Sony xbr65x900c sound yes, no backlight or image.
  • Diah
    • Feb 2013
    • 6598
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Thanks, think i got the right one, it read 562 in diode mode, it jumps around in ohm mode just like some other same looking ones I tried to measure on the board.
    voltage messurments whilr the tv on
      • 12331
      • U.S.
      #202
      .01 volt.
        • 12331
        • U.S.
        #203
        I think thats means im in deep shit, no way I can replace that little IC, its hard enough just to see it, lol,
        • Diah
          • Feb 2013
          • 6598
          just now no need to think on the IC. pin 18 are low 0. we will find why.. go to yours LD boards you said you have 12 volts on cn6602 . on same socket pin 4 connected direct to pin 9 on the other socket at the boards... check both are connected and if they have 12V ?
            • 12331
            • U.S.
            #205
            that was the voltage i got at the G1B board, are you saying go from pin 4 of cn6601 which is vled_gd to pin 9 of 6602 which is ground? ok 4 to 9 has continuity but I have 0v when powered on.
              • 12331
              • U.S.
              #206
              edited above. They are both grounds, should they have voltage between them?
              • Diah
                • Feb 2013
                • 6598
                man. this is confused... SJ photo may different.. cn6602 pin 4 & cn6601 pin 9 they connected together and should have 12.V... you need to follow both to know who are the IN 12V. and from where.
                  • 12331
                  • U.S.
                  #208
                    • 12331
                    • U.S.
                    #209
                    probably not what you meant, I tested cn6102 pin 4 to cn6402 thats between both powerboards, i got 27v.
                    • Diah
                      • Feb 2013
                      • 6598
                      post photo on yours LD boards
                      no need you have..
                      also pin 9 recieve 12V from MB pin 1. you need to check if you have fuse on this rail on MB open
                        • 12331
                        • U.S.
                        #211
                        ok, my bad, there does seem to be a difference between the G1B and the G1C i linked, heres a pretty good picture of the G1B board. I noobed that one https://www.ebay.com/itm/12512214097...YAAOSw6dVh84uZ
                        • Diah
                          • Feb 2013
                          • 6598
                          look above i add yours photo
                            • 12331
                            • U.S.
                            #213
                            Thanks Diah, i just took a bunch, ill add them.
                              • 12331
                              • U.S.
                              #214
                              Pictures:
                                • 12331
                                • U.S.
                                #215
                                pictures:
                                • Diah
                                  • Feb 2013
                                  • 6598
                                  my attached photo at post #210 i wrote it in wrong way
                                  12V come from PCB to the boards cn6602 pin 4 then go to MB via PIN 9 CN6601.
                                  just check there are 12V or not.
                                    • 12331
                                    • U.S.
                                    #217
                                    with this camera if you try to get too close it blurs everything.
                                      • 12331
                                      • U.S.
                                      #218
                                      ok, i have 12 at 4 and 9, i measured between 9 and where it goes to ld board, there is 0v on the ld side, thats from cn6601, should i yank that harness and check it for continuity?
                                        • 12331
                                        • U.S.
                                        #219
                                        I do currently have the bl-error pin from pin 2 grounded to pin 9 on cn6602, has been for a while.
                                        • Diah
                                          • Feb 2013
                                          • 6598
                                          ok. now you need on the socket cn6602 pin 1 BL_ON to pull it out from the socket ( discconect it ) and power on... messure the cable if it go high... in case yes or no ... go to the shit IC pin 18 check if it get >3.V
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
