Electronic spider repeller not working
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    Re: Electronic spider repeller not working
    sorry but i dont see fixing something that does nothing other than raise the electric bill a bit.
    sigpic
    (Insert witty quote here)
    • Newbie2
      • Sep 2005
      • 885
      Instead of fixing this electronic device that has never been actually proven to work, just call a good exterminator and let them inspect your spider problem.
      This might be good to learn about troubleshooting and repairing electronics, but that device probably will not solve your spider issue.
      My gaming PC:
      AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
      ASUS M4A77TD AMD 770 AM3 Motherboard
      PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
      G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
      TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
      WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
      ASUS Xonar DG 5.1 Channel PCI sound card
      Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
      Antec Three Hundred Mid-Tower Case
      Microsoft Windows 10 Pro 64-bit
      Microsoft Windows 7 Ultimate SP1 64-bit
        master hoarder
        • May 2008
        • 12168
        • Bulgaria
        And I used to think that spiders are harmless (Black Widow and Tarantula aside)...
        A few articles about the brown recluse said it's common in the Midwest and SE states. That puts me somewhere near the border more or less. I guess I'll just try to avoid spiders that look like it next time.
        Spiders were always very common in the house where I grew up, so that's likely why I'm still indifferent to them, though.
        • gdement
          • Jan 2007
          • 690
          Originally posted by momaka
          There's also one spider in the basement that caught a mid-sized centipede - and those just look nasty. Of course if it's one of those spiders with big, hairy and round bodies, I won't keep it either (I still don't kill it though).
          Worst bugs are roaches. If you have those don't count on some electronic gimmick-of-a-gizmo to get rid of them. Call an exterminator immediately. Same goes for termites.
          I think centipedes are the nastiest insects I've ever seen. I hate those things.
          We had a neverending supply of roaches in Florida. It was just a fact of life that they were rampant in that area. Never had many in other places we lived.
          • mrs sumner
            • Sep 2009
            • 8
            Ok - so what if it's snake oil? I sleep easier for having it.
            I would like to point out that I don't have an infestation of spiders (or anything else) in the house at the moment. So getting the house fumigated would not really help. The device is supposed to stop the spiders coming in. That's all .
            Anyway, back on topic. I have removed the zener diode now marked in yellow and red, and tested it on my DMM, on the diode setting, both ways. I get readings of 001 in both directions. So I think I may have found the culprit. (Tested another similar looking diode on the PCB and got 001 in one direction and 717 in t'other).
            The question now is where can I get another diode? The lettering on it is "1N4740A" with "5T" underneath.
            Any help is much appreciated. Thanks.
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              http://www.fairchildsemi.com/pf/1N/1N4740A.html
              • mrs sumner
                • Sep 2009
                • 8
                #27
                Thanks - I think I've managed to order some from Farnell in the UK (free postage), so we'll see what turns up in the post.
                Fitting it is probably going to be another matter, but I'll let you know how I get on.
                • mrs sumner
                  • Sep 2009
                  • 8
                  #28
                  Fitted the new diode last night, then soldered the speaker wires and power leads back.... and....
                  IT WORKS!
                  (Well, the lights come on, and the test button emitts a sound, whether it will work as a repeller has already been debated on here!)
                  Thanks guys... I owe u
                  • skystormfarms
                    Banned
                    • Mar 2011
                    • 160
                    #29
                    the cap's if i am right in electronic's will fillter out all the signal's it send's out
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      #30
                      Originally posted by mrs sumner
                      IT WORKS!
                      Good job. If it fails again, use one with a higher power rating.
                      A working TV? How boring!
                      • c_hegge
                        • Sep 2009
                        • 5219
                        Originally posted by kc8adu
                        for anyone who doubts the danger of the brown recluse just do a google search for brown recluse bite.
                        I did that, but I wish I hadn't. They look gross
                        FWIW, I HATE spiders too (and kc8's new avatar gives me the creeps). I remember the fright I got when I saw one the size of a dinner plate.
                        • c_hegge
                          • Sep 2009
                          • 5219
                          Actually, it looks similar to a white tailed spider bite.
                          • Scenic
                            o.O
                            • Sep 2007
                            • 2642
                            ehm.... did anyone look at the date of the last post (#28) in this thread..?
                            • Th3_uN1Qu3
                              Believe in
                              • Jul 2010
                              • 6031
                              • Romania
                              #34
                              I guess skystormfarms didn't.
                              • joshnz
                                • Feb 2011
                                • 969
                                • New Zealand
                                #35
                                new members that are not forum literate. That been said when I was new to forums I myself dug up the grave of many topics and posts till I worked out why I was getting grilled
                                On this side topic of spiders I love them but the sad thing is now white tail and red backs are in my town and one of them are in my house somewhere I know this I had 2 bites in as many years they are nasty.
                                My pc
                                CPU : AMD PHENOM II x4 @ 3.5Ghz
                                MB : ASUS M4A89TD PRO USB3
                                RAM : Kingston ValueRAM 16gb DDR3
                                PSU : Cooler Master 850W Silent Pro
                                GPU : ATI Radeon HD 6850
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  #36
                                  not sure whether the funniest part of the thread was the op fixing a spider repeller or it getting dug up from the dead.
                                  • Uranium-235
                                    Comrade Glimmer
                                    • Aug 2007
                                    • 5042
                                    • US
                                    #37
                                    Originally posted by Topcat
                                    Tell that to the people who have been permanently scarred and disfigured from brown recluse bites....
                                    true. infact I was almost in that group but some smart doctor decided to use anti-leperacy medicine on the bit when I got bit (when I was like 7). and and healed without a scratch
                                    regular spiders are good, they do keep the more annoying bug populations down, but if you see a reculse or widow (saw tons of widows in mansfield). kill it
                                    • Agent24
                                      I see dead caps
                                      • Oct 2007
                                      • 4928
                                      • New Zealand
                                      #38
                                      I just throw any dangerous spiders I find out the window
                                      -David VanHorn
                                      • PCBONEZ
                                        Grumpy Old Fart
                                        • Aug 2005
                                        • 10661
                                        Originally posted by Wizard
                                        BUNK.
                                        Spiders doesn't have ears. They feel vibrations.
                                        Cheers, Wizard
                                        As a matter of fact ultrasonic waves ARE vibrations.
                                        That's why they call them waves.
                                        And if they could be 'heard' they would not be ultrasonic.
                                        Those things DO work - somewhat.
                                        When I lived in Washington State my house was out in the woods.
                                        We had an annual 'spider bloom' with millions of them hatching all at once.
                                        It was all through the woods, an exterminator wasn't going to accomplish a damned thing.
                                        Lasted a week or two until the babies got done eating each other.
                                        I could keep them out of the house but the garage was another story.
                                        I used on of those things.
                                        A few would come in so you'd see some but they wouldn't stay in for long. [They didn't get 'thick' in there anymore.]
                                        Mann-Made Global Warming.
                                        - Dr Seuss
                                        • PCBONEZ
                                          Grumpy Old Fart
                                          • Aug 2005
                                          • 10661
                                          I hit one in Florida with bug spray.
                                          It was big enough to hear the thump when it hit the floor.
                                          - Dr Seuss
                                          • MMH3
                                            Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                                            by MMH3
                                            i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                                            Never ever i experienced problems with that.
                                            Now i have one 5050sff machine, where this jumper isnt working at all.
                                            I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                                            The history of the machine is that i used it in my office...
                                            03-23-2025, 09:28 PM
                                          • DynaxSC
                                            GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
                                            by DynaxSC
                                            I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
                                            There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
                                            The board is generally working now, all PCIe ports are working, Windows installs normally.
                                            However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
                                            The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
                                            03-10-2025, 12:27 PM
                                          • obelix24
                                            Macbook Air 2020 (a2179) - touch id not working
                                            by obelix24
                                            Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
                                            I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
                                            02-09-2025, 12:57 PM
                                          • hopkok
                                            Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
                                            by hopkok
                                            Hi masters, I need your help.
                                            I am working on Lenovo Legion 16ITHg6
                                            Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
                                            INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
                                            My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
                                            AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
                                            Power LED is not working as well, power button working well.
                                            UI26 ??? is there any firmware too? Powered by +3VALW_AG.
                                            Motherboard...
                                            05-04-2025, 09:35 AM
                                          • bociub
                                            laptop freezes, usb 2.0 not working, usb 3.0 working
                                            by bociub
                                            Hi there,
                                            It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
                                            Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
                                            08-25-2024, 03:44 PM
