ESR meter upgrades
This is a sticky topic.
  • bmht
    • Jul 2016
    • 37
    • Venezuela
    #561
    Re: ESR meter upgrades
    Originally posted by stj
    avrdude -C ../etc/avrdude.conf -c avrisp -P COM3 -b 19200 -p m328p -U efuse:w:0x04:m
    Code:
    C:\Program Files (x86)\Arduino\hardware\tools\avr\bin>avrdude -C ../etc/avrdude.
    avrdude: AVR device initialized and ready to accept instructions
    Reading | ################################################## | 100% 0.04s
    avrdude: Device signature = 0x1e950f
    avrdude: reading input file "0x04"
    avrdude: writing efuse (1 bytes):
    Writing | ################################################## | 100% 0.01s
    avrdude: 1 bytes of efuse written
    avrdude: verifying efuse memory against 0x04:
    avrdude: load data efuse data from input file 0x04:
    avrdude: input file 0x04 contains 1 bytes
    avrdude: reading on-chip efuse data:
    Reading | ################################################## | 100% 0.01s
    avrdude: verifying ...
    avrdude: 1 bytes of efuse verified
    avrdude: safemode: Fuses OK (H:04, E:D9, L:F7)
    avrdude done. Thank you.
    does it means is ok now?
    On the other hand I did not knew what OSC1 meant so I did a search downloaded the datasheet and it was pin 9 of the chip.
    Now beside my whole setup I also do that? or since apparently the fuses are now ok I do not?
    I'm kind of burned out by now lol
    Thanks again
    Update After that I inserted the reprogrammed chip into the tester and still it stays on for about 3 to 4 seconds then it turns off
    Thanks again
    Belen
    Last edited by bmht; 07-23-2016, 03:36 PM. Reason: Just tested and posting results
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      #562
      im sure stj will advise you dont add those extra parts yet as you maynot need them
        • 31557
        put in the code from the zip i posted.
        • bmht
          • Jul 2016
          • 37
          • Venezuela
          #564
          Dear sjt
          Your code only has the Hex file not an epp file still I programmed
          Code:
          conf -c avrisp -P COM6 -b 19200 -p m328p -U flash:w:Code.hex \-U lfuse:w:0xf7:m
          \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
          Reading | ################################################## | 100% 0.03s
          avrdude: NOTE: "flash" memory has been specified, an erase cycle will be perform
          ed
               To disable this feature, specify the -D option.
          avrdude: erasing chip
          avrdude: reading input file "Code.hex"
          avrdude: input file Code.hex auto detected as Intel Hex
          avrdude: writing flash (29702 bytes):
          Writing | ################################################## | 100% 32.84s
          avrdude: 29702 bytes of flash written
          avrdude: verifying flash memory against Code.hex:
          avrdude: load data flash data from input file Code.hex:
          avrdude: input file Code.hex contains 29702 bytes
          avrdude: reading on-chip flash data:
          Reading | ################################################## | 100% 20.32s
          avrdude: 29702 bytes of flash verified
          Now the LCD stays lit and nothing else happens
          Thanks again
          Belen
            • 31557
            the zip has Code.HEX and Data.HEX
            Data is the eeprom file
            • bmht
              • Jul 2016
              • 37
              • Venezuela
              #566
              Again Thank you
              I reprogrammed
              Code:
              conf -c avrisp -P COM6 -b 19200 -p m328p -U flash:w:Code.hex -U flash:w:Data.hex
               \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
              ed
              avrdude: reading input file "Data.hex"
              avrdude: input file Data.hex auto detected as Intel Hex
              avrdude: writing flash (806 bytes):
              Writing | ################################################## | 100% 1.01s
              avrdude: 806 bytes of flash written
              avrdude: verifying flash memory against Data.hex:
              avrdude: load data flash data from input file Data.hex:
              avrdude: input file Data.hex contains 806 bytes
              Reading | ################################################## | 100% 0.66s
              avrdude: verification error, first mismatch at byte 0x0000
                   0x10 != 0x52
              avrdude: verification error; content mismatch
              Got some errors
              Now back to square one the LCD lights up as long as I got the button pressed. Else it stays off
              another thing do you happen to know a cheap hv programmer that I can buy to reset the fuses of my usbasp? I know it would make more sense to buy another usbasp but I figured out if I brick more chips I got 10 attinys in here , I rather have the option available that wait for more chips and all. Besides I'm learning wich I love.
              Thanks for your feedback
              Belen
                • 31557
                your making this up as you go instead of understanding the instructions
                conf -c avrisp -P COM6 -b 19200 -p m328p -U flash:w:Code.hex -U flash:wata.hex \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
                -U flash = flash memory
                your flashing both files to the same place.
                you need -U eeprom:wata.hex
                to write the data to the eeprom
                  • 31557
                  avrdude -C ../etc/avrdude.conf -c avrisp -P COM6 -b 19200 -p m328p -U flash:w:Code.hex -U eeprom:wata.hex \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0x04:m
                  copy & paste that
                  • bmht
                    • Jul 2016
                    • 37
                    • Venezuela
                    #569
                    Really
                    Thank you for standing up with me and being VERY patient
                    Code:
                    conf -c avrisp -P COM6 -b 19200 -p m328p -U flash:w:Code.hex -U eeprom:w:Data.he
                    ed
                    Writing | ################################################## | 100% 32.81s
                    avrdude: writing eeprom (1024 bytes):
                    Writing | ################################################## | 100% 49.61s
                    avrdude: 1024 bytes of eeprom written
                    avrdude: verifying eeprom memory against Data.hex:
                    avrdude: load data eeprom data from input file Data.hex:
                    avrdude: input file Data.hex contains 1024 bytes
                    avrdude: reading on-chip eeprom data:
                    Reading | ################################################## | 100% 3.58s
                    avrdude: 1024 bytes of eeprom verified
                    OMG!!!!!!!!
                    I had almost gave up!
                    I owe you big time!!!
                    Thanks Thanks Thanks!!!
                    Now I nee to go through the calibration process
                    As I said to Vince I do know a lot about photography so if by any chance you happen to have any question regarding that you got yourself a slave hehehe
                    Thanks again!!!! Really I do not have words for you that kept up with me.
                    Belen
                    • bmht
                      • Jul 2016
                      • 37
                      • Venezuela
                      #570
                      hummm it doesn't go through the calibration procedure weird!!
                      Now my next question would I be able to upgrade it with the Markus Frejek software or some variation?
                      Thnaks again
                      Belen
                        • 31557
                        you could.
                        but first you need to learn how to calibrate it.
                        go read this.
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          • uk
                          #572
                          Thnaks again
                          Belen
                          Im glad you have made progress with your meter what issues are you having when your trying to calibrate it?
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #573
                            copy & paste that
                            stj i hope im not going to have these issues when i try to programe my spare meter as im new to programing is winavr any easier to use? as im sure i have that on a laptop i got given.
                              • 31557
                              all issues are caused by people not listening.
                              firstly, if people hooked a header to the bottom of the chip socket and programmed the chip on the tester we wouldnt be going through questions about crystals and 18-22pf caps.
                              second, if people just used a £1 USBasp and actually copy & pasted the commands i post then it would work first time.
                              we have over 3 pages now of threads because of these 2 things being ignored.
                              BTW, programming wires from chip to programmer shouldnt really be more than 10cm if you want to avoid errors.
                              building the code is another issue.
                              you need a slightly older version of GCC because the latest one builds larger files.
                              i just downloaded the latest arduino package and extracted the compiler & build-tools from it.
                              then install winavr and overwrite the gcc & tools with the arduino ones.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #575
                                I do agree with the header idea as the esr tester pcb has all the capacitors etc already fitted that what made me mention them in the first place i guess not everyone will have header in there parts box or readily available so have to order one but yes i will fit one to both of my testers.
                                regarding the calabration issues bmht might be having i had this issue where it took ages to calibrate etc and was one fuse setting wrong as youself and per had advised once i reset it was all fine and tester works great.
                                This thread may need cleaning up as you say for people just wanting to find your latest upgrades pictures etc theres a few pages too go through as there are now a few diffrent testers too.
                                Regarding the programming now we are seeing there are a lot of the kits being sold with blank ics theres going to be a lot of people unsure how to programme them, it would be great if someone had the time too upload a video/guide with step by step instructions on how to use avrdude/USBASP and add the hex files etc check the fuses and programme the ic solely to programme these esr testers as a lot of newbies like myself have probably never done programming, i have been looking for a good video guide with step by step instructions but have not found a good one.
                                  • 31557
                                  it would be good if chinese went back to surface-mount mcu's because when they do that they put the space on the board for a header.
                                  also, i'm sure a 16MHz crystal costs the same as an 8MHz one.
                                  maybe they should bundle the tester & a USBasp together.
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #577
                                    yes i agree with what you have said my old tester has the smd ic and also the holes for the header (just waiting for the angled header and the ic too come) so that tester should be fine then as my upgraded spare.
                                    Regarding my latest 2016 tester im struggling where to mount the header i was thinking about gluing it too the back of the board so its easy to run wires to the ic legs to solder etc then use some brass standoffs as legs for the tester so it sits level.
                                      • 31557
                                      across the back of the board, one row of pins on each side of the pcb
                                      glue it after you do the wires and remove the flux - no point putting glue over flux.
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        • uk
                                        #579
                                        yes thats a good idea a project for later on this week.
                                        • bmht
                                          • Jul 2016
                                          • 37
                                          • Venezuela
                                          #580
                                          Dear Vince and sjt
                                          Again thank you so much for your time and effort
                                          I'm sorry it took me this much to put the tester into operation. At the beginning I had not one but 2 USBasp's but since I was having an issue with the timing I read that I should upgrade the firmware which I did with both of them and now I do not know why they are not recognized anymore That is why I had to switch to arduino as ISP. I think I messed those both up. again it has to do with the fuses again although I burned them as indicated in this page
                                          http://blog.lincomatic.com/?p=1480
                                          Now When I try to read it's configuration I got this problem so they are useless to me now
                                          Code:
                                          conf -c avrisp -P COM3 -b 19200 -p m8 -v
                                          avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
                                               Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                               Copyright (c) 2007-2009 Joerg Wunsch
                                               System wide configuration file is "../etc/avrdude.conf"
                                               Using Port          : COM3
                                               Using Programmer       : avrisp
                                               Overriding Baud Rate     : 19200
                                               AVR Part           : ATmega8
                                               Chip Erase delay       : 10000 us
                                               PAGEL             : PD7
                                               BS2              : PC2
                                               RESET disposition       : dedicated
                                               RETRY pulse          : SCK
                                               serial program mode      : yes
                                               parallel program mode     : yes
                                               Timeout            : 200
                                               StabDelay           : 100
                                               CmdexeDelay          : 25
                                               SyncLoops           : 32
                                               ByteDelay           : 0
                                               PollIndex           : 3
                                               PollValue           : 0x53
                                               Memory Detail         :
                                                           Block Poll        Page
                                             Polled
                                                Memory Type Mode Delay Size Indx Paged Size  Size #Pages MinW Max
                                          W  ReadBack
                                                eeprom     4  20  128  0 no    512  4   0 9000 90
                                          00 0xff 0xff
                                                flash     33  10  64  0 yes   8192  64  128 4500 45
                                          00 0xff 0x00
                                                lfuse     0   0   0  0 no     1  0   0 2000 20
                                          00 0x00 0x00
                                                hfuse     0   0   0  0 no     1  0   0 2000 20
                                          00 0x00 0x00
                                                lock      0   0   0  0 no     1  0   0 2000 20
                                          00 0x00 0x00
                                                calibration  0   0   0  0 no     4  0   0   0
                                           0 0x00 0x00
                                                signature   0   0   0  0 no     3  0   0   0
                                           0 0x00 0x00
                                               Programmer Type : STK500
                                               Description   : Atmel AVR ISP
                                               Hardware Version: 2
                                               Firmware Version: 1.18
                                               Topcard     : Unknown
                                               Vtarget     : 0.0 V
                                               Varef      : 0.0 V
                                               Oscillator   : Off
                                               SCK period   : 0.1 us
                                          avrdude: Device signature = 0x00ff00
                                          avrdude: Expected signature for ATmega8 is 1E 93 07
                                               Double check chip, or use -F to override this check.
                                          Second it was the first time I has to use AVRdude, and yes I realize I do have a LOT to learn. And again I appreciate your time and effort and somehow read the manual so now I know the many mistakes I did.
                                          Since I did a lot of them I might be able to do the video to help others.
                                          Besides in the first place I shouldn't be doing all that if the chip would have come programmed as it should be.
                                          Anyway let me know if you are interested although I know about photography I do not know nothing on video editing.
                                          Thanks again
                                          Belen
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
