sometimes you get something memorable!
how NOT to apply thermal compound!
Re: how NOT to apply thermal compound!
put it on ebay, I swear Jesus's face is embedded in the goop...I'd swear to that!! Ok, maybe I don't see it, but say it any way....some dumbshit is bound to pay 10-grand for that CPU!<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
At least that's not Arctic Silver or something conductiveI love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
My first ever PC build was a bit like that... AMD Duron 1.3GHz and I thought more paste was better.. wondered why the thing always ran hot...
At least I knew it only had to go on the die though!"Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
HP did this in my old laptop. The thermal pad doesn't touch anything.
I added some crappy paste between the "heatsink" and the metal block on the right that cools an inductor. They did the same thing that they did here. There was a thermal pad next to that block that was not touching anything.Last edited by lti; 05-05-2014, 07:52 PM.Comment
I've seen something similar on a Pentium 4 chip (though not as memorable for sure). Of course, with the Pentium 4, you have a heat spreader so it doesn't look as bad. Nonetheless, it was, because there was a ton of leftover paste on the side of the CPU and the heatsink. The paste looked at least 1 mm thick. No wonder the CPU fan was all over the place (the motherboard was a P4SD out of a HP DC5000 - and they do actually have fan speed control).
By the way, sorry for reviving a thread like this. I wanted to reply to this when it was still fresh but didn't have time due to exams and now I'm going through my bookmarks and finding a few others I haven't replied to.Comment
thats not thermal stuff, I just got too excited about the processorCap Datasheet Depot: http://www.paullinebarger.net/DS/
^If you have datasheets not listed PM meComment
by GcnewbieForgive me this is my first request for help on this forum, so if i've screwed up or not followed the rules i should have i apologise profusely.
I have a Dell Latitude 5570 that was randomly shutting down, on further investigation i found that the machine had been shutting down due to thermal events as noted by windows event viewer.
My investigations lead me to the dell diagnostics screen, where i found that there were two sensors out of range which had been causing the shutdowns, one of which was the GPU thermal sensor and the other the ambient sensor.
I opened the...03-29-2024, 06:55 AM -
by Veyron7887Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
by caspianDear members,
I have got an ordinary gray thermal paste that has no name/model on the box.
I put some of this thermal paste on a 128-pin QFP IC. A bit of this thermal paste was put on pins of the IC.
I tried to clean the pins by thinner but the thermal paste cannot be cleaned from the pins properly. because the pins are tiny and the thermal paste is stuck between them.
Is it possible that the thermal paste damages pins of the IC in long term by creating corrosion or something?
Is it safe to leave the thermal paste on the pins?
I guess the thermal paste... -
by gurj1979Hey guys, I need help with my personal MSI GP62MVR-7RF. Annoying fan / thermal issue.
Machine Idle. Fan will spin medium speed for 4 seconds, then off for 1 second. Repeat forever.
CPU and GPU are cold. No load, just sitting doing nothing.
It's clean inside, nothing blocked. New MX4 paste.
Updated BIOS, EC, and VBIOS but nothing's helped.
Schematic shows 2 thermal resistors, but they're OK.
All thermal signals are good, inc PCH.
Has anyone ever come across this ? Any idea what to do ?
Could it be a faulty CPU / PCH / KBC ? I REALLY don't want...09-16-2024, 02:14 PM -
by nobbnobb1Hello,
I have a Velodyne DPS-12 subwoofer that was making weird noises. Upon taking it apart, I noticed there was yellow glue all over the circuit board which had turned brown, so I scraped it all off and that fixed the problem. I used hot glue instead around the various components.
There was also one bulging capacitor, and another that must've been in a really hot location because the labelling looked like it was scorched. You can see in the picture the circuit board has discolored over time from this heat. Could either be from the MOSFET (with heatsink), or the resistor....-
- Loading...
