Macbook Air 2020 (a2179) - touch id not working
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    Hi i have one Macbook Air 2020 where touch ID is not working (it's not scanning fingerprints). Touch ID was working before, there is no error message during scanning fingerprint it's just not scanning on screen you can see only fingerprint but there are no red updates as when it's working. Power button is working fine.
    I've checked boardview and also schematics but i'm not able to find anything related to TouchID ... i have similar issue on a2338 where there was problem with PP3V0_TOUCHID​ and after replacing UT610 it was working but here i'm not able to find anything related to TouchID is it fully operated by audio board ?
  • obelix24
    • Jun 2023
    • 300
    • Slovakia
    any idea ?
    • mon2
      • 14721
      See if this helps (assuming it is not a hardware failure):
      https://www.youtube.com/watch?v=y_F_WAnxdEk
      • obelix24
        • Jun 2023
        • 300
        • Slovakia
        this is not my case as i don't have fingerprints there. when i click on add fingerprint it normally opens window with scanning but it doesn't scan my fingerprint. it's not recognizing my finger on the button itself. so to me it looks like hardware issue somewhere on the board but as i'm not able to find any traces for touch i don't know where to measure.
        • mon2
          • 14721
          How did this unit go from working to a non-working state?
          • obelix24
            • Jun 2023
            • 300
            • Slovakia
            there was water damage in audio board so i replaced it with another one and it was working some time and then it stopped (touch id) power button is responding only issue is the touch id. I'm trying to find any schematics for this audio board but nothing online
            • Darren Hibbert
              MacBook A2179 Audio board+Power button boardview & schematic needed
              by Darren Hibbert
              Hi.
              Long shot but does anyone have a schematic & boardview for the audio board+power button on a Macbook A2179?
              There is a shorted cap on mine and I need to know if I can safely remove it or whether I need to replace it and with what capacitor.
              Many thanks. ...
              08-21-2025, 02:38 PM
            • thuygsm
              Macbook Air 2020 A2179 820-01958 (5V to the USB-C port unstable)
              by thuygsm
              I have a MacBook Air A2179 in my hands that had power problems (5V to the USB-C port unstable).
              I noticed there is liquid at U3200 and U3100 and have replaced them.
              PP1V5_UPC_X_LDO_CORE : 1.575V
              PP3V3_UPC_X_LDO : 3.280V
              PP3V3_G3H_RTC: constantly fluctuating from 0.5V to 3.284V
              I have isolated R6979,
              Pin 1: 3.280V stable
              Pin 2: 0.447 (diode)
              PPBUS_G3H: 12.28V (with R6979 isolated)
              PPBUS_G3H: fluctuates 5V -> 4V -> 6V -> 12.28V(when R6979 is present), and repeats in a loop
              What should I do next?
              10-29-2025, 06:02 AM
            • Hauke
              MacBook Pro 15" A1707, 2016 - No Display and Touch Bar
              by Hauke
              Hi, I am asking for a little troubleshooting advice.
              The laptop seems to boot up fine. Caps lock is working, the touch pad has haptic feedback, and even the "charger plugged"-sound is present.
              Power consumption is about 15-30W at boot and idles at about 20W.
              Unfortunately, the display and the touch bar are completely black (No signal and no backlight).
              I don't get a signal on an external USB-C display either. Also not in safe mode.
              I noticed that only the left fan (from the bottom side, hinge on top) seems to spin up. I think...
              09-03-2025, 04:04 AM
            • conghuyms
              MacBook Air A2179 stuck logo , pls help me !
              by conghuyms
              Hey everyone,
              I’ve got a MacBook Air A2179 that got some water damage through the keyboard. Now it powers on, shows the Apple logo, but just stays stuck there — no startup chime, no keyboard backlight, and no progress bar under the Apple logo.
              When I try to boot into Internet Recovery (Option + Command + R), the mouse cursor is extremely slow and laggy — like when I lift my finger off the trackpad, the cursor keeps drifting slowly for a second or two.
              I opened it up and found some corrosion around the LED driver IC area on the logic board. I cleaned...
              11-05-2025, 08:30 AM
            • cheebster
              Macbook Air 2020 A2179 Internet Recovery and Battery Issues
              by cheebster
              Hello, i have a batch of 10 Macbook Pros A2179 bought from a Costco return wholesaler.
              The 10 of them show the exact same behavior;
              They auto power on, to internet recovery spinning globe, fans to 100%.
              Power consumption on USB-C port is 0.43a, shuts down as soon as unplugged. Battery doesn't charge at all. However, it boots to 20V on the Ampmeter.
              Based on their iBridge versions (4.x and 5.x) these were shelfed for a long time.
              All of them power on the same way; 100% fans, shut down as soon as they are unplugged. Removing...
              10-09-2024, 06:23 AM
