Can thermal paste cause corrosion?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Dear members,
    I have got an ordinary gray thermal paste that has no name/model on the box.
    I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
    I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
    Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
    Is it safe to leave the thermal paste on the pins?
    I guess the thermal paste might contain a bit of water since it is not dry. Then, Can the thermal paste cause corrosion?
    I searched the net and I found this:
    "Some thermal pastes cause corrosion with aluminum and with copper it does bond weirdly over time."
    • 31283
    Re: Can thermal paste cause corrosion?
    "liquid metal" can do real damage,
    most paste is fine - and it's based on oil, not water
    you do want to keep it off pins though - it has capacitance.
    white spirit can liquify it so it will come off with a tissue
      Example of what some thermal paste caution:
      https://www.quietpc.com/as5
      Some also electrical conductive:
      https://timtronics.com/electrically-conductive/
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        For ic you need perhaps thermal adhesive tape or thermal glue. Unless you have other way to fix the radiator firmly to the IC,
        Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
        1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
          master hoarder
          • May 2008
          • 12175
          I've used many cheap no-name thermal pastes. Arctic Silver 5 is conductive, because it tends to contain some Silver, if I'm not mistaken. The cheap pastes, on the other hand, tend to be cheap so no Silver or other expensive elements. Instead, they tend to be silicone or oil -based, suspended in oil-like liquid. As such, they are be non-corrosive and electrically non-conductive. In fact, they have to be non-corrosive, because otherwise it wouldn't be possible to use them with Aluminum and Copper heatsinks - the last thing you want is corrosion to form on the surface of those, and then your heat transfer will be greatly reduced. Also, many of these cheaper pastes are so electrically non-conductive, that sometimes if you get it on the pins of a CPU, you may get a dead PC due to CPU not detecting due to pins not making contact in the socket.
          So you don't have to worry about cleaning the paste from the IC pins. However, if you want to, it should be fairly easy to do that with IPA (alcohol)... or Acetone in a pinch.
          • clearchris
            • Dec 2013
            • 687
            If acetone and IPA doesn't work, brake cleaner will take off nearly anything. Just don't burn (solder) the brake cleaner or it will give off very poisonous phosgene gas.
            • Andrew LB
              • Mar 2014
              • 6
              Liquid Metal doesn't cause corrosion. It's made of a mixture of Gallium, Tin, and Indium (mostly gallium) which is an eutectic alloy. If applied to aluminum, it will alloy with the aluminum, turn black, and it will literally start to crumble away. This type of thermal compound is only for use on nickel plated copper, and plain copper. I use the stuff between the integrated heat spreader and the CPU core itself. Works wonders.
              • Veyron7887
                Laptop overheating after replacement thermal paste
                by Veyron7887
                Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
                11-24-2024, 05:08 AM
              • Fobo
                What kind of Thermal Paste is this?
                by Fobo
                I bought a laptop in parts and was going to assemble it and looked on youtube and saw that it was some type of Thermal Paste on the vrams
                What kind of Thermal Paste is this on the vrams insted of thermal pads?
                the picture is taken from youtube movie
                11-22-2023, 06:20 PM
              • Jonjojonz
                dell latitude 7400 dead after thermal paste replacement
                by Jonjojonz
                hi sir, bro, i have problem my dell 7400 dead after replace thermalpaste, just blink yellow led/charging light when pwr button press n no taking current anymore, its hard to remove heatsing, just gently lift up then i put some solvent/thinner try again n wiggle it n can remove heatsing, thermal paste dry, when done assembly its dead, i do unplug battery first of course, whats wrong please help sir
                11-14-2025, 10:05 PM
              • magneh
                Liquid Metal Thermal Paste + Alienware = KO
                by magneh
                Hey guys !
                Funny one to share.
                What would be an IC replacement due to conductive thermal paste, revealed to be something more...
                Long story short, owner contacted for burned IC due to thermal paste accident, and when I put my eyes on it ... sweet god!
                Theres this liquid thermal paste everywhere under the chips... GPU, ram ic's...
                So sad...
                Someone had some kind of similar case?
                Can this be blown off with compressed air or something? or only way is lifting the BGA's?
                I can lift the ram chips and reball, but I dont have BGA...
                04-29-2020, 01:51 PM
              • corrize
                Asus Zenbook DUO UX481F – small water damage and thermal paste
                by corrize
                Hello, the laptop has a resistor cdamaged by water and dead (open line) close the charging chip. I will replace it soon.
                I found a lot of thermal paste on coils and componets close CPU.
                With meter, I saw 2,6 Ohms between ground and shunt resistor close power jack. So I guess it's too low.
                I don't find true short (0 Ohms) on the board, no coil shorted.
                I don't found bad mosfet (shorted drain-source). I found 2,6 Ohms to the « output » of the second mosfet close power jack.
                I found a coil (close CPU) at 2,6 Ohms.
                I measured between the output of 2sd mosfet...
                04-11-2022, 03:02 PM
