Sony xbr65x900c sound yes, no backlight or image.
  • Diah
    • Feb 2013
    • 6565
    Re: Sony xbr65x900c sound yes, no backlight or image.
    if it read zero ( nothings ) at the opposite way measure try it.
    • nomoresonys
      • 12330
      • U.S.
      #122
      yes 850, switch leads and it's 1, like most diodes, read in diode mode, most standard diodes I read are usually 5xx or close to it.
      • Diah
        • Feb 2013
        • 6565
        did yours meter read 1 when there are nothings connect to the probe at this diode mode ???
        • nomoresonys
          • 12330
          • U.S.
          #124
          Yes it does.
          • Diah
            • Feb 2013
            • 6565
            maybe its L not 1 LOL
            • nomoresonys
              • 12330
              • U.S.
              #126
              Lol
              • nomoresonys
                • 12330
                • U.S.
                #127
                Startin to think I'll need a hammer to fix this one.
                • nomoresonys
                  • 12330
                  • U.S.
                  #128
                  Is 1n4732 ok to replace 1n4732a and nz4v7d I wonder?
                  • Diah
                    • Feb 2013
                    • 6565
                    if with nothngs on probe read L or 1 what ever.. i think yours original zener read same or ?
                    • nomoresonys
                      • 12330
                      • U.S.
                      #130
                      Yes the old one reads the same as the new one, 850 and 1 in reverse.
                      • Diah
                        • Feb 2013
                        • 6565
                        did you messure other at the pack u bought all read 850 ?
                        • nomoresonys
                          • 12330
                          • U.S.
                          #132
                          Read all 20 of the 1n4732, all read around 850, read about 40 of the others all read about the same 840 to 860 or so, gave up at that point, there is 200 zeners in all, from 1n4728 to 1n4737.
                          • Diah
                            • Feb 2013
                            • 6565
                            i would put the original back. and the way you did only cap 220 change it to 2 of 110uf or 3 of 78uf.. it may now the currents low amp. dive in your scrap and look if you find main caps
                            • nomoresonys
                              • 12330
                              • U.S.
                              #134
                              Ok, I'mado it.
                              • nomoresonys
                                • 12330
                                • U.S.
                                #135
                                Thinking about using two of these three: 450v 160uf, 450v 47uf and 400v 180uf, looks like closest match is 450v 47uf and 400v 180uf.
                                • Diah
                                  • Feb 2013
                                  • 6565
                                  should the 2 botth same value so use 2 of 450V 160uf
                                  • nomoresonys
                                    • 12330
                                    • U.S.
                                    #137
                                    Well I don't have two that match in the whole mess, guess I'll have to buy some, will two 450v 110 or 120uf be ok for permanent replacement? thanks.
                                    • Diah
                                      • Feb 2013
                                      • 6565
                                      2X 110uf 570V or 500V and above
                                      • nomoresonys
                                        • 12330
                                        • U.S.
                                        #139
                                        Ok, thanks, did anyone measure one of these zener diodes 1n4728 thru 1n4737? still not sure if I got a bad batch, they all read 840 to about 860.
                                        • nomoresonys
                                          • 12330
                                          • U.S.
                                          #140
                                          None, nobody has a zener 1n4728, 1n4729, 1n4730, 1n4731, 1n4732, 1n4733, 1n4734, 1n4735, 1n4736, or 1n4737, they can test in diode mode??
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            Yesterday, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
