Sony xbr65x900c sound yes, no backlight or image.
  • nomoresonys
    • 12331
    • U.S.
    #241
    Re: Sony xbr65x900c sound yes, no backlight or image.
    put it all back, turned it on does same as without panel, do have solid light at optical out.
    • Diah
      • Feb 2013
      • 6595
      music here ? check screen with tourch
      • nomoresonys
        • 12331
        • U.S.
        #243
        yes music, gonna have a rough time getting a look at screen, only put some screws along the bottom, so this thin allinone panel deal is unstable, i ll give it a shot.
        • nomoresonys
          • 12331
          • U.S.
          #244
          guess i cant look at the screen, misplaced the screws for the legs, i doubt if theres an image tho, theres only .10 v on each side of tcon fuse.
          • nomoresonys
            • 12331
            • U.S.
            #245
            Does this seem wrong? checked this and there is continuity but no 12v on the ld board pin 9: I have 12 at 4 and 9, i measured between 9 and where it goes to ld board, there is 0v on the ld side, thats from cn6601.
            • Diah
              • Feb 2013
              • 6595
              pin 9 on cn6601 go to LD boards pin 1 LOL.. check again
              but T-CON 10.V this is not normal you need to test it on the 5 pins socket on T-CON pin 3- 4- 5 recieve 12V from power boards direct
              • nomoresonys
                • 12331
                • U.S.
                #247
                my bad, i meant pin 1, i just followed the wire over continuity but no 12 on ld board, will check the tcon 12s.
                • nomoresonys
                  • 12331
                  • U.S.
                  #248
                  checked the tcon 12s at 5 pin connector, 0v on all of them.
                  • Diah
                    • Feb 2013
                    • 6595
                    tv on or off ????
                    only pin 4 and 5 12v. other nc and GND
                    • nomoresonys
                      • 12331
                      • U.S.
                      #250
                      i have that bl-error pin grounded out, don't know why these voltages are missing.
                      • nomoresonys
                        • 12331
                        • U.S.
                        #251
                        Originally posted by Diah
                        tv on or off ????
                        checked with tv on.
                        • Diah
                          • Feb 2013
                          • 6595
                          cant be .. there are error at test
                          check all cable u pulled yesterday if they are okay
                          • Diah
                            • Feb 2013
                            • 6595
                            did you forget what you did before !!! yours POST #169
                            • nomoresonys
                              • 12331
                              • U.S.
                              #254
                              yes its still grounded out, took 2 bl-error wire and put it in 9 gnd, been that way all thru testing.
                              • nomoresonys
                                • 12331
                                • U.S.
                                #255
                                thats suppose to "fix" the 4 blink code, didnt for me tho.
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  #256
                                  the voltages are not there, 12 isnt getting from cn6601 pin 9 to ld board pin 1, and the tcon 5 pin connector has 0 v, one of the pins might have showed .10 volts like the tcon fuse does but thats what they are, tested 4 or 5 times.
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    #257
                                    it must be that damn IC9107 is bad, I guess.
                                    • Diah
                                      • Feb 2013
                                      • 6595
                                      remove all i wrote bring the tv as original..
                                      you are the bad here... sorry.. this why pin 18 0V and this why no picture even panel power on was high at the IC .. you fooled me before your self,, this never being trouble shooting... its just kids play game.
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        #259
                                        I wrote that it was like that at least 2 times.
                                        • nomoresonys
                                          • 12331
                                          • U.S.
                                          #260
                                          putting it back as original but i dont think it should matter because a lot of people fixed 4 blink with that setup, if it kept all the voltages low their tvs would not be working.
                                          • domix
                                            Sony KD - 65XF9005 - No image, sound OK
                                            by domix
                                            at tv KD - 65XF9005 i have a problem.
                                            Afrer a coupe of minutes (10-30) i got black screen, no image. But i have sound.
                                            is this a common problem for this tv?
                                            i attached pictures of inside. Supply board looks okey, no blowed caps....
                                            07-21-2025, 06:37 AM
                                          • rimwall
                                            Sony KD-65x7500D - double image - Tcon or Panel?
                                            by rimwall
                                            This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
                                            I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
                                            11-18-2025, 02:09 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • shahnld
                                            Sony kdl 65xg9505 green amber blinking
                                            by shahnld
                                            Good Day.
                                            I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                            i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                            green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                            01-03-2024, 03:05 PM
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
