Sony xbr65x900c sound yes, no backlight or image.
  • Diah
    • Feb 2013
    • 6573
    Re: Sony xbr65x900c sound yes, no backlight or image.
    if you cant then remove it from PCB socket side... and make the jumper on the PCB sockeks pin
    • nomoresonys
      • 12330
      • U.S.
      #302
      should i leave the cable plugged in on the mainboard side?
      • Diah
        • Feb 2013
        • 6573
        sure the socket cable should connected to MB... only the cable (tcon_on) we disconnected it from the PCB socket and on the PCB we make jumper t-con_on to power on. ( this is simulation that MB send signal to power on the t-con )
        • nomoresonys
          • 12330
          • U.S.
          #304
          did jumper, have 12v on 26, checked and tcon fuse now has 12v on each side with jumper in place.
          • Diah
            • Feb 2013
            • 6573
            did jumper, have 12v on 26, checked and tcon fuse now has 12v on each side.
            you need to explain now what did you have..
            did you have blinking error ?
            BL get on ?
            do you hear music as start setting?
            did you can see picture on screen with tourch light ?
            • nomoresonys
              • 12330
              • U.S.
              #306
              ok, have it on a power strip, no blinking red, when i first plug it in strip and turn on strip, it will blink orange and green, then i hit power on remote it goes bright white for a second then dim white, if i turn it on and off at that point it just goes same bright white then dim white no orange/green blink, if i turn off the strip then turn it back on and turn on tv it will start with orange/green blink again etc. No backlight, no image with torch, pretty much always had the music.
              • nomoresonys
                • 12330
                • U.S.
                #307
                took a while had to find the parts put it partial back together and put the legs on to get this skinny monster upright to see the screen.
                • Diah
                  • Feb 2013
                  • 6573
                  it sound the LD boards blocking MB to start TCON_ON and BL_ON. so let us terminate LD boards from the system.
                  you need disconnect the ribbon cable between LDboards and MB
                  and unplug the socket CN6601 between G1B boards and LD boards.
                  the TCON_ON cable which you pulled it out put it back in place
                  when you turn on the set measure the following voltage.
                  1- TCON fuse come high or not ? if come high check picture with torch light on screen.
                  2- on socket 6601 G1B boards pin 1 & 2 should >60.V
                  if every things fine mean LD boards defect. if nothing change. MB issue. if the tv give blinking error its much LD or MB.
                  • nomoresonys
                    • 12330
                    • U.S.
                    #309
                    tcon on wire is back in, with ld plugged out from mb and sub powerboard, tcon fuse is back to .10v, pin 1 and 2 on 6601 is 39.5v, no image with torch.
                    • Diah
                      • Feb 2013
                      • 6573
                      MB. put every things back as it should.. and try force the tv with its firmware reset while you have correct firmware on usb stick
                      • nomoresonys
                        • 12330
                        • U.S.
                        #311
                        trying to make sure this usb is prepared correctly tried it a lot before with no success, its fat32, i have 1 android folder on it and 1 LOST.DIR folder, and update_loader.pkg, does that look correct? any certain procedure needed? like plug in usb turn on tv or turn on tv plug in usb etc?
                        • Diah
                          • Feb 2013
                          • 6573
                          android & lost dir folder are generated if any USB stick inserted in TV and the set firmware working.. delete them.. and press the joystick down and plug in wall until the front indicator turn green same way of hard reset. if nothing new bring to you, you need to consider MB replacement and i think this is not the end too
                          • nomoresonys
                            • 12330
                            • U.S.
                            #313
                            ok, i tried it before your last responce, i did get a bit of a different outcome than last time i tried update. i plugged usb in, plugged tv on it went green/orange, usb stick lit up and blinked as they do, did it for about 20 seconds then stopped lighting up, then about 30 seconds later tv indicator light went red for a few seconds then yellow for a few then red, thats where it is now.
                            • Diah
                              • Feb 2013
                              • 6573
                              ok, i tried it before your last responce,.
                              did you killed the last spirit of MB LOL.... give it time
                              • Diah
                                • Feb 2013
                                • 6573
                                BTW: LD boards socket which it go to sub power on cn6601 pin 6 are the LD_ERR does it go high ?
                                edit pin 6 if i read the tiny no correct
                                • nomoresonys
                                  • 12330
                                  • U.S.
                                  #316
                                  did the hold power and vol - , plugged in was green/orange for about 15 seconds went solid green let go of buttons, about 10 seconds later started green/orange again.
                                  • Diah
                                    • Feb 2013
                                    • 6573
                                    it resetet give time for it it will reboot 2 time untill it became dim white
                                    mean while check pin 6 cn6601 if its high
                                    • nomoresonys
                                      • 12330
                                      • U.S.
                                      #318
                                      ok, pin 6 on cn6601 is 0v, did you mean leave the usb in after it goes to red solid? I took it out because you said if it shows those folders on the drive then the firmware on the tv is already ok or something like that, lol.
                                      • nomoresonys
                                        • 12330
                                        • U.S.
                                        #319
                                        I think you meant while doing the reset, to just give it some time, correct? some days i have more trouble than others with english, lol.
                                        • Diah
                                          • Feb 2013
                                          • 6573
                                          remove USB, no problem, but at which state its right now?
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
