Sony xbr65x900c sound yes, no backlight or image.
  • nomoresonys
    • 12330
    • U.S.
    #161
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Service manual there: https://www.manualslib.com/manual/20...?page=8#manual
    • Diah
      • Feb 2013
      • 6565
      plugged it in it flashed green/orange for about a minute then went out then turned green for a few seconds then went out, turned it on with remote, have stable white dim indicator and android music.
      the tv working now at least PCB and MB 100%
      just now you dont have BL on... are you sure the leds are fine????
      • Diah
        • Feb 2013
        • 6565
        check BL_ON on the PCB socket if its H or L
        • nomoresonys
          • 12330
          • U.S.
          #164
          with it plugged in and off bl-on is 0 volts, powered up with solid white light and music its still 0 volts.
          • nomoresonys
            • 12330
            • U.S.
            #165
            I tested with backlight tester, they all lit up 11 at a time with 60 on the tester screen.
            • nomoresonys
              • 12330
              • U.S.
              #166
              This one gets the bl-on signal from mainboard right?
              • nomoresonys
                • 12330
                • U.S.
                #167
                should I unplug the bl-on wire from connector on powerboard side, to see if the backlights will come on?
                • Diah
                  • Feb 2013
                  • 6565
                  dont do it... you will toast the PCB and MB maybe.
                  you have BL_ON 0 L mean you have 10000000000000% LED back light issue... dont trust tester.. i told you before.. there are zener diode bulid in reverse ..any one short will pass the tester but not the set as it monitore always the currents.
                  • nomoresonys
                    • 12330
                    • U.S.
                    #169
                    I grounded out the bl-error for testing but backlights didnt come up, thats what some are doing that get the 4 red blinking lights, I wouldn't run it like that was just for testing but it didnt work.
                    • nomoresonys
                      • 12330
                      • U.S.
                      #170
                      Some are saying that this is the worse pos tv sony has made to date, inclined to believe it, backlights are hard if not damn near impossible to find, how do I test them individually? so I can identify the bad ones, they dont show any damage that I can see.
                      • Diah
                        • Feb 2013
                        • 6565
                        LVDS must connected to T-CON and other small socket to T-CON should be in place.
                        when power it on did you got any V. up and down on any of LED+ with reference to chassis ?
                        • nomoresonys
                          • 12330
                          • U.S.
                          #172
                          There's no spike, just pops on 39.5 and stays there on vled-vcc 1 and 2 pin when tested on cn6601 connector on G1B board, tcon is hooked up.
                          • Diah
                            • Feb 2013
                            • 6565
                            follow S.M page 142 ( check BL_ON (L or H) on main boards : IC9017 #18pin if low then go back to S.M page 136 follow it however its not accurate 5 time blinking.
                            of course if there no picture signal from main boards it will not turn on BL.. so if you are sure 100% the BL okay.. need to put the screen in place while trouble shooting.
                            • nomoresonys
                              • 12330
                              • U.S.
                              #174
                              Its some strange shit Diah, I got 4 blinks the first time the tv messed up, i fooled around with it and never got the 4 blinks again, still have the 2.3 volts on bl-error, will try a needle to probe the little wire 18, thanks.
                              • nomoresonys
                                • 12330
                                • U.S.
                                #175
                                its not marked on the board, but i think its 9 pins from left top pin for pin 18, the voltage is 3.24v.
                                • nomoresonys
                                  • 12330
                                  • U.S.
                                  #176
                                  crap, was i suppose to check pin 18 of the ic or the connector??
                                  • Diah
                                    • Feb 2013
                                    • 6565
                                    LOL.... on main boards IC9017 pin 18 , this ic are the U com. so like hearts.
                                    • Diah
                                      • Feb 2013
                                      • 6565
                                      fooled error didn't mean repair.. so 4 error belong LED driver boards G boards need to take it out and show here up and down clear photo
                                      • nomoresonys
                                        • 12330
                                        • U.S.
                                        #179
                                        Lol, ok, i was testing the dam connector.
                                        • nomoresonys
                                          • 12330
                                          • U.S.
                                          #180
                                          best can tell pin 18 on ic is 0v, its tiny work probe slipped a bit and touched the next one and it went back to orange/green blink, turned it off, turned back on still the same, so guess i didnt mess anything up with the probe slip, tested the voltage on the tcon fuse while i was at it, it only reads .11 volts on each side, wonder if thats because the screen isnt attached?
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            Yesterday, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
