Sony xbr65x900c sound yes, no backlight or image.
  • nomoresonys
    • 12331
    • U.S.
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Nothing labeled fs that I can see on top of board, there's some labeled fb, should I rip it out and check bottom of board, that's where I have the tiny resistors reading short.
    • nomoresonys
      • 12331
      • U.S.
      I'll rip the board back out and report all shorts.
      • Diah
        • Feb 2013
        • 6598
        yes Fb. my typo. i dont thnk you have short.. its much open circuit at primary because the main fuse didnt blow up since yours Main filter caps blowing out. i think R.J are good at this part to follow. hope he join and help you
        • nomoresonys
          • 12331
          • U.S.
          Looks like about 6 tiny resistors are reading short, one near D950A, D950A reads good. There's 5 tiny resistors around D901 and IC901 reading short, the labels on the resistors that I was able to read were 3R3, 3R6, 4R4Z as far as my eyes can tell, don't have 20/20 vision any more, thanks.
          • nomoresonys
            • 12331
            • U.S.
            Ok, checking fb, thanks.
            • Diah
              • Feb 2013
              • 6598
              3R3, 3R6, 4R4Z are fuseable R low Ohm. they are not short.
              • nomoresonys
                • 12331
                • U.S.
                #27
                All fb on top of board show continuity.
                • nomoresonys
                  • 12331
                  • U.S.
                  #28
                  Oh, ok, thanks.
                  • nomoresonys
                    • 12331
                    • U.S.
                    #29
                    Dam that's a relief, I couldn't change those out, too tiny.
                    • Diah
                      • Feb 2013
                      • 6598
                      free the legs of the MOFSET under the heatsink. then test .. it could be one are open.
                      • nomoresonys
                        • 12331
                        • U.S.
                        #31
                        Can you see the label on that mosfet, the number, is it Qxx something?
                        • nomoresonys
                          • 12331
                          • U.S.
                          #32
                          Oh crap, did you mean all of them? big job.
                          • Diah
                            • Feb 2013
                            • 6598
                            start with the 2 close to the IC and main filter cap place.. by the way which value of filter cap you bridge to the boards?
                            • nomoresonys
                              • 12331
                              • U.S.
                              #34
                              two of the 450 v, 220uf.
                              • Diah
                                • Feb 2013
                                • 6598
                                the original was 2x110 uf, it mean 1 x220uf enough
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #36
                                  dam those mosfets are in deep, can I just clip a leg and check or do I need all the legs out of circuit? if so does it matter which single leg I clip? thanks.
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #37
                                    Wasn't sure if I needed to put 2 caps back in so I replaced the 2 570v 110uf with the 2 450 220uf, you think that's messing things up?
                                    • Diah
                                      • Feb 2013
                                      • 6598
                                      yes 100%
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        #39
                                        Should I take one out, if so can I just test with the one still in and nothing in the other spot? thats what I wasnt sure about, thanks.
                                        • Diah
                                          • Feb 2013
                                          • 6598
                                          the 2 original caps are connected together at - and + so the value of 2x 110uf = 220uf. so 1x220uf will be enough, take one out and leave the other on correct position of - & +
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
