ESR meter upgrades
This is a sticky topic.
    • 31555
    Re: ESR meter upgrades
    here is your foto of using an LM4040 inplace of the TL431
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #702
      stj ive noticed the last few months some more of these testers have come out i wouldnt mind a colour screen version 16 mhz which one are you recomending at the minute
        • 31555
        there is only one colour unit as a kit / with software.
        there are 2 others sold in cases that look interesting - wait a while.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #704
          Cheers will do im in no rush.
          • Per Hansson
            • Jul 2005
            • 5897
            • Sweden
            #705
            Do you know if an SCR should be possible to read on the transistor tester?
            Specifically a S2514NH. (Attached datasheet).
            It shows up just as a 15ohm resistor. (I am suspecting something is wrong with the SCR).
              • 31555
              no idea, it may depend on gate current.
              i cant tell you that low gate current triacs can be tested - because i tried one yesterday.
                master hoarder
                • May 2008
                • 12182
                • Fixing stuff
                #707
                That definitely sounds suspect. Check it with your multimeter. It's essentially like a BJT with an extra diode junction on the Collector.
                See SCR Construction @ Wikipedia: https://en.wikipedia.org/wiki/Silico...r#Construction
                That said, you should get an open-circuit between Anode and Cathode terminals (A and K), and a diode Vf between Gate (G) and Cathode (K).
                Good point in asking if the TT can check this component. IIRC, I remember a picture of one showing it testing a TRIAC. Don't remember about SCR, though. I don't think I have any SCRs in my junk box so can't check.
                  • 31555
                  the test current is very limited.
                  • Per Hansson
                    • Jul 2005
                    • 5897
                    • Sweden
                    #709
                    Thanks Momaka!
                    -I get 7MΩ
                    -I get 0.036
                    I asked on eevblog too and got this reply:
                    This device is capable of recognizing Thyristors IF the gate current is <~ 5-6mA.
                    Your SCR requires minimum 20mA so cannot be recognized. Your SCR could well be OK.
                    Graham
                    I reckon it's dead, could this work as a replacement?
                    Thing sits in an electric fence controller...
                    https://www.elfa.se/en/thyristor-to-...00r/p/17201058
                    I've seen one Chinese version with a booster circuit, I assume that would then have the possibility to measure my SCR?
                      • 31555
                      the booster is voltage, not current - it's for zener diodes.
                        master hoarder
                        • May 2008
                        • 12182
                        • Fixing stuff
                        #711
                        -I get 0.036
                        That looks like a Gate to Cathode short-circuit.
                        Yup, I think it's bad. I had two big RCA 1884 SCRs from a very old HP DC power supply that were blown the same way. Also, yesterday I just pulled a TRIAC from a home food processor. Was O/C between A and K terminals with a short-circuit between the input A terminal and G :eek: . Thankfully, the IC and driving circuitry was undamaged.
                        Well, I am no expert on SCRs and TRIACs, but that looks about right. You got the same current and voltage ratings. The gate current on your replacement part is a little more sensitive, but I think that's a good thing, because then the controller should be able to drive it more easily (kind of like a MOSGET with a lower gate charge/capacitance).
                        Yes, I think I remember readings something like that too.
                        Then again, all you need to test a Zener diode is a breadboard, a few resistors, and a power supply with a high enough voltage and current.
                          • 31555
                          about swapping triacs.
                          one thing i learned the hard way - make sure you know if the original and replacement have an isolated tab or one linked to the center pin.
                          unless you want a live heatsink!!
                          • TheOnlyDocc
                            • Sep 2016
                            • 8
                            A few days ago my Tester DIY Kit arrived. But without any documentation. Only the PCB and the parts.
                            My question is if someone with the same tester can take a picture of it without the LCD installed? That would help a lot.
                            And i want to ask if it is possible to protect the tester against a charged capacitor. Or better protect the tester in case i forget to discharged a capacitor.
                            That are the parts i got from ebay (the 16Mhz crystal is still in transit but the LM4040 is already here)
                              • 31555
                              i dont know why a foto would help? all the part values are marked.
                              • Dutch52
                                Retired
                                • Aug 2016
                                • 9
                                • Netherlands
                                • Electronics, computers, Photography, making music
                                #715
                                The assembly doc and manual are attached here.
                                Perhaps reading this thread will help you further:
                                http://www.eevblog.com/forum/testgear/$20-lcr-esr-transistor-checker-project/2400/
                                  • 31555
                                  updates.
                                  because i'm probably moving soon due to gentrification and all my shit will be in storage!
                                    master hoarder
                                    • May 2008
                                    • 12182
                                    • Fixing stuff
                                    #717
                                    updates.
                                    Sorry to hear that stj . I absolutely hate moving myself. I hope you don't get dealt a bad card with that. Have you found a new place yet? (perhaps keep us updated in VIP.)
                                      • 31555
                                      no idea about anything.
                                      • Per Hansson
                                        • Jul 2005
                                        • 5897
                                        • Sweden
                                        #719
                                        Thanks for the update, finally put in a 16Mhz crystal to test it, worked fine
                                        Got any firmware built for 20Mhz too?
                                          • 31555
                                          no, it cant do it because the delays are carefully tuned for each crystal speed.
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
