Sony kdl 65xg9505 green amber blinking
  • shahnld
    • Nov 2019
    • 164
    • Netherlands
    Good Day.
    I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
    i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
    green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite and was playing music via hdmi. after installing tcon this green amber issue showed up. now with or without tcon same issue.
    renaming, in original state nothing helps. any idea's which may help is welcome..
    cheers
  • lotas
    • Jan 2016
    • 4850
    • Russia
    Well it's written right there:
    Extract the downloaded file to a location on your computer you can easily find.
    Note: After you extract the downloaded file, you will find another zip file (sony_dtvxxxxx_xxxx_xxxxxx.zip).
    You just need to extract the internal zip file to the flash drive.
    • shahnld
      • Nov 2019
      • 164
      • Netherlands
      yes. and that zip does not do anything when i put it in usb drive. usb is formated mbr 16gb ntfs
      • shahnld
        • Nov 2019
        • 164
        • Netherlands
        Tv does not seems to be using that file. cause no matter what its just blinking green amber.
        • lotas
          • Jan 2016
          • 4850
          • Russia
          You need to turn on the TV, the LEDs will start blinking, wait about 20 seconds and then insert the USB with the firmware into the TV...
          And not all USB flash drives will accept the update, try different smaller flash drives from different companies!
          And format the USB flash drive to fat32.
          • shahnld
            • Nov 2019
            • 164
            • Netherlands
            i just extracted the downloaded zip to the usb which created another zip in there.
            turned the tv on. green amber blink for 20 seconds then i inserted the usb in tv. now its still blinking green amber and then goes solid green for few seconds and goed all leds out then starts again the same. it does not turn in to blinking white which all other sony does..
            • shahnld
              • Nov 2019
              • 164
              • Netherlands
              ok. i have 3x usb drives.
              2x usb 2.0, 1x 3.0.
              i will try again with all 3 one by in fat32 format.
              only that extracted zip is ok. or do i need to extract the 2nd zip to reveal all the files..
              • lotas
                • Jan 2016
                • 4850
                • Russia
                The second zip does not need to be unzipped.
                "Insert the USB flash drive containing the extracted file (sony_dtvxxxxx_xxxx_xxxxxx.zip) into a USB port of the TV set."​
                • shahnld
                  • Nov 2019
                  • 164
                  • Netherlands
                  Ok thanks. i am now making one ready. will reply with the results in a few minuts .
                  • shahnld
                    • Nov 2019
                    • 164
                    • Netherlands
                    2nd usb. fat32 16gb. usb starts to blink and the tv led goes to solid green for few seconds. then all leds goes out. then starts all over again. goes out, goes on blinks green amber goes out. it never blinks white.. or i just need to wait and it may be blinking green and amber during the update..?
                    • lotas
                      • Jan 2016
                      • 4850
                      • Russia
                      You should try 4.8 Gb flash drives, this is SONY, they are very capricious when it comes to flash drives....
                      • shahnld
                        • Nov 2019
                        • 164
                        • Netherlands
                        oh. i dont have that small. will try to find one.
                        • lotas
                          • Jan 2016
                          • 4850
                          • Russia
                          Before each update check, try this
                          Unplug the TV and wait 20 seconds.
                          Reconnect the TV to the outlet, wait 30 seconds and then turn it on using the button on the remote control.
                          And after about 20 seconds, insert the USB drive into the USB connector of the TV.​
                          • shahnld
                            • Nov 2019
                            • 164
                            • Netherlands
                            i am not sure of the led blink behaviour on this tv. it goed solid green then goes out. then just now it got solid amber then went out so. i mean how long normally it should blink green and amber before going to white. and should it go to white or what else. and how to know if its not reading or working the files.
                            • lotas
                              • Jan 2016
                              • 4850
                              • Russia
                              It is better for you to have a usb flash drive with an LED, and then you will see that it is being accessed, it will blink, which means files are being copied, the update can last 20 minutes with a black screen, then it will reboot, when updating, it is strictly forbidden to remove the usb flash drive, press buttons and turn off the TV.
                              • shahnld
                                • Nov 2019
                                • 164
                                • Netherlands
                                wel. usb is with led indicator. it blinking at 1st then nornal slow blink but not fast as its being accesded.
                                i think this .zip firmware in only working when the tv is working and someone wants to update. i watched 100 videos and posts about sony firmware updated and all were using .pkg in a usb when tv gives green amber blinks.
                                otherwise it was working without tcon. i could here the music and all those beeps when tv is accessed via remote.
                                but now i dont here those beeps iether. bluetooth is still visible when i try to connect my mobile..
                                i have tried 4x diff usb's and all kind of tricks but non worked..so only left option is .pkg file which i couldnt find anywhere..
                                • shahnld
                                  • Nov 2019
                                  • 164
                                  • Netherlands
                                  Took out same board from another tv. doing the same issue. green amber. usb activity goes on for about 5 minuts then the tv restarts and then the same..
                                  • nomoresonys
                                    • 12328
                                    • U.S.
                                    Probably bad eMMC.
                                    • shahnld
                                      • Nov 2019
                                      • 164
                                      • Netherlands
                                      wel. same board from a working tv with broken screen which was booting perfect giving the same issue..
                                      • shahnld
                                        • Nov 2019
                                        • 164
                                        • Netherlands
                                        Probably bad eMMC.
                                        anyway to confirm if eMMC is bad..? which programmer can be used to reprogram replacment eMMC? and what files are required..
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • huzo
                                          HP 470 G5 blinking amber light no power
                                          by huzo
                                          The board is daox8cmb6eo and i can't find no boardview or schematics on the forum or anywhere...
                                          So i plug in the charger, amber light starts blinking ,there is 3.3V and 5V present, and 2.4V on the power button,board doesn't turn on, no shorts...
                                          I've tried flashing the bios...
                                          interesting thing is the battery was around 7,8V, and it's 11.1V battery, the mosfet near the battery is open, but not charging,i desoldered it,tested it and it's fine ,but the amber light kept going on the charger so i charged the battery with power supply and got it to about 10.5V...
                                          06-08-2023, 04:08 PM
                                        • jxrepman
                                          Asus X453MA won't turn on and green led light blinking
                                          by jxrepman
                                          Hi there,
                                          I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                          I have checked the charger and it is giving 19+ V
                                          I have disconnected the battery and pressed power button for 30 seconds.
                                          I tried another RAM stick.
                                          Tried disconnecting the keyboard and touchpad.
                                          Tried disconnecting the HDD and the wifi adapter.
                                          The problem persists.
                                          Hope you could help me out on this one. Thank you.
                                          12-14-2024, 06:40 AM
                                        • CSM123
                                          Sony KDL-55HX850 - Blinking 3x
                                          by CSM123
                                          Have KDL-55HX850 that seems to have been hit by power surge.
                                          Blinking red 3x - clicks on/off on the power supply board when power is held in.
                                          Replaced Power Supply G board - same response.
                                          Replaced main BAP - no response at all. Seems worse, maybe bad board.
                                          Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
                                          Checked speaker impedances ok 8ohms each.
                                          Where are JL6002, JL6005 test points?
                                          Ideas for what next to troubleshoot?
                                          Could it be T-Conn or LED board? Seems that the troubleshooting...
                                          02-06-2024, 11:50 AM
                                        • YasaCh
                                          sony kd-49xf9005 4 red blinking problem
                                          by YasaCh
                                          Sony KD-49XF9005 it power up to android boot screen and turns off immediately with continuously 4 red blinks ...
                                          05-05-2025, 08:40 AM
