Electronic spider repeller not working
  • Agent24
    I see dead caps
    • Oct 2007
    • 5039
    • New Zealand
    #41
    Re: Electronic spider repeller not working
    We only have 3 poisonous spiders, one of which is endangered, and none of which are very big, or really very dangerous.
    I've also read that most infections caused by spider bites aren't the fault of the spider but rather due to bacteria on the spider or a person's own skin, in fact you don't even need to be bitten by a spider, any insect will do given the right circumstances...
    -David VanHorn
    • Radio Fox
      • Jan 2010
      • 281
      We are relatively safe in the UK when it comes to spiders, but I was surprised by the number of spiders in the UK that can still give you a nasty nip.
      http://www.nhm.ac.uk/nature-online/l.../spider-bites/
      ________________________________________________
      Invisible airwaves crackle with life
      Bright antennae bristle with the energy
      • Radio Fox
        • Jan 2010
        • 281
        Originally posted by skystormfarms
        the cap's if i am right in electronic's will fillter out all the signal's it send's out
        Eh? It depends where they are placed in the circuit.
        • Agent24
          I see dead caps
          • Oct 2007
          • 5039
          • New Zealand
          #44
          I have a funny feeling that skystormfarms is a spammer of some kind trying to get his post count up.
          -David VanHorn
          • inuyasha.rules
            • May 2011
            • 43
            #45
            Originally posted by Scenic
            ehm.... did anyone look at the date of the last post (#28) in this thread..?
            I guess skystormfarms didn't.
            This threads a cockroach. When you think its dead and gone it pops back up! And yes I know im adding to the problem
            • MMH3
              Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
              by MMH3
              i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
              Never ever i experienced problems with that.
              Now i have one 5050sff machine, where this jumper isnt working at all.
              I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
              The history of the machine is that i used it in my office...
              03-23-2025, 09:28 PM
            • DynaxSC
              GIGABYTE X299 AORUS ULTRA GAMING - SATA PORTS 4-7 NOT WORKING ???
              by DynaxSC
              I have the above mentioned bord after repair, which was related to a lot of missing smd devices on the back of the board.
              There were almost 20 devices missing, caps, resistors and some diodes/mosfets.
              The board is generally working now, all PCIe ports are working, Windows installs normally.
              However I have a problem with SATA ports 4-7 (the board has 8 SATA ports) - disks are not beeing recognized by the BIOS neither by Windows (which is usually normal in case BIOS does not recognize them).
              The SATA 4-7 driver network is quite simple chipset<->buffers/drivers<->SATA...
              03-10-2025, 12:27 PM
            • obelix24
              Macbook Air 2020 (a2179) - touch id not working
              by obelix24
              Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
              I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to...
              02-09-2025, 12:57 PM
            • hopkok
              Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
              by hopkok
              Hi masters, I need your help.
              I am working on Lenovo Legion 16ITHg6
              Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
              INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
              My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
              AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
              Power LED is not working as well, power button working well.
              UI26 ??? is there any firmware too? Powered by +3VALW_AG.
              Motherboard...
              05-04-2025, 09:35 AM
            • bociub
              laptop freezes, usb 2.0 not working, usb 3.0 working
              by bociub
              Hi there,
              It is sunday and I got a faulty hp pavilion 15-cs1006na. No available schematics on the entire world. It flashed 5 long 4 short and no post then I discovered the usb 2.0 2. pin in one of the usb-a socket bent backwards and been shorted to 2. and 3. pin of the 3.0. after removing this short in the port the laptop came alive.
              Now the laptop freezing randomly. The webcam, the built in mic and according to the device manager one more thing not working which are connected to usb. If I connect anything what have usb 2.0 plug that wont work if i plug anything what...
              08-25-2024, 03:44 PM
