how NOT to apply thermal compound!
    • 31304
    sometimes you get something memorable!
  • 3d0
    • Jan 2014
    • 159
    • BiH
    Re: how NOT to apply thermal compound!
    That's a piece of art if you ask me. LOL
    • SteveNielsen
      Retired Tech
      • 2327
      It's the Three Wise Men surrounded by angels.
        • 31304
        i had a pair on a dual-cpu motherboard.
        it was so thick that the heatsinks never touched the silicon!
        and it's just standard silicon-grease - so it dried like cement!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16959
          put it on ebay, I swear Jesus's face is embedded in the goop...I'd swear to that!! Ok, maybe I don't see it, but say it any way....some dumbshit is bound to pay 10-grand for that CPU!
          <--- Badcaps.net Founder
          Badcaps.net Services:
          Motherboard Repair Services
          http://folding.stanford.edu/
          Team : 49813
          Join in!!
          Team Stats
          • goodpsusearch
            • Oct 2009
            • 2850
            • Greece
            The AMD is ok?
            • c_hegge
              • Sep 2009
              • 5219
              At least that's not Arctic Silver or something conductive
                • 31304
                athlon 2400MP - a pretty expensive cpu for some asshole to just treat like that!
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5096
                  • New Zealand
                  My first ever PC build was a bit like that... AMD Duron 1.3GHz and I thought more paste was better.. wondered why the thing always ran hot...
                  At least I knew it only had to go on the die though!
                  -David VanHorn
                  • lezsimply
                    The Wanderer
                    • 658
                    • Philippines
                    Will an old 40MB western digital still have value today?
                    • sidgallup
                      • May 2014
                      • 13
                      • mexico
                      only if its an old drive from an FBI computer with the names of all reptilians living among us, and the name of JFK assassins.
                        • 31304
                        you can identify reptilians, they hang around radiators and you never see them in the winter!
                        • lti
                          • May 2011
                          • 2558
                          HP did this in my old laptop. The thermal pad doesn't touch anything.
                          I added some crappy paste between the "heatsink" and the metal block on the right that cools an inductor. They did the same thing that they did here. There was a thermal pad next to that block that was not touching anything.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            I've seen something similar on a Pentium 4 chip (though not as memorable for sure). Of course, with the Pentium 4, you have a heat spreader so it doesn't look as bad. Nonetheless, it was, because there was a ton of leftover paste on the side of the CPU and the heatsink. The paste looked at least 1 mm thick. No wonder the CPU fan was all over the place (the motherboard was a P4SD out of a HP DC5000 - and they do actually have fan speed control).
                            By the way, sorry for reviving a thread like this. I wanted to reply to this when it was still fresh but didn't have time due to exams and now I'm going through my bookmarks and finding a few others I haven't replied to.
                            • Uranium-235
                              Comrade Glimmer
                              • Aug 2007
                              • 5045
                              • US
                              thats not thermal stuff, I just got too excited about the processor
                              • Gcnewbie
                                Dell Latitude 5570 Ambient thermal sensor reading -127 Degrees C
                                by Gcnewbie
                                Forgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
                                I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
                                My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
                                I opened the...
                                03-29-2024, 06:55 AM
                              • Veyron7887
                                Laptop overheating after replacement thermal paste
                                by Veyron7887
                                Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                                11-24-2024, 05:08 AM
                              • caspian
                                Can thermal paste cause corrosion?
                                by caspian
                                Dear members,
                                I have got an ordinary gray thermal paste that has no name/model on the box.
                                I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
                                I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
                                Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
                                Is it safe to leave the thermal paste on the pins?
                                I guess the thermal paste...
                                06-19-2020, 10:47 AM
                              • gurj1979
                                MSI GP62MVR-7RF - weird fan / thermal issue
                                by gurj1979
                                Hey guys, I need help with my personal MSI GP62MVR-7RF. Annoying fan / thermal issue.
                                Machine Idle. Fan will spin medium speed for 4 seconds, then off for 1 second. Repeat forever.
                                CPU and GPU are cold. No load, just sitting doing nothing.
                                It's clean inside, nothing blocked. New MX4 paste.
                                Updated BIOS, EC, and VBIOS but nothing's helped.
                                Schematic shows 2 thermal resistors, but they're OK.
                                All thermal signals are good, inc PCH.
                                Has anyone ever come across this ? Any idea what to do ?
                                Could it be a faulty CPU / PCH / KBC ? I REALLY don't want...
                                09-16-2024, 02:14 PM
                              • nobbnobb1
                                Fixed a Velodyne DPS-12 Subwoofer. Thermal Management + Heatsink Grounding Question
                                by nobbnobb1
                                I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
                                There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....
                                09-08-2022, 09:58 PM
