Logo, then it shuts off ......and the green power light goes out too. Now I hope this is enough for a simple solution........but since this monitor seems to have a whole history of poor design...maybe I shouldn't hold my breath.
    All replies welcome.
    • PlainBill
      • Feb 2009
      • 7034
      It's teh same problem as found on any number of these monitors. Starting at the beginning of the thread may have given you this information.
      After replacement 4x2SC5707 2xFU9024 and the fuse 3A all was well again. I resolder joints on the inverter transformers.
      In your case,check the 2SC5707's. If any are shorted, replace the lot; likewise for the FU9024. Because you are getting the flash, the fuse is good. Also, resolder the transformers; that was the original cause.
      NOW it may be that the transistors are fine. Then check the output voltage of the power supply; if good, see if the monitor comes on when you push the power button.
      Oh, pictures help. See the FAQ on inserting pictures.
      PlainBill
      • imalearner
        • Apr 2010
        • 38
        #243
        PlainBill
        Thanks PlainBill for that. My eyes see much less now than my camera can, so I'll post these anyway. I don't have a history for this monitor/board, but it looks overall, like the whole board solder connections are in some state of corrosion, or overheating perhaps....I dunno. Might be better to reconsider replacement of the whole board rather than repair?
        Any comments gratefully accepted.
        imalearner..
        xx pics upload failed twice xx Will try again later!
        • imalearner
          • Apr 2010
          • 38
          #244
          So here they are...I hope!
          • PlainBill
            • Feb 2009
            • 7034
            I believe the site has a limit of 2000 pixels on a side. My camera takes pictures at a resolution of 2278 x 1712; too big to upload. I've found that reducing the pictures to 1024 x 720 gives a large, usable picture. Yours are almost too small to be helpful.
            First step, I have marked up the usual suspects for this monitor. Check the transistors I have circled to see if any are shorted. I've also circled what I believe is a picofuse; the identifier is too small to read. Verify that is intact.
            PlainBill
            • imalearner
              • Apr 2010
              • 38
              #246
              PlainBill
              Thanks PlainBIll for getting back. I'll be testing away as soon as I get back to my workshop/shed. Thinking that the upload failed last time because the images were too big....I just resized them. It may also have been just a poor wirelesss signal from my shed too! So, I'm putting this one back up just to see if that is more helpful....for future enquiries perhaps. This is max size for my camera. Hopefully part identifiers should be more legible. Fingers crossed.
              Cheers,
              Imalearner
              • PlainBill
                • Feb 2009
                • 7034
                Cheers,
                Imalearner
                Great picture. the only flaw is the board is rotated slightly counterclockwise. I'll give it a 9.6.
                PlainBill
                • imalearner
                  • Apr 2010
                  • 38
                  #248
                  PlainBill
                  Hey hey! Thanks on that PlainBill. You'd be amazed at what I can achieve with your patients
                  Now with your continued kindness (creep creep) I wonder if you can help a little further???
                  Should (can) I test any/and all of these components on/off the board, and furthermore, with my digital meter in hand, what test(s) should I be puttting them thru/to?
                  Imalearner by name....and by nature....
                  Thanks again in advance.
                  Imalearner.
                  • PlainBill
                    • Feb 2009
                    • 7034
                    Imalearner.
                    These transistors and the fuse can be tested on board. Set the meter to the lowest ohms scale (typically 200 ohms). The transistors have three pins in a row; starting at the left number them 1-3. Check the resistance between 1 and 2; 1 and 3, and 2 and 3. All readings should be > 1K Measure the resistance of the fuse; it should be less than 1 ohm.
                    PlainBill
                    • imalearner
                      • Apr 2010
                      • 38
                      #250
                      PlainBill
                      Thanks PlainBill. PLaytime starts agin early next week so I'll give it a shot.....I have noticed that the odd two transistors are not bearing the same id/specs so I may be hunting for their identity too! Will get back and thanks again.
                      imalearner
                      • imalearner
                        • Apr 2010
                        • 38
                        #251
                        imalearner
                        Back again!
                        Okay, so off came the four C5707 (faulty enough for me!) and then the two unidentified others, but I am not sure how to read the markings/codes on them....any offers out there please, or suggestions about what I could use instead. Thanks.
                        I have used a few shots for different light to 'catch' the markings better...some might find these a useful help....these were taken about 4-6mm away from the transistors. At one point I think I fainted to stopped movement whilst breathing
                        imalearner.
                        • Bobdee
                          • Jun 2008
                          • 461
                          #252
                          Back again!
                          imalearner.
                          This will do it
                          http://cgi.ebay.com/LOT-2-FU9024N-IR...-/320492401104
                          • imalearner
                            • Apr 2010
                            • 38
                            #253
                            Originally posted by Bobdee
                            AHaaaa! Thanks for that Bobdee......I see it's coming from the states. So, my next question is (being a novice at this...) do you know if the following products, I have found based from the uk, are also suitable/safe to do the same job?
                            http://uk.farnell.com/international-...01?Ntt=FU9024N
                            http://uk.farnell.com/sanyo/2sc5707/...251/dp/1554597
                            Thanks for help.
                            • pedro
                              • 199
                              • AUSTRALIA
                              #254
                              Thanks for help.
                              Yep, they are fine. Farnell may not be the cheapest source, but the semis they supply are invariably from a decent manufacturer.
                              Friends don't let friends buy Samsung ....
                              • imalearner
                                • Apr 2010
                                • 38
                                #255
                                Thanks Pedro for that.
                                I have just given Farnell a ring. Guess what? "If paying by debit card/credit card... online there is a minimum order of 20.00 Pounds Sterling.....if over the telephone it goes up........30.00 Pounds Sterling."
                                I said, thank you very much I'll think about it!!!
                                fffffffffffffffffffffffffffffff**************or goodness sake! I'm 'orf hunting for somewhere else a liitle more customer friendly.
                                Thanks again though.
                                imalearner
                                • pedro
                                  • 199
                                  • AUSTRALIA
                                  #256
                                  imalearner
                                  Shite that's obscene. Down here in Oz, Farnell's minimum for on-line CC purchase is $A10 - about six pommy quid - AND we get free shipping. Ironically I currently have some Pana FM's ordered from them en route from UK. And I had to pad the order with other stuff to make the $10.
                                  • Bobdee
                                    • Jun 2008
                                    • 461
                                    #257
                                    imalearner
                                    This may help
                                    http://cgi.ebay.co.uk/Lot-4x-C5707-2...item43979fcc08
                                    I have never had a problem buying these from ebay dealers
                                    • imalearner
                                      • Apr 2010
                                      • 38
                                      #258
                                      This may help
                                      OH Bollacks! I got sick of searching on ebay uk and all I kept coming up with is the exact same thing wtih free international satandard shipping from good ol USA....so now they are ordered.
                                      Mmmmmmmmmmmmmmmmmmm, me thinks I should find practice my soldering or summat!
                                      Cheers!
                                      Imalearner
                                      • Radio Fox
                                        • Jan 2010
                                        • 281
                                        ...I have just given Farnell a ring. Guess what? "If paying by debit card/credit card... online there is a minimum order of 20.00 Pounds Sterling...
                                        I normally order from RS, but there was a few things on my list that were not in stock, so tonight, for the first time, I wasted an hour or so compiling my first order with Farnell. It wasn't until I tried to order (after going through all the registration process), that I was told that my order needed to be over £20 before VAT (= £23.50).
                                        Also, I couldn't find anywhere on their website that told you the p&p charges.
                                        I didn't go through with the order.
                                        ________________________________________________
                                        Invisible airwaves crackle with life
                                        Bright antennae bristle with the energy
                                        • sam67
                                          • 256
                                          #260
                                          I know how you feel i ended up ordering some op amps from usa as over here they wanted to charge me 12 quid for £1.45 parts ,needless to say i got them from the states 3 of then inc shipping 5 bucks ..you cannot argue at that now i have 2 spare if i ever blow the other speakers lol.
                                          • x_orange90_x
                                            Vizio E55-E1 bad backlights or bad inverter?
                                            by x_orange90_x
                                            I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                            I don't know how exactly to test the inverter itself. Is it...
                                            01-29-2025, 09:24 PM
                                          • Gentian
                                            APSINT3636VR 3600W APS INT Series 36V DC 230V AC Inverter/Charger schematic
                                            by Gentian
                                            I have a tripp-lite aspint 3636vr inverter charger which blow some of mosfet transistors. I replaced them repaired also the driver circuit and tested but the mosfets burn again.
                                            It work very well as inverter and also as charger if I let the rear switch in auto mode (inverter) and charger only(charging) but in auto when I connect the feed line 220V AC first time it pass ok to line and start charging the batteries but when I remove the feed line it pass to inverter mode and if I do it again the second time when passing from charging to inverter the Main transformer start making a...
                                            03-06-2023, 07:07 AM
                                          • valvashon
                                            Insignia NS-LCD19-09 (PS OK, Inverter problem?)
                                            by valvashon
                                            For some reason I'm just not going to let this 19" TV defeat me. I guess because I have a schematic to work from I feel like I'm oh so close.
                                            History- while adding a turn-on circuit I let a small screw roll under the power board. Worked through all of that circuitry, probably replacing a MOSFET and PWM controller that were not bad but I was following the service manual. Finally figured out that the power supply is in working order when the inverter section (for the backlights) is disconnected. When the +12 supply to the inverter is disconnected the +12 and +5 will come up...
                                            01-04-2024, 01:44 PM
                                          • eccerr0r
                                            A modified sine wave inverter + a grid tie inverter?
                                            by eccerr0r
                                            If I had a solar fed grid tie inverter (GTI), a modified sine wave inverter, and a power outage occurred, what would happen if you disconnected mains, backfed the modified sinewave inverter (MSI) into house power, and hooked up the GTI to the output of the MSI, would it work?
                                            Next thing is trying to charge the batteries using solar power, but that's another issue ...
                                            08-31-2023, 09:14 PM
                                          • caseyjay_48
                                            Sony KDL-46BX450 Inverter Troubleshoot Logic
                                            by caseyjay_48
                                            I am currently on a troubleshoot of 46” Sony KDL-46BX450 tv. I came back from Washington to Texas on medical emergency and had to leave all my tools up there. All I have is a couple of screwdrivers and a dvm. I wish to ask the community a troubleshooting question. Please forgive stupid questions as meds I am taking produce brain fog.
                                            I have well maintained Sony KDL-46BX450. It went black one day. After turn-on, I get solid green light and Sony logo in screen center for about 1-2 seconds, then black. No blinking LEDs, no hissing. Flashlight test shows screen characters dimly viewable,...
                                            09-23-2022, 08:08 PM
