MSI GP62MVR-7RF - weird fan / thermal issue
  • gurj1979
    • Dec 2014
    • 186
    Hey guys, I need help with my personal MSI GP62MVR-7RF. Annoying fan / thermal issue.
    Machine Idle. Fan will spin medium speed for 4 seconds, then off for 1 second. Repeat forever.
    CPU and GPU are cold. No load, just sitting doing nothing.
    It's clean inside, nothing blocked. New MX4 paste.
    Updated BIOS, EC, and VBIOS but nothing's helped.
    Schematic shows 2 thermal resistors, but they're OK.
    All thermal signals are good, inc PCH.
    Has anyone ever come across this ? Any idea what to do ?
    Could it be a faulty CPU / PCH / KBC ? I REALLY don't want to replace them for guess work.
  • ugamazing
    820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
    by ugamazing
    So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
    1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
    2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
    04-10-2024, 08:06 AM
  • Spider1211
    Weird but interesting issue with DELL 3542 (intel mb 13269-1)
    by Spider1211
    Hey guys, need help fixing a weird issue with DELL 3542 with board cedar intel mb 13269-1
    Schematic from here: https://www.badcaps.net/forum/showthread.php?t=52924
    Backstory:
    Laptop came in as completely dead. I opened it and removed the top half of the casing (as well as battery) and tried to power it again and it turns on and post. I turned it off, unplug charger, plugged back in and nothing. No boot, no nothing. I tried resetting CMOS but no dice.
    Power supply draw:
    Voltage: 19.40V
    Amp draw: 0.006 - 0.007A
    Amp draw...
    04-07-2021, 03:21 PM
  • tommygun26
    Hp 6510b weird issue
    by tommygun26
    Good day people.Have hp6510b laptop with crazy issue.I can switch laptop on either under battery attached or witchout it connected to a OG charger.Have display working correctly.Can access bios menu.Memory test passed ok.Issue is i cant boot into any install media usb or Optical drive to setup Os.Quick boot menu F9 is working ok.Laptop wont boot into media just boots looping or randomly switches himself off dead just before media boot.One time managed to boot into freedos Hp bios update and flashed F16rev bios with success.That did not fixed issue.Couple times rarely like 1/40 laptop did boot...
    02-26-2023, 06:00 AM
    APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
    This started a few days ago and does this about every 8 hours
    After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
    The battery backup is about 3 or 4 years old
    Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
    06-02-2024, 02:30 AM
  • Stephen
    A2141 Weird Issue But works
    by Stephen
    Got an A2141 MacBook Pro 16" computer turns on however the track pad clicks but the keyboard has no life, NO LIQUID DAMGE whatsoever. Trackpad does click but the OS loads but the trackpad won't move the cursor, the keyboard is unresponsive. I replaced the cable and the trackpad to see if that was the issue but it was not, I went to see if the CAPS LOCK would turn on but it does not. Any indication what this is? I went and tested the lid sensor but nothing else. Battery holds a charge, fans spin normally, and lcd is good. I can use external mouse and keyboard without issue....
    05-06-2025, 10:23 AM
