Sony xbr65x900c sound yes, no backlight or image.
  • nomoresonys
    • 12272
    • U.S.
    #101
    Re: Sony xbr65x900c sound yes, no backlight or image.
    Or should it read short til a new zener is in place?
    • nomoresonys
      • 12272
      • U.S.
      #102
      Originally posted by Diah
      for zener 676 / 704 are acceptable value .. mybe yours DMM drunk !!!
      Damn meter must be drunk, Makes me need a drink for sure, is it 5 o'clock yet?
      • nomoresonys
        • 12272
        • U.S.
        #103
        Ok, read it with a good mag glass, nz4v7d. smallest shit ive read in quite a while. Uh o hope that turd dont get me 4 points.
        • Diah
          • Feb 2013
          • 6435
          look on this thread up post #13
          • vinceroger69
            • Mar 2012
            • 6714
            • uk
            #105
            as per budm reply post 14 in thread diah found
            It is connected in parallel wirh R907A/B so it will show conduction in both directions when tested in circuit.
            • nomoresonys
              • 12272
              • U.S.
              #106
              Thanks Diah, I think I have the very same problem as in that thread.
              • nomoresonys
                • 12272
                • U.S.
                #107
                Thanks VR69, that was buggin the hell out of me, I thought it tested like the rest before but I had to be wrong, guess I have to change it becuz it tested at 848.
                • nomoresonys
                  • 12272
                  • U.S.
                  #108
                  Is 227 ok for diode 950a, it may be a shottky?
                  • nomoresonys
                    • 12272
                    • U.S.
                    #109
                    Can I use a 1/2 watt zener or does it have to be 1 watt?
                    • charlie555
                      • Feb 2018
                      • 76
                      • usa
                      #110
                      So you turn on the tv and comes up to 4 little images and then shuts off then 4 read blinks?
                      • nomoresonys
                        • 12272
                        • U.S.
                        #111
                        It was, then I think I did too much research and went down the wrong path, thinking the backlights were at fault, tested each with tester all worked, was a pain, tiny connection pins, if you test them cover them with something, I just used a piece of notebook paper, they are blinding bright. I think my problem is on powerboard, waiting on the slow boat from china for parts.
                        • nomoresonys
                          • 12272
                          • U.S.
                          #112
                          Images weren't there but the android music was.
                          • nomoresonys
                            • 12272
                            • U.S.
                            #113
                            Avoid this seller, all these junk zener diodes tested at 840 or higher, with 3 meters, which all tested my good zeners between 500 and 700: https://www.amazon.com/Voltage-Regul...s%2C96&sr=8-42
                            • nomoresonys
                              • 12272
                              • U.S.
                              #114
                              Can't imagine that this board's zeners would be higher than most zeners, only 2 measure in spec, zd902 at 682 and zd907 at 710, unless someone has a similar working powerboard with these high readings, It has to be these guys are selling pure junk.
                              • Diah
                                • Feb 2013
                                • 6435
                                they are good for CRTs vaccuum tube TV, not as yours LED LCD.
                                • nomoresonys
                                  • 12272
                                  • U.S.
                                  #116
                                  Damn, you mean these are good but I just bought the wrong ones?
                                  • nomoresonys
                                    • 12272
                                    • U.S.
                                    #117
                                    One of the values is 1n4732, I thought that's what they said in that other thread was a good replacement for nz4v7d, I probably got it wrong.
                                    • Diah
                                      • Feb 2013
                                      • 6435
                                      1N code at electronic parts world had others name code ( tomato ) you just bought Code not the deepest specification ,,,, how about the watt? did you know !!! so this is tomato can be used at any dishes. but who knows which taste at end will be.
                                      • nomoresonys
                                        • 12272
                                        • U.S.
                                        #119
                                        https://www.badcaps.net/forum/showthread.php?t=81634: Was that thread, 1n4732a was suggested as repacement, the new ones that tested at 850 are 1n4732 but no a suffix, wonder if that matters? thanks.
                                        • nomoresonys
                                          • 12272
                                          • U.S.
                                          #120
                                          Ad said 1 watt.
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • iglitare
                                            Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
                                            by iglitare
                                            i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
                                            Backlight seems to work, Sound (Setup menu after reset) works.
                                            If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
                                            Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
                                            With my small knowledge i would think at least the cables are good.
                                            Can this happen because of a bad tcon board?
                                            Or is it always a bad/shorted...
                                            09-04-2025, 07:13 AM
                                          • Kartowl
                                            philips 47pfl6158k/12 image faded away, sound still coming from TV
                                            by Kartowl
                                            Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                                            04-23-2024, 12:57 AM
