Laptop overheating after replacement thermal paste
  • Veyron7887
    • Nov 2023
    • Turkey
    Hi. I have Asus X55C laptop from year 2013. It has i3-2328M CPU. I replaced stock thermal paste with high quality thermal paste. Before thermal paste replacement, I measured CPU temperature Around 65-70 degrees Celcius with stock thermal paste. If after the replace thermal paste, I measured CPU temperature around 80-84 degrees Celcius and fan don't stop when system is idle. I replaced the thermal paste several times but still did not change. Where is the problem?
  • mon2
    • 14737
    Is the heatsink on top of the CPU properly to dissipate the heat generated by the CPU?
    Does the logic board power up ok - other than this heating issue? Inspect all sides of the CPU to be sure the metal is touching the top layers of your heatsink compound.
